327 On3 turbo build - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
  • 1 Post By t32265
post #1 of 16 Old 10-11-2012, 12:24 AM Thread Starter
wytwolf's Avatar
327 On3 turbo build
Ok turbo folks, here it is. I'm starting my build. Dart Iron Eagle(all 5 mains 4 bolt)8.2" deck, 4.00" bore, Eagle 4340 3.25" crank, Eagle 4340 H-beam 5.4" rods, pistons TBD, 70cc Vic Jr. heads 2.05/1.60, cam TBD, Vic EFI intake, 90mm TB, On3 76mm ball bearing, billet wheel upgrade kit, w/60lb. injectors, PMAS MAF, 340lph fuel pump, so on and so forth.
Car is an '89 Coupe. Currently 302, GT40 irons, Edelbrock Performer intake, E-cam, 70mm TB, 150 shot NOS, WC T-5, 3.73.
Just dropped block, crank, and rods off for machining, etc. Updates to follow. Hoping for great results. Going in open minded. Have read good and bad reviews regarding On3. I dealt with Power Adder Solutions and was very pleased with my customer service. One part(BOV, I think) was backordered, but received in a couple weeks. 6 months later, it's still in boxes, lol. I'm only looking to achieve small things considering the hardware, but 600+RWHP for a daily tune would make me happy.
We'll see.
http://i233.photobucket.com/albums/e...8/IMG_0090.jpg
http://i233.photobucket.com/albums/e...8/CIMG2438.jpg
wytwolf is offline
post #2 of 16 Old 10-11-2012, 09:51 AM
600 RWHP will be easy with that combo.
MYSTICSVT is offline
post #3 of 16 Old 10-11-2012, 04:39 PM
M88handles's Avatar
Trader Feedback: (115)
I'm looking to build roughly the same thing this winter. 327, afr 185 72cc, turbonetics 7268, Glenn's fuel system, etc.
Will follow your build to see how you do. Good luck
91 Dove Grey coupe, Tennessee Transmissions Built AOD, 3.73's, BBS RK's, Full Team Z Suspension, H/C/I. V3-SCI, r134 AC/PS/PW/CC
[email protected] 1.70 60' foot braking 2300rpm.........................SOLD
"If your broke...or enjoy lowballing and wasting time, your likely on the wrong post"
M88handles is offline
post #4 of 16 Old 10-25-2012, 10:07 PM
Madspeed's Avatar
sounds good, get her done and post up pics. I'm planning a single turbo for my stock block 333. Suppose I should get the 76mm?
Shameless plug.... My Business
Use coupon code MADSPEED for a 20% discount!!
Madspeed is offline
post #5 of 16 Old 10-26-2012, 10:02 PM
nasty92lx's Avatar
the 70 will blow it up nice and proper. hell a 67 would too. i have a mp 70 on my car works great spools quick i love it.
nasty92lx is offline
post #6 of 16 Old 10-29-2012, 07:30 PM
flashman's Avatar
We'll see.
Why would you put a 1500 dollar turbo kit on a 8000 dollar motor.
89 coupe- some parts
best time-11.67
best mph-120.57
best 60 ft-1.63
flashman is offline
post #7 of 16 Old 11-01-2012, 04:57 PM
89BlackGtVert's Avatar
We'll see.
I bought all my stuff from Chris also. Get the on3. you will hit your goal no Problem. Get the bigger turbo though. Or none at all and upgrade it.
1989 GT Vert.. Major Changes for 2013 Wish me luck
Old setup from 2012 On3 Turbo, Trick Flow 170 Heads, Edelbrock RPM upper & Lower, Trick Flow Stg 2 cam, UPR K-member and control arms and Strang front and rear coil over, and UPR upper and lower rear control arms, MM frame connectors Fully Built AOD, 512whp
89BlackGtVert is offline
post #8 of 16 Old 11-01-2012, 10:42 PM
mghoward74's Avatar
If a 340 pump an 60's are all you got, it might be hard to make 600 rwhp.
