18" drag radial suggestions... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 42 Old 10-17-2012, 09:42 AM Thread Starter
2004 Mustang GT, should put down around 750 rwhp. Old turbo made 737 rwhp. It is a STREET car, but I would like it to hold traction at least in 3rd and 4th gear. Right now it has a tubular k-member, coil-overs in the front, KYB adjustable struts and shocks, Steeda lower control arms, both sway bars are still hooked up and they will remain hooked up as it is a street car. I have 3.73's out back for gears.
I am running a 18 x 9 up front and a 18 x 10 out back. Tires out back are a 315/30/18 Hoosier drag radial. The Hoosier's worked pretty good when they were new, but now I can spin them pretty easily in 3rd and sometimes 4th. I'd like a tire that can be driven in the rain if I get caught in it. I've ran M/T drag radials and Nitto drag radials on my old fox. They both did a good job, but this is a whole new ball game with the turbo car making some steam.
Let's hear some suggestions!
Thanks,
Tim
'91 GT: SOLD
'04 GT: Forged bottom end, MHS Stg 3 PI heads, Hi-Tech Custom Cams, MHS Vic Jr + elbow, custom turbo kit, Precision 7175, T-56 & 3.27's. 785rwhp/725rwtq @ 20 psi.
Macs Stang is offline
post #2 of 42 Old 10-17-2012, 10:12 AM
Trader Feedback: (33)
You can run the Mickey's, they're a lot better in the rain than the hoosiers (what isn't?), but traction isn't going to be any better.
If you want traction, for YOUR application I would look at a nice boost controller that does boost by gear. That should help you get the power down.
Also, changing to something like a 3.27 gear would help make that power more manageable.
1987 Saleen clone: 358cid, FoxLake Vic Jr's, Victor 5.0, YSi, etc, etc, etc
809rwhp on pump gas + meth injection
"Just turn the boost up.....it's only air."
tireburner163 is offline
post #3 of 42 Old 10-17-2012, 10:20 AM
Well there not nessisarily a drag radial
But the toyo r888 is a good competition tire with excellent wet traction
Proxes R888 | Toyo Tires
mstngcobra is offline
post #4 of 42 Old 10-17-2012, 11:15 AM
Also agree with him on the boost controller
U can get a good digital one that allows u to control boost based on rpm for when it on the street
Eboost2 is a good setup but they are 500 bucks
post #5 of 42 Old 10-17-2012, 12:02 PM
Toyo TQ's are the best drag radial I've run so far. My car will dead hook at any speed as long as the car is moving. Granted my 510 wheel isn't your 750 wheel, but I'm only running a 275 and not a 315.
MYSTICSVT is offline
post #6 of 42 Old 10-17-2012, 03:00 PM
lightblade's Avatar
Nitto 555R if you want decent mileage out of a good hooking tire thats not bad in the rain at all. A truely street friendly dr imho.
Mickey et street radials if you want more dry traction, but less wet and less mileage.
lightblade is offline
post #7 of 42 Old 10-17-2012, 03:21 PM
I had those on my car before the Toyo TQ's. The TQ's are better in every way. Wet or dry traction. They are even wearing pretty good.
post #8 of 42 Old 10-17-2012, 05:19 PM
lightblade's Avatar
I have driven on tq's they are definetly nice, my buddy has them on his turbo miata. I wasnt impressed enough to make a switch and they dont have them in the size Im looking for.
post #9 of 42 Old 10-17-2012, 10:01 PM
Robs4valve's Avatar
Trader Feedback: (31)
I've been planning on runing the 315/30/18 Hoosier drag radial as my next tire. So I'll be watching this one.
96 Mustang, 98 Teksid, Manly 11cc pistons, Manly H beam rods, 98v forged crank, ARP throughout, 01 C heads with a little exhaust porting, 98 cobra cams, 76mm PTK/custom turbo kit, ams boost controler, Snow stage 3 methanol injection, Rebuilt 4R75w controlled with a Quick1, Lentech valve body with transbrake, 3600 stall, bronze Volk TE-37 wheels and Micket Thompson's all the way around. Burns gas and rubber! Delta Force Tuned using Commando.
Robs4valve is offline
post #10 of 42 Old 10-18-2012, 10:21 AM
2002mustanggt's Avatar
You need 3.27 gear swap, 3.73 moving rpm way to fast. As for tires mt et street will give as good traction and good mileage .
