410"w turbo build help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 11-07-2015, 01:02 PM Thread Starter
machine head's Avatar
I'm rebuilding my DSS pro bullet 410"w over the winter. Right now I'm running tfs 205cnc heads, N91 cam, 10.5:1 compression, tfs box r intake, 90mm t/b, 90mm maf, stock computer sct chip etc.
I know I need to buy lower compression pistons and I'm gonna order a FTI custom turbo cam. My question is can you guys help me with turbo build. What company, (hellion, on3, B&G, pony down etc) what size turbo, piping etc.
Thank you.
machine head is offline
post #2 of 9 Old 11-07-2015, 09:42 PM
I would leave the compression as is, or run a little thicker head gasket, a little higher static compression will help it spool quicker and be more fun to drive on the street. If you are going to have a custom cam ground, any cam grinder that knows what he is doing will ask your compression and take that into account.
cheap10s is offline
post #3 of 9 Old 11-07-2015, 09:53 PM Thread Starter
Thank you. So I will be fine on 93 octane or will I need meth injection? Anyone recommend quality turbo system for 351w based block?
post #4 of 9 Old 11-08-2015, 08:06 AM
I would use a progressive meth injection set up and a T6 S480.
cheap10s is offline
post #5 of 9 Old 11-08-2015, 01:23 PM Thread Starter
So is it best if I fabricate my own kit with a t6 s480?
What do I look for in a kit just hot side, cold side and inter cooler? Stainless steel piping best? Who sell best parts or kits?
post #6 of 9 Old 11-08-2015, 01:57 PM
Depends on your goals. With the meth or e85 an intercooler is not mandatory.
I am sure that BG would be happy to build you a hot side with a T6 flange or you could start out
with a set of reversed shortys and go from there.
Columbia River Mandrel Bends is a good place to start.
cheap10s is offline
post #7 of 9 Old 11-08-2015, 08:27 PM
blk91coupe's Avatar
I'm doing the exact same thing as you. I am also going to use the s480. I bought a garret intercooler and ponydown headers. Now I'm having my crossover pipe made up.
blk91coupe is offline
post #8 of 9 Old 11-08-2015, 11:21 PM
-Wraith-'s Avatar
Trader Feedback: (29)
Keep the compression you have, use e85, race gas, or meth. Build your own kit or buy a decent one, an s480 is capable of 1000+ to the wheels, with that cubic inch don't go any smaller than a t6 turbo with a 1.32 exhaust housing. And as far as hot side piping, 2.25" would be good, 3" for the cold side.
Just another slow mustang with a single turbo....
-Wraith- is offline
post #9 of 9 Old 11-08-2015, 11:38 PM
Fielder4.6's Avatar
I would look at the Pony down hotside kits. Either a s475 or s480 would be great.
Fielder4.6 is offline
Carb B/T Twin Turbo 302 Build Nutzz Turbochargers 7 03-27-2015 09:37 PM
Turbo Foxbody Build Fielder4.6 Member Build-Up Projects 5 02-26-2015 02:07 PM
Lund Twin Turbo kit Alpha X build duece212 S-197 Mustang GT (2011-2014) 10 06-24-2013 05:27 PM
Getting a turbo 95 gt, I need advice on this build SpeeDemon7 Turbochargers 25 04-21-2012 11:58 PM
On 3 Performance 2011 5.0 Single Turbo System / Shop Car Build On 3 Performance Turbochargers 28 11-28-2011 04:26 PM
