1993 Cobra Dart 347 Hellion Kit Precision T-76 Build - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 73 Old 08-27-2012, 08:46 PM Thread Starter
PowerAdder Solutions's Avatar
Trader Feedback: (230)
Thumbs up 1993 Cobra Dart 347 Hellion Kit Precision T-76 Build
Hey Guys, This long time build finally is up and running I wanted to share my personal street setup. We here at Power Adder Solutions appreciate your support and look forward with future success with your ride and supporting.
Finished up most of the build at the shop, Here are some pics..
Thanks,
[email protected],Inc.
Hellion Power Systems: First Gen Kit Precision 7675 Billet Turbo
Dart SHP 347 Big Bore (Custom By Mark K) Pro 5.0/NMRA Engine Builder
Trick Flow Twisted Wedge 185 CNC Heads Spring Upgrade 650'
Holley System Max Intake
Camshaft: Custom (Cam Motion)
Siemens Deka 60 LB Injectors
Astro Built T5 (Upgrading Soon)
Fuel System: Weldon Pump Custom (Coming Soon)
Turbosmart 50mm BOV
Turbosmart Hyper-Gate 45mm Wastegate
Tuning: Binary Editor (BE 2012) Quarterhorse PAS Pack Tuning Solution.
Previous pic's..
Dart 347 Big Bore 4.125 Bore Cleaning And Machining.
TFS Twisted Wedge 185 CNC Doing Some Work
Just got the turbo back from polishing..Enjoy,
Billet Wheel:
post #2 of 73 Old 08-27-2012, 08:52 PM Thread Starter
Remflex Gaskets
Remflex Gaskets Preferred Choice With Turbo Applications.
post #3 of 73 Old 08-27-2012, 09:02 PM Thread Starter
Jet Hot Finish More
post #4 of 73 Old 08-27-2012, 09:10 PM
johnny turbo5.0's Avatar
Great build Chris !
95gt stock
johnny turbo5.0 is offline
post #5 of 73 Old 08-27-2012, 09:12 PM Thread Starter
Start Up Base Tune
post #6 of 73 Old 08-27-2012, 09:15 PM
89BlackGtVert's Avatar
Love it!! Nice work! How much power this bad boy making? Man wish I wasn't still on this crappy stock block..
Sent from my PI86100 using Board Express
1989 GT Vert.. Major Changes for 2013 Wish me luck
Old setup from 2012 On3 Turbo, Trick Flow 170 Heads, Edelbrock RPM upper & Lower, Trick Flow Stg 2 cam, UPR K-member and control arms and Strang front and rear coil over, and UPR upper and lower rear control arms, MM frame connectors Fully Built AOD, 512whp
89BlackGtVert is offline
post #7 of 73 Old 08-27-2012, 09:21 PM
Spotless Cobra!
Have you had any tuning glitches with the intake tube going from 3 inch to 2 1/2 '' to 3 inch? (i was thinking of using a new 3 inch pipe)
How much boost are you going to run and HP goal?
] /Freezy cam/ Dart 331 / Hellion heat / Precision 7675/ PRO-M EFI
JOHN 86GT is offline
post #8 of 73 Old 08-27-2012, 09:34 PM Thread Starter
Thanks! Shooting for 700 ish once the fuel system is finished next month, I will keep you guys posted, glad to have it running I will be doing some tutorial videos BE tuning for users to help shed some light.
post #9 of 73 Old 08-27-2012, 10:18 PM
Formerly eades5.0
4Jenna's Avatar
Beautiful bud!
-Chris
WWW.JENNABEARSFOUNDATION.ORG
4Jenna is offline
post #10 of 73 Old 08-27-2012, 10:49 PM
Keep up the good work.
boosty is offline
post #11 of 73 Old 08-28-2012, 09:06 AM
ACJ
ACJ's Avatar
Nice Build Chris ! I'm still getting my coins in order .
ACJ is offline
post #12 of 73 Old 08-28-2012, 10:16 AM Thread Starter
Originally Posted by JOHN 86GT View Post
Spotless Cobra!
Maf signal looks good, no tuning issues with the configuration Ideally it is best to have the same tube size but not really needed for the setup I personally wouldn't worry with it. Street tuning now once get it back on the dyno were hoping 650-700 Rwhp with 18-20psi guesstimating.
Thanks,
Chris.
post #13 of 73 Old 08-28-2012, 10:18 AM Thread Starter
Sounds good, just let me know I look forward to your swap for sure..
post #14 of 73 Old 08-28-2012, 10:57 AM
looks good.....can't wait to see what the numbers are
Tommy1005 is offline
post #15 of 73 Old 08-28-2012, 11:17 AM
XH5LWEPN's Avatar
Awesome build! Great pics!
Look forward to seeing how you go once fully tuned!
Australian 5.0L Utility, Fordstrokers 363ci, 9.2:1, RHS 180cc Alloys, KB 2.1L A2A build in progress!