2002mustanggt is offline
post #11 of 42 Old 10-18-2012, 01:46 PM Thread Starter
Would a tune change be required with swapping to a 3.27 since technically you are adding more load with the longer gear ratio?
'91 GT: SOLD
post #12 of 42 Old 10-18-2012, 02:11 PM
It will load better so you might have to add fuel , it will pull like mofo compare to 3.73 . Your speedo need to be adjusted too.
post #13 of 42 Old 10-18-2012, 03:51 PM
They definitely hook well. But a buddy of mine wiped his out in six months. That was only about 2K miles and two trips to the drag strip.
post #14 of 42 Old 10-18-2012, 05:06 PM
I think it depends on how you drive. I can usually get 6000-8000 miles out of a set of M/T's.
post #15 of 42 Old 10-18-2012, 06:42 PM
With dr you should drive like dr not like street car tires , take corner little slower and don't beat on the every time you drive then it will last. Mine got me good 8-10k out of them with tons of track use .
post #16 of 42 Old 10-18-2012, 08:04 PM
lightblade's Avatar
Mine lasted me a good while, 3 years around 6k street miles and 25-30 healthly 5-6 second burnouts at the track.
post #17 of 42 Old 10-18-2012, 09:06 PM
I am running the regular NT05 295 tires and the car holds in 3rd and 4th gear. 763 RWHP but also coil overs in the rear.
2003 OW Cobra Vert - Twin 57s, TH400, SRA
2013 Escape - 2.0 EcoBoost
2014 Honda Accord - Dat MPG Doe
2002 MG GT Vert - SOLD
Joyrider564 is offline
post #18 of 42 Old 10-18-2012, 10:27 PM Thread Starter
Interesting, the car already hauls the mail very well. Gave me tunnel vision the first time I went for a ride in it...I have sct pro racer software, so adding fuel is no problem. I also have new axles and a diff waiting to go in. Maybe I can convince my neighbor to put some 3.27's in it once spring time comes around.
'91 GT: SOLD
post #19 of 42 Old 10-20-2012, 11:00 AM
It will be different animal , pulls never ends
post #20 of 42 Old 10-21-2012, 01:27 PM
pkstang's Avatar
Trader Feedback: (161)
how many miles did they last?
i just installed them on my car (we're making similar power) and love them. i've also had great results with the NT05Rs. on the street that is.
x2. i changed from 373s to 331s (can be found all day long on ebay in like new condition) and it was a huge difference. my 550 tune felt like the old 650 one.
pkstang is offline
post #21 of 42 Old 10-22-2012, 01:04 PM Thread Starter
They were on the car when I bought it. The tires were about a year old. I couldn't hold traction at the top of 3rd gear. I took them off this weekend and replaced them with some used Toyo drag radials that the previous owner had. The Toyo's are in the same boat, they spin, but I haven't lowered the tire pressure down yet to see if they actually work.
I might have to toss in the longer gears...it would be nice to be able to hammer the gas and be able to feel the power for longer then a second or so. LOL
'91 GT: SOLD
post #22 of 42 Old 10-22-2012, 02:37 PM
Cammed 2V GT's Avatar
I had a toyo proxis tq 315 35 18 on a 10in wheel on my 04 gt. By far the best tire ive ever owned. Dead hooked on the street and track and did great in the rain. I got more than 8k miles out of them even with dozens of passs and smokey burnouts.
A little cam is like a little d**k, every time you go to use it you wish it was bigger.
98 cobra. V2si 466/425
Cammed 2V GT is offline
post #23 of 42 Old 10-22-2012, 06:19 PM
quicktime's Avatar
Trader Feedback: (136)
not trying to hijack this thread at all,some good info here..i'm looking for a set of STREET tires 335/30/18 does anyone make that size tire in a compound that will last 15000 or more? no racing,just occasional getting on it with around 550 rwhp..mostly cruising ,..this is on a 18-11 wheel..thanks for any info
quicktime is offline
post #24 of 42 Old 10-22-2012, 06:29 PM Thread Starter
What suspension do you have? My car is slammed pretty good, so I know that hurts the hook, but anything is better then nothing if a tire can help the hook!
