3.55 gears for turbo mach? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 10-15-2012, 08:32 PM Thread Starter
would 3.55's be my best choice for a 5 speed mach with 28" tall tires? I heard that it should be more like a 3.27 gear with the 28"s. is this true?
ToFastCalypsoCoupe is offline
post #2 of 8 Old 10-15-2012, 09:13 PM
Yes
] /Freezy cam/ Dart 331 / Hellion heat / Precision 7675/ PRO-M EFI
JOHN 86GT is offline
post #3 of 8 Old 10-16-2012, 09:35 AM
Trader Feedback: (33)
3.55's will be fine, especially with a mod motor. I think people get a little carried away waving the "3.27 or Die" flag.
My car has 3.27's in it and runs faster on 26" tires and 28" tires.
1987 Saleen clone: 358cid, FoxLake Vic Jr's, Victor 5.0, YSi, etc, etc, etc
809rwhp on pump gas + meth injection
"Just turn the boost up.....it's only air."
tireburner163 is offline
post #4 of 8 Old 10-16-2012, 11:12 PM
I'm current running a 3.73 with a 26" tall tire and it rips pretty good. I'd bet a 3.27 or 3.55 would probably be best as I can destroy the 315/30/18 Hoosier drag radials from a 3rd gear roll once boost comes on (haven't tried brake boosting yet). 18 psi from a 7175 precision turbo shoving air into a little 4.6L will do that though.
'91 GT: SOLD
'04 GT: Forged bottom end, MHS Stg 3 PI heads, Hi-Tech Custom Cams, MHS Vic Jr + elbow, custom turbo kit, Precision 7175, T-56 & 3.27's. 785rwhp/725rwtq @ 20 psi.
Macs Stang is offline
post #5 of 8 Old 10-17-2012, 05:19 PM
S1ten's Avatar
3.55's may be a good choice as long as you can keep your foot planted and the tires hooking. 3.73's would most likely ensure crossing the traps (1/4 mi) closer to my peak HP but, I think 3.27's will be overall better for a mostly street driven turbo car. I'll let you know first hand soon.
[B]S1ten
2001 Saleen 281 SC #0174
CG Fab TT Kit w/PT 5858 CEA Turbos, Patriot Stg II Heads prepped by MHS, Bullet/MHS Stg II Turbo Cams, MMR 900 Short Block, Edelbrock Intake, 6061 Plenum, Lethal Return Style Fuel System, Siemens 80lbs injectors. 747WHP/691TQ @ 22lbs
S1ten is offline
post #6 of 8 Old 10-17-2012, 07:13 PM Thread Starter
I hope to find out myself next week!
post #7 of 8 Old 10-17-2012, 11:29 PM
y2k02's Avatar
I run 3.27 gears.
2002 2V TF heads Custom Edelbrock NA SVT Cams
Twin 6466 TH400 Dominator EFI TH400 UCC
y2k02 is offline
post #8 of 8 Old 10-18-2012, 10:02 AM
I have 3.73's and dislike them. I run 4th out to quick and then catch 5th and it's pure dog####. I'm betting if I ditch the 3650 and went t56 the 3.73's would be nicer...
burkej62 is offline
For Sale 3.55 gears for 8.8" rear - Used MustangResource Drivetrain Parts 4 04-19-2012 10:49 AM
For Sale 3.55 final drive gears out of a 03 Mach 1 WooMach Modular Engine Parts 0 12-17-2011 03:17 PM
For Sale Ford Motorsport 3.55 gears and 28 spline limited slip differential irwinner Drivetrain Parts 6 09-02-2011 03:51 PM
Want To Trade FRPP 4:10 gears for FRPP 3.55 gears Bullitt5566 Drivetrain Parts 1 12-12-2010 01:13 PM
