e85+___boost= 500ish rwhp? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 01-01-2016, 09:20 PM Thread Starter
Trader Feedback: (15)
I am looking to get just under or over 500 rwhp on my stock block/ t-5 with hci and bolt ons. I am planning on getting a v3 si or an on3 67cbb and running e85. anyone have any experience with either of these set ups and how much boost and timing to achieve on or about those numbers with e85? I am leaning towards the turbo since changing springs is easier than pulleys. I am thinking 10 lbs should do the trick. I got deatschwerk 78s and a 340 both specifically for e85. Thanks guys
MH60SMECH is offline
post #2 of 7 Old 01-02-2016, 01:11 AM
B0jangles's Avatar
10lbs sounds pretty conservative for 500 on a stock 302. E85 lets you run more boost safely with more aggressive timing but it has a lower energy density than unleaded. If the 302 can do 10lbs on premium unleaded that's a lot easier than converting your whole fuel system and filling up more often
B0jangles is offline
post #3 of 7 Old 01-02-2016, 12:38 PM
Trader Feedback: (36)
I made 461/548 to the wheels through a stock '86 long lock with 16psi. 93 pump gas.
A h/c/I long block boost should make 500+ on 10psi no problem. No need to start playing with e85
1995 Mustang GT 5.0
DevaRoh is offline
post #4 of 7 Old 01-02-2016, 12:40 PM
without a decent top end you're going to need closer to 20lbs for 500 rwhp. At that point, a 302s head gasket is a laughin matter..... I never had any luck going much past 12psi on a stock 302 with iron heads.
Turbocharged 87 GT T Top
XBL Tag: Mikemachine812
MJs89GT is offline
post #5 of 7 Old 01-02-2016, 01:05 PM
Iron e6 heads, studs and fel-pro 9333's.
I ended the season pushing 18psi n went [email protected]
3415 race weight tremec 3550 5speed
Pulled the motor still running strong
1995 Mustang GT 5.0
DevaRoh is offline
post #6 of 7 Old 01-02-2016, 08:46 PM
I mad 495 RWHP and 560 RWTQ at 10# of boost with a HCI car. It was actually just under 10#, 9.5 to be exact, but if I upped it just a little more, it would be right at 500.
Daves8950LX is offline
post #7 of 7 Old 01-05-2016, 02:35 PM Thread Starter
Thanks for the input guys.
Help! Fuel setup... E85, gas IDK and between 600&700 rwhp one_live95 GT & SOHC 0 07-17-2012 01:26 AM
MY E85 Experiment (F+) Michael Plummer Superchargers 20 06-01-2012 09:30 PM
E85 vs Water/Methanol Injection Michael Plummer Superchargers 44 05-14-2012 12:41 PM
RWHP capability of Aeromotive A1000 + E85? KrisR General Mustang Tech 8 08-01-2011 10:14 PM
Thinking of doing a Vortech and E85 to my 96 cobra. Mobile Chassis Dyno SVT & DOHC 10 01-09-2011 05:40 PM