Are you running fuel rails? bigger lines coming from the tank? Etc.
mghoward74 is offline
post #9 of 16 Old 11-02-2012, 03:41 AM Thread Starter
wytwolf's Avatar
That's what I have right now. It's no going to support 600+, no. I'm currently working on piecing together a "real" fuel system. It will be(at the minimum) dual 340s, but more likely just go with A1000. Like to do full Aeromotive system, but will see how the budget works out. Either way, yes, all those things are being addressed. Can't wait to get it all together and actually work on making some meets/races.
wytwolf is offline
post #10 of 16 Old 11-02-2012, 03:19 PM
mghoward74's Avatar
Look at glenns peformance or BBRC ( behind bars race cars )
Good luck
post #11 of 16 Old 11-03-2012, 09:11 AM
M88handles's Avatar
I didnt want to piece anything together or have to chase down little odds nd ends So This is what i picked up to run 550ish. Says its good to 600 but im not looking to push it that far. It can be upgraded later should it be needed. Also running 60lb injectors. Almost done collecting all the parts to start the winter build.
Glenn's Performance
GP 600HP Mustang Sleeper Tank Fuel System (1979-1997) Glenn's Performance
post #12 of 16 Old 11-03-2012, 02:47 PM
vrnnrchrdsn's Avatar
Can't wait to see the pictures from the build. I hope one day soon to be doing a build close to what you are doing.
vrnnrchrdsn is offline
post #13 of 16 Old 11-05-2012, 08:48 AM
I have 600hp Flywheel. with 60's and a 340 PAS pump. And the cheap Professional Products fuel rail with gauge. It actually was a nice piece. The rest of system is stock.
Sent from my PI86100 using Board Express
post #14 of 16 Old 07-07-2017, 09:32 AM Thread Starter
wytwolf's Avatar
Ok, 5 years later and I'm still trying to get this thing together! Here's where it's at:
Dart Iron Eagle Block, 4.030"
Eagle 3.25" forged crank
Eagle 5.4" forged rods
Probe 2618 Forged, flat top pistons
AFR 205cc, 72cc chamber heads
Custom FTI turbo cam, valve spring, timing set
Edelbrock Vic Jr EFI intake with elbow
80mm Holley Throttle Body
Treadstone T4 hotside
Turbonetics T4 midframe HP76mm turbo
On3 coldside
Aeromotive A1000 fuel system, also have Pro Series Pump
80+ lb/hr injectors(TBD)
UPR tubular front suspension w/coilovers
UPR pro series rear suspension w/antiroll bar and coilovers
8.8" rear w/3.27 gears
Lentech strip terminator AOD.
Tuned with Holley HP EFI
Just trying to build a healthy street car with 9 sec. potential. Some things aren' exactly matched, I know, but let me know what you think. Tried to source parts to support more HP that I want in order to build a (fairly) big power car that will be reliable. As I said, looking for 6-700whp/9 sec capable car that I can drive fairly regularly. Comments/questions, suggestions all welcome.
wytwolf is offline
post #15 of 16 Old 07-07-2017, 10:27 AM
Trader Feedback: (21)
Looks like a healthy combo. I have a friend that pieced together a HCI stock lower 351 with leftover turbo parts, through a home built C4, ran multiple 8.8X in the 1320.
For everything that is worthwhile, there is a counterfeit.
boostup89 is offline
post #16 of 16 Old 07-09-2017, 07:54 AM
t32265's Avatar
should have went 4.1225 on the bore left a lot on the table for no cost difference a the time. should run great though.
wytwolf likes this.
t32265 is offline
For Sale PAS Power Pack: On3 Performance Foxbody Turbo Kit w/Precision Turbo Upgrade *SALE* PowerAdder Solutions Power Adders 41 07-09-2013 06:37 PM
DIY turbo build on 87 GT MJs89GT Member Build-Up Projects 64 06-27-2013 03:18 PM
For Sale 94-95 Upgraded On3 Turbo kit AJs94cobra Power Adders 11 10-20-2012 02:07 PM
For Sale 86-93 on3 turbo kit complet for sale..plug an play. 331lilcoupe Power Adders 7 05-29-2011 08:55 AM
89 coupe On3 blowthrough carb turbo build cbibb Turbochargers 16 02-28-2011 01:56 PM
