5.4 DOHC TURBO!! PICS INSIDE - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 19 Old 10-31-2012, 06:28 PM Thread Starter
Here is the start of my build. Pics will be posted as I get them uploaded.
5.4 DOHC
Built shortblock mahler flat tops, Manley h beams With arp 2000 rod bolts, forged crank, h bearings, all arp hardware. Navigator heads cleaned up and gone through with Sean hyland dual race valve springs and retainers with 03/04 Cobra Cams
Sullivan Intake single blade accufab
Electric water pump
Sfi balancer
New tensioner and idler pulley
All brand new sensors and timing equipment
Moroso 7 qt aluminum pan
All covers powdercoated red, black (timing cover)
Fluidyne Radiator
SPAL electric fan
Brakes
Phils abs delete block
Aerospace engineering manual booster
New rotors and pads all the way around with painted red calipers
Suspension
Qa1 tubular k member
Eibach drag springs
QA1 adjustables in front
Qa1 adjustables out back
Full length sub frame connectors
UPR pro series suspension (double adjustables) with anti roll bar
No sway bars
Steering
Flaming River Manual Rack with Manual Steering Shaft
Wheels/tires
Matte Black Bullitts 315/35/17s out back
Transmission
PA supercomp C4
Sfi bell and flex
TCI pro x converter flashes at 4000 on the brake
Aluminum driveshaft with safety loop
Deep trans pan
Locking dipstick
Ratchet shifter underneath stock boot
Interior
Rear seat delete
SOS gauge pod
Electric oil pressure fuel pressure and trans temp, boost
AEM wideband
Exterior
3 inch cowl hood
Tinted
03/04 Cobra Front
Rear end
3.73 gears
31 spline strange axles with c clip eliminators
31 spline eaton trak-lok
Ta rear girdle
Fuel
Magnafuel Fuel Pump
80 lb injectors
Sullivan Rails
Return line system
Turbo Setup
Precision HP76GTS Billet Wheel 1.00 a/r
Tial 50mm BOV
Precision 46mm Wastegate
31 x 13 x 4 CX Racing Intercooler
Going for 1000 rwhp!
PICS AS PROMISED....
Complete Custom Kit made by Executive Performance in Merriam Kansas
2L8WIN2 is offline
post #2 of 19 Old 11-01-2012, 07:35 AM
Trader Feedback: (21)
Your wastegate looks like it is mounted vertical . I have 50mm progate and the instruction said that was worst ways to install because of exhaust flow.
02 Roush, Livernois stage 1 cams, eaton posi, qa1 kmember, highly modified on3 turbo kit
Turbo numbers 415 rwhp 458 rwtq
Stupidity is a sexually transmitted disease
CG hot side T6 turbo under way
sonic 02 is offline
post #3 of 19 Old 11-01-2012, 08:23 AM
89BlackGtVert's Avatar
Love it. Good work..
Sent from my PI86100 using Board Express
1989 GT Vert.. Major Changes for 2013 Wish me luck
Old setup from 2012 On3 Turbo, Trick Flow 170 Heads, Edelbrock RPM upper & Lower, Trick Flow Stg 2 cam, UPR K-member and control arms and Strang front and rear coil over, and UPR upper and lower rear control arms, MM frame connectors Fully Built AOD, 512whp
89BlackGtVert is offline
post #4 of 19 Old 11-01-2012, 09:20 AM Thread Starter
The guy building it has 20 years of building turbo cars and the wastegate is horizontal actually with the dump tube facing the back of the hotside. Its a pretty trick setup.
2L8WIN2 is offline
post #5 of 19 Old 11-01-2012, 02:59 PM
TWNWHR's Avatar
Thats pretty sweet. I think with all the air that engine can flow, that 76 is going to tap out pretty quick. Probably reach your power goal tho
Keep diggin!
GOOD FRIENDS DON'T LET YOU DO STUPID THINGS, ALONE
90 Trunkback 140k+ miles stock short block, Holley heads & Intake, stock cam, Faceplated 600, MS1, 72mm, Its ALIIIVE.
89 Notch 427W, PMS, some nitrous, a parachute, getting boost someday
67 Coupe, soapbox derby car
TWNWHR is offline
post #6 of 19 Old 11-01-2012, 03:44 PM Thread Starter
Yeah it may. I am going to upgrade to an 88 next year along with a TH400 and cams but wanting to get it together by the end of the month and try to enjoy it before it starts snowing. Progress is being made.
