1st pass in 3yrs 9.1@149.9 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 26 Old 12-13-2015, 11:53 PM Thread Starter
Formerly eades5.0
4Jenna's Avatar
1st pass in 3yrs [email protected]
I couldnt be happier
14psi
17* total
https://www.youtube.com/watch?v=PXA4qynlC5w
WWW.JENNABEARSFOUNDATION.ORG
4Jenna is offline
post #2 of 26 Old 12-14-2015, 03:53 AM
GilroyRacing's Avatar
Trader Feedback: (111)
Very nice, congrats.
91 Fox
R.I.P. 347: 1.43 60' [email protected] 1/8th [email protected] 1/4
302 1.59 60' [email protected] [email protected]
GilroyRacing is offline
post #3 of 26 Old 12-14-2015, 05:25 AM
91lxntch's Avatar
Trader Feedback: (40)
What's the combo....
91lxntch is offline
post #4 of 26 Old 12-14-2015, 08:17 AM
Chebby
91 Fox
post #5 of 26 Old 12-14-2015, 10:58 AM
blk91coupe's Avatar
What turbo?
blk91coupe is offline
post #6 of 26 Old 12-14-2015, 05:00 PM
Radrick50's Avatar
Trader Feedback: (60)
Awesome!! Super congrats!!!
Radrick50 is offline
post #7 of 26 Old 12-15-2015, 01:18 PM
2Guard's Avatar
Slight work
Car/92 5.0/ Engine stock block/ and bolt-ons.. [email protected] (sold)
97 Cobra All stock for now...
2Guard is offline
post #8 of 26 Old 12-16-2015, 07:29 PM
Very nice! Even being bowtie powered.
1995 lightning Forged 383 sbf. AFR 195 heads, Silverstate motorsports turbo kit, 76mm T-netics turbo, 50mm wg, Tial 50mm bov, Punisher built E40D, Circle D 258mm 3200 converter, Built 8.8 with welded tubes,DTS girdle, Tru-Trac and LFP 58" Longbars, Tuned by Fast
rudder9 is offline
post #9 of 26 Old 12-20-2015, 07:54 PM
Blk.Snake's Avatar
Congrats on a great pass. I really like the combo. I had a 94 in black and wanted to do a turbo on that. I ended up doing a 92 gt in a very similar blue. ( mine is a 1999 dodge truck INTENSE blue). So the color, year,and drive train are what I would have ended up with. Very nice to see.
BTW : if that was the first pass I'll BET we can expect to see a 8.50 real soon.
94 cobra, 393, afr 205s. boxr intake. (SOLD)
New 427 turbo build in progress.
Blk.Snake is offline
post #10 of 26 Old 12-20-2015, 08:00 PM Thread Starter
Formerly eades5.0
4Jenna's Avatar
Thxs!!
4Jenna is offline
post #11 of 26 Old 12-20-2015, 08:01 PM Thread Starter
Formerly eades5.0
4Jenna's Avatar
4Jenna is offline
post #12 of 26 Old 12-20-2015, 08:03 PM Thread Starter
Formerly eades5.0
4Jenna's Avatar
I still share here since I was a long time poster here even though I'm LS powered now.
100K+ mile LQ4 LS 6.0 (2004 Silverado motor)
Stock block, crank, rods, pistons, bearings, rod bolts, rings, heads, rockers, intake, tb, and exh manifolds.
I did a Cam kit, gaskets, head studs, and a oil pump.
Twin 67mm 14psi
Glide
Holley HP EFI
80lb inj
275 DR
4Jenna is offline
post #13 of 26 Old 12-20-2015, 08:09 PM Thread Starter
Formerly eades5.0
4Jenna's Avatar
Originally Posted by blk91coupe View Post
What turbo?
Garrett 67mm with p-trim turbine wheels and .81 a/r
These things really need some more boost to shine, they are barely getting on the map. The 4 passes I made last Sunday
6psi (lowest I can run) [email protected] on a 1.68 60'
10psi [email protected] 1.61
10psi smoked the tires raised the 2 step to high [email protected] 1.9 60'
14psi [email protected] 1.40 60'
Amazing from 10-14psi I went from 10.1-9.1et!
4Jenna is offline
post #14 of 26 Old 12-20-2015, 08:10 PM Thread Starter
Formerly eades5.0
4Jenna's Avatar
Appr it!
