Wideband shows LEAN on two step. Normal? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 15 Old 08-31-2012, 08:07 PM Thread Starter
Just got my two step working today and noticed the my AFR is buried on the lean side when on the two step limiter. Is that normal, or should I be concerned? I also noticed that I occasionally get a backfire when using it.
MYSTICSVT is offline
post #2 of 15 Old 08-31-2012, 08:41 PM
nasty92lx's Avatar
Mine goes lean too and it backfires through the exhaust and that's super loud. I think that's normal. Haven't launched the car with the two step yet cause I haven't had time to get to the track in like 2 months. But when it starts backfiring it starts makin boost with a quickness!
nasty92lx is offline
post #3 of 15 Old 09-01-2012, 12:12 AM
It's normal, they sound like a machine gun going off.
Turbocharged 87 GT T Top
XBL Tag: Mikemachine812
MJs89GT is offline
post #4 of 15 Old 09-01-2012, 01:56 AM
All normal. You are throwing a bunch of air and fuel down the pipe.
Journeyman is offline
post #5 of 15 Old 09-01-2012, 09:09 PM
Trader Feedback: (22)
if the car is loading up thus making boost and your a/f is showing lean then thats never good. it is however a good way to melt a piston
03 Mustang GT
Turbo 2v
LS1KILR is offline
post #6 of 15 Old 09-02-2012, 01:01 PM
What??? The car is showing a false lean because he is sending unburnt fuel into the exhaust. It is perfectly normal.
chiaj144 is offline
post #7 of 15 Old 09-02-2012, 01:17 PM
what kind of 2 step? MSD or sct xcal 2 step? guessing a msd type 2 step. does it cut fuel or air?
2000 gt bright atlantic blue, 5 speed, procharger, built motor, cms stage 2 cams, lee blankenship tune, 430/405.
mustanginky is offline
post #8 of 15 Old 09-02-2012, 01:50 PM
bottlefedgt's Avatar
spark
PM me for BILLET SHIFT FORKS! Currently made for T45,3650(all of them) ,and now the T56
bottlefedgt is offline
post #9 of 15 Old 09-02-2012, 03:37 PM
Trader Feedback: (41)
Actually it is unburnt oxygen. Oxygen sensors measure oxygen, not fuel.
stangjumper is offline
post #10 of 15 Old 09-02-2012, 11:09 PM Thread Starter
My two step is with an MSD 6 Programmable box. So it is normal?
post #11 of 15 Old 09-02-2012, 11:18 PM
Anytime you cut the spark you will get a false lean reading. 100% normal.
post #12 of 15 Old 09-03-2012, 12:50 AM
Trader Feedback: (33)
Not even close to correct.
As mentioned already, you're getting a false lean reading due to the two step cutting spark and lots of unburned fuel going out the exhaust.
1987 Saleen clone: 358cid, FoxLake Vic Jr's, Victor 5.0, YSi, etc, etc, etc
809rwhp on pump gas + meth injection
"Just turn the boost up.....it's only air."
tireburner163 is offline
post #13 of 15 Old 09-10-2012, 04:24 PM
When I was referring to fuel I meant unburnt combustion, which is both fuel and oxygen. Guess I should have been more specific.
chiaj144 is offline
post #14 of 15 Old 09-10-2012, 06:03 PM Thread Starter
Wouldn't unburnt combustion basically be raw fuel. To which the wideband would read as uber rich?
post #15 of 15 Old 09-11-2012, 11:32 AM
Widebands don't even know what raw fuel is, it's the oxygen they read. If it's raw fuel... it's raw air, so it reads lean.
MJs89GT is offline
Project Plasti Dipped New Edge CONVertIBLE Topless04GT The Body Shop 34 06-29-2013 05:48 PM
vacuum leak hints, or running lean rockspyder 5.0/5.8 Engine Tech 26 11-15-2011 10:23 PM
is it normal for your car to go lean when hitting two step?? mkrantz1106 Turbochargers 7 09-05-2011 05:12 AM
Nitrous 3v redmustang83596 Nitrous 7 08-25-2011 12:39 AM
need help: step by step holley DP tunning. sefi 5.0/5.8 Engine Tech 29 01-18-2011 11:43 PM