2L8WIN2 is offline
post #7 of 19 Old 11-01-2012, 04:19 PM
jarryd2018's Avatar
Keep diggin!
There are guys running 5.4s with smaller turbos than that. They aren't making 1000 hp, but they're putting up decent numbers. I plan to use a 76 to reach my goal of 700 hp. My longblock is almost identical to this one except I'm using I beams so I don't know that I'll be able to push it as hard as others are doing. I'll use H beams next time and up the boost.
2000 GT with o/r X, magnaflow catback, xcal 2, MGW shifter
4.6= dead
my 5.4 swap project https://forums.corral.net/forums/showthread.php?t=1220542
jarryd2018 is offline
post #8 of 19 Old 11-01-2012, 05:35 PM
Awesome....that 76 looks tiny next to that motor should be pretty nasty indeed.
ashJ is offline
post #9 of 19 Old 11-01-2012, 07:07 PM Thread Starter
As long as you have Billet I beams your going to hold more boost. None of my hard parts are going to break under the boost Im running. Turbo cars out of all types of boost are the easiest on hard parts.
2L8WIN2 is offline
post #10 of 19 Old 11-01-2012, 08:39 PM
jarryd2018's Avatar
I'm just afraid the I beams won't be as durable as H. They're also just forged not billet. The 4.6 version is rated for 500 hp, but I could get that without boost if I wanted so I don't know how hard I can push them. I'm sure I'll find out. Next block will be a 351 big bore with more head work and bigger cams.
To get the most out of this one I'm going to run e85 or meth injection to keep temps down.
4.6= dead
post #11 of 19 Old 11-02-2012, 12:49 AM
Manley Billet I Beams? They are 1500hp rated.
1999 Mustang Cobra MMR 1500 5.4 DOHC
898/779rwtq 14psi 17deg timing E85
Z06KILLR is offline
post #12 of 19 Old 11-02-2012, 07:54 AM
jarryd2018's Avatar
I just went with the forged ones. I wasn't originally planning on boost. I'll have it back out again at some point and I can upgrade.
Sent from my iPhone using Autoguide.com Free App
4.6= dead
post #13 of 19 Old 11-05-2012, 10:39 PM
I'm building a pretty similar setup now. Keep the thread updated, I book marked it. Lol. I have a 5.4 4v, P&P Navi heads, Sullivan intake, 96 Cobra cams, and doing a single 76mm as well. Waiting on pistons now.
SuperDan is offline
post #14 of 19 Old 01-23-2013, 04:27 AM
JOESBOSS's Avatar
I'm jealous of you yanks, our 5.4 falcons only have like 4 inches between our fan shroud and water pump pulley, so not turbo routing for us there. we got next to transmission of behind the headlights with battery relocation like this one
JOESBOSS is offline
post #15 of 19 Old 01-23-2013, 05:15 AM
Any update? This build looks amazing!!
post #16 of 19 Old 03-14-2013, 02:33 PM Thread Starter
New PICS
Had to modify the y pipe as there were issues with the exhaust manifolds. Everything is coated. The valve covers are going out to get gloss torch red paint thrown on them.
2L8WIN2 is offline
post #17 of 19 Old 03-14-2013, 03:22 PM
NightStalker's Avatar
Are you using stock manifold that are flipped or custom headers?
2002 Torch Red Mustang, V-6 turned 5.4L DOHC 307RWHP, Viper-spec 6-speed.
2003 Black Cobra, 2.8 pulley, JLT CAI, Flowmasters, Diablo tune, Daily Driver.
NightStalker is offline
post #18 of 19 Old 03-14-2013, 03:57 PM
Gearhead559's Avatar
i wanna see pics of the hydro boost clearance
Gearhead559 is offline
post #19 of 19 Old 03-14-2013, 07:34 PM Thread Starter
It's a navigator drivers side and cobra passenger side manifold.
The car doesn't have hydro boost. It's an aerospace engineering manual booster.
2L8WIN2 is offline
89 notchback 306, on3 turbo. Lots of pics. Raptor Jr Member Build-Up Projects 220 02-26-2016 11:39 PM
5.4 DOHC Turbo Build Inside... 2L8WIN2 SVT & DOHC 3 07-08-2012 09:06 PM
Want To Buy WANT TO BUY DOHC 5.4 PARTS ty.thompson1981 Modular Engine Parts 2 10-31-2011 01:24 PM
TDC DOHC info . . just recieved!!! BlackDemonGT GT & SOHC 36 12-16-2001 10:54 PM
