86 notch carb/fuel injection swap and on 3 install - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 11-02-2015, 09:28 AM Thread Starter
Trying to get a list of what i need to turn a carb 347 car into a fuel injection 302 turbo car. i know engine harness and ecm, do i have to change the dash and dash harness also? I know i need a tuner or have to get the car tuned. Just trying to gather everything i need.
lucas86notch is offline
post #2 of 4 Old 11-02-2015, 12:50 PM
Trader Feedback: (27)
just go blo thru carb. lot less hassle
broke again is offline
post #3 of 4 Old 11-03-2015, 08:23 AM
Cake...Just did this with an 83...All you need is the efi engine harness on the wiring side...I used a 92.5-93 harness just for simplicity sake, because the fuel pump relay is part of that harness already
Since the harness is basically standalone, all you need is to run power to a few places, couple grounds, and you are set.
I had a tough time finding a spot to mount the ECU, ended up trimming the rear of the glove box door and mounting it behind the dash
Your current dash harness doesnt need to be changed
Fuel system is up to you...i just used a stock efi tank and lines from an 86.
Some nickel and dime stuff...TFI dizzy, thottle cable, etc etc
slofox5.0 is offline
post #4 of 4 Old 11-15-2015, 08:44 PM
Don't forget a rear wiring harness if it doesn't have an in tank fuel pump. Just did one also, not bad at all.
55fbomb is offline