'91 GT: SOLD
post #25 of 42 Old 10-22-2012, 06:43 PM
Pirelli P-Zero. I used to run them. They are expensive but they lasted about as long as you're looking for.
04 Mach 1 SHM Race Heads, Stage 3 Cams, Daytona Prototype Rotating Assembly, Kenne Bell 2.2
Steele is offline
post #26 of 42 Old 10-22-2012, 08:47 PM
I use BFG Drag Radials. I'm working on sub 50mph traction (just lowered the psi to 20) and will test some more as its hit or miss depending on the temperature outside.
1999 Mustang Cobra MMR 1500 5.4 DOHC
898/779rwtq 14psi 17deg timing E85
Z06KILLR is offline
post #27 of 42 Old 10-29-2012, 12:23 AM
Change to 3.27's. Then see how things change. If its still not hooking, try a diff drag radial. You WILL enjoy the 3.27's.
You could also pick up another set of rims and run a set of more aggressive DR's on there when you want to play and run something like the R88 or NT05 for regular street use.
stangboy460 is offline
post #28 of 42 Old 10-29-2012, 01:39 PM Thread Starter
I think the gear swap is already planned for the spring. Just have to talk with my drivetrain guy to set it up. This thing has zero traction right now with the 3.73's, so I think the switch to a 3.27 will probably be the best bet.
I'll be curious to see what it does to the tune. Might have to add a little fuel here and there to make up for the added load.
I have the Toyo Proxis TQ's on the car right now. I can shred them easily in 3rd gear and 4th if I build boost quick enough.
'91 GT: SOLD
post #29 of 42 Old 11-02-2012, 12:10 AM
quicktime's Avatar
think i'm going to try those Nittos..heard they can last up to 10,000 if not crazy on the burnouts,etc wonder who has the best deals on 335/35/18's?
post #30 of 42 Old 07-31-2014, 01:05 PM Thread Starter
Bringing this one back from the dead...
I have since changed to 3.27's.
I have to put a few more miles on the new build before I start getting crazy with WOT pulls.
I am going to see how the Proxes TQ's do, then I will decided if I am going to switch to a different brand DR. I have had thoughts about switching to the R888, but really haven't heard any opinions on them for 700+ rwhp.
'91 GT: SOLD
post #31 of 42 Old 08-01-2014, 12:50 PM
I have since gone to the 315 NT05R. 1st gear on the street spins, but not ridiculously. 2nd gear just hooks and goes.
post #32 of 42 Old 08-01-2014, 06:12 PM
badcobra over on SVTP runs R888's on his 950whp Cobra.
'01 GT - sold
'05 CVPI - DD
'00 GT - Broken
Gravik is offline
post #33 of 42 Old 08-03-2014, 11:34 AM
BlowThisRacing's Avatar
I have 275 NT05's on a 18" wheel under my fox and they don't hook on the street for nothing. Hoping to have better luck at the track. I have 355 gears on 11psi of boost. It will burn 1st, 2nd, and 3rd.i can punch it in 3rd from a roll and will still spin some when the boost hits. I know if I changed to a 327 or 331 gear it would be better but I'll go to MT ET streets when the nittos wear out. The MT's you don't get miles out of them but they hook like hell for a DR. My car is a weekend driver so mileage isn't a big issue
1991 Mustang GT
302, 170 TFS heads, TF track heat intake, turbonetics 60mm turbo, pro force built T-5, Kurgan Tune
BlowThisRacing is offline
post #34 of 42 Old 08-04-2014, 01:04 PM Thread Starter
Link or is he on here?
'91 GT: SOLD
post #35 of 42 Old 09-18-2014, 06:59 PM Thread Starter
Anyone have any experience with the R888's in a 315/30/18?
Now that the car is tuned I can report that 1st & 2nd gear spin once boost comes on. 3rd and 4th gear hook. This is with a Proxes TQ in a 315/35/18.
'91 GT: SOLD
18" drag radial suggestions Macs Stang Wheels and Tires 2 10-17-2012 05:40 PM
Hoosier Drag radial vs. MT drag radial racer2fast Drag Racing 18 08-07-2011 11:04 AM
18" Drag Radial Recommendations billyNOTnice Wheels and Tires 6 07-31-2011 02:25 PM
Tire recomendation Nitto extreme drag radial or BFG drag radial Torino390 GT & SOHC 8 01-09-2002 01:45 PM