4Jenna is offline
post #15 of 26 Old 12-20-2015, 08:15 PM Thread Starter
Formerly eades5.0
4Jenna's Avatar
Originally Posted by 2Guard View Post
Slight work
Blasé Blasé
LOL
4Jenna is offline
post #16 of 26 Old 12-20-2015, 08:19 PM Thread Starter
Formerly eades5.0
4Jenna's Avatar
4Jenna is offline
post #17 of 26 Old 12-20-2015, 08:21 PM Thread Starter
Formerly eades5.0
4Jenna's Avatar
Thxs!
The car really surprised me going a bottom 9 the first time out in 3yrs, lots left in the car to say the least. From the soft 60', to the 17% slip on the converter, to shifting low, and most of all tons more power to be had when I up the boost. Just not so sure this stock motor will be happy with that lol.
Def will be updates in the future with better times I'm hoping! I couldn't ask for much more on the 1st outing!
-CE
4Jenna is offline
post #18 of 26 Old 12-20-2015, 08:50 PM
KEVIN$'s Avatar
Thxs!
-CE
What's the weak link in those stock motors?
ks
Kevin Slaby
KEVIN$ is online now
post #19 of 26 Old 12-21-2015, 12:58 AM
91lxntch's Avatar
Rods and Pistons are the weak links , # 7 is a lot of times first , very stout motors . In stock form on a budget they work good .
91lxntch is offline
post #20 of 26 Old 12-21-2015, 01:53 PM Thread Starter
Formerly eades5.0
4Jenna's Avatar
Indeed, rods and pistons. Some make tons of power and the fastest guys go bottom 8's (but I'm not sure how many motors they are going thru to get there) I'm hoping to get a season or two out of the stock stuff, then throw some rods and pistons in it and really let it eat. Most say they can live around 800rw for a long period of time.
The blocks/crank are very strong and stock heads flow well also.
Very impressed so far!
4Jenna is offline
post #21 of 26 Old 12-21-2015, 06:35 PM
botlrokit93's Avatar
Trader Feedback: (26)
Nice timeslip. No, , REALLY nice timeslip at modest boost to boot. I run basically the same setup.... 2004 lq4, ls3 heads, etc..twin billet 6765's and a glide on 325 radials. I have done countless 20+ psi hits on the street (short hits) at 10 deg. timing, 93 octane, no intercooling or meth! If your ring gaps are opened up, your good to go 8's easy with a tad more boost. Im with you though, im gonna put some forged internals in before driving over the crank, lol.... good to see some nice numbers put down with a similar combo to mine. Ive been wanting to hit the track, but no cage yet. Your endeavor has inspired me to get some bars in the car and give it a try at the local track this spring. Again, nice pass, and nice car man!
botlrokit93 is offline
post #22 of 26 Old 12-22-2015, 12:49 PM
It picked up 10 MPH for every 4 lbs of boost, lol.
Originally Posted by hondatech
One does not simply collect wins at the dragstrip. Victories there are guarded by more than just rear wheel drive... There is torque there that does not sleep. Not with 10,000 RPM could you do this, this is folly...
neat is offline
post #23 of 26 Old 12-22-2015, 04:00 PM
Great job Chris, even if I think you trolled me with the newer 5.0 engine cover. Lol
Looks like there is more left in it for sure.
kbscobravert is offline
post #24 of 26 Old 12-22-2015, 11:26 PM Thread Starter
Formerly eades5.0
4Jenna's Avatar
Thxs bud! Good luck and keep us updated!
-CE
4Jenna is offline
post #25 of 26 Old 12-22-2015, 11:28 PM Thread Starter
Formerly eades5.0
4Jenna's Avatar
Getting happy every time, lol!
Makes me wonder what it would have really trapped on 14psi if I wasn't on the limiter blowing thru the converter!
4Jenna is offline
post #26 of 26 Old 12-22-2015, 11:29 PM Thread Starter
Formerly eades5.0
4Jenna's Avatar
LOL, all in good fun!! Thxs bud, hows your beast doing?
-CE
4Jenna is offline
T5 wont go into 1st gear now? Exiled General Mustang Tech 3 07-22-2013 10:03 PM
My 1st time in NMRA Factory Stock TooSlo86 Drag Racing 27 07-17-2013 11:34 AM
T5 grinds going into 1st Bill39568 General Mustang Tech 7 04-12-2012 07:00 PM
TKO600 + 4:10's, 1st or 2nd? I3oostedCubes Drag Racing 15 06-25-2011 10:25 PM
tricks to pass E check in a 351???? mogs01gt 5.0/5.8 Engine Tech 10 01-09-2002 02:59 PM