XH5LWEPN is offline
post #16 of 73 Old 09-02-2012, 10:04 AM
XH5LWEPN's Avatar
Originally Posted by PowerAdder Solutions View Post
Is there a 3rd piece to these manifolds? A flex joint with a bend or something?
XH5LWEPN is offline
post #17 of 73 Old 09-02-2012, 10:43 PM
I have a very similar combo. 1st gen hellion, precision billet 76,world 363, afr165, TKO600. Made 680ft.lb at 4200 and was pulling to 650wrhp at 14 psi. You should have no trouble reaching you goals!
Keep track of your AIT's and report back. My temps on 1/4 mile passes are a little warm, wondering if it's due to to small of turbo or Intercooler.
racerryan is offline
post #18 of 73 Old 09-03-2012, 10:38 AM
93alexcoupe's Avatar
Looks very nice!! At that boost level it make more than your goal.
Built by Lujan Motorsports
Boss 308ci BullseyePower Turbo, ProEfi.
93alexcoupe is offline
post #19 of 73 Old 09-03-2012, 04:48 PM Thread Starter
Thanks guys, yeah I am estimating low I know.. there a couple things on the first gen kit I'm not crazy about personally, but did not want to cut any where on this car which luckily I did not have to with the first Gen Hellion Kit, 3" piping would of been a plus but overall good system, we should have a few base pulls in the next few week I'll post some numbers.
Thanks,
[email protected],inc.
post #20 of 73 Old 09-03-2012, 04:53 PM Thread Starter
These is the cross over pipe, but not in this picture there is no flex joint used with the system.
post #21 of 73 Old 09-03-2012, 05:00 PM Thread Starter
Thanks for chiming in, I have tuned many Hellion Kit's with the Tnetics, but look forward to see how we do with the Precision setup, great numbers..I have noticed with the first gen kit the AIT are on the high side I have seen several cases of this.
Any work done to your 165's ?
Thanks,
post #22 of 73 Old 09-03-2012, 05:55 PM
I bought them years ago when the car was bone stock and was too cheap to replace them. I had them cleaned and setup to match the cam. Same story with the intake. It's a street heat TF and the power nose dives at 6000. New heads and box R the car would easy add a hundred rwhp and 500 rpm.
Is 175f for ait normal then for this combo at end of 1/4 pass?
post #23 of 73 Old 09-03-2012, 06:00 PM
And gorgeous car!
post #24 of 73 Old 09-09-2012, 07:15 PM
jcg9777's Avatar
Trader Feedback: (51)
Hey Chris, Are those Remflex Gaskets better than using the RTV? I have had issues with my Turbo side header leaking at the rear of the head. If so, who do you recommend I buy them from?
1991 Coupe: Dart Sportsman 331, AFR205's, Holley Systemax, Hellion T76 turbo kit, TKO, PMS and other extras.
1993 Cobra: 52K, Black/Grey cloth #4740, SOLD
jcg9777 is offline
post #25 of 73 Old 09-09-2012, 11:11 PM
Thanks,
just to help piggy back..with my 336, AFR185's and Comp 76, I made 789/845 on E85 @ 17.8 psi....
'18 Charger Hellcat
chinopsu is offline
post #26 of 73 Old 09-10-2012, 03:02 PM Thread Starter
We have had real good luck with them, I have a lot of guys using header studs or locking bolts with the Remflex's doing well, the trick is to evenly torq them down best you can keep in mind they are fairly thick. We stock them let me know if we can help.
Thanks,
Chris.
post #27 of 73 Old 09-10-2012, 03:11 PM Thread Starter
With this kit specifically, I have seen temps in that range we may try a intercooler swap sometime in the future.
post #28 of 73 Old 09-10-2012, 07:59 PM
Do you have a specific Intercooler in mind?
1993 Mustang LX 363 World/Scat Stroker, 76mm Precision Billet Turbo, AEM Series 2, g101a, afr205, box r, and solid roller! [email protected] Best MPH 158
post #29 of 73 Old 09-30-2012, 08:31 PM
Any updates?
Is there a problem with your site ? My computers block it (says it is unsafe?)
post #30 of 73 Old 10-01-2012, 10:03 AM Thread Starter
Any updates?
Shouldn't be, we are working on a new site currently but shouldn't reflect it, maybe your settings. No numbers yet we have been swamped and I have not had much time to do anything, I want to get the fuel system completed first though.
post #31 of 73 Old 10-18-2012, 09:42 PM
do you think the block will handle 20lb of boost with no problem?
a1automotive1 is offline
post #32 of 73 Old 10-18-2012, 11:18 PM
Draggin90's Avatar
Trader Feedback: (29)
That block will handle 1200+rwhp.
Draggin90 is offline
post #33 of 73 Old 10-18-2012, 11:24 PM
Not a shp block.
post #34 of 73 Old 10-19-2012, 10:18 AM
an SHP will handle a lot more than Dart says it will......some builders will say if you break it at less than 1000 they'll warranty it. I think Dart says it's good for 600, which is way under on what it really handles, they just under rate it so they can sell more iron eagles to people who don't know better.
post #35 of 73 Old 10-19-2012, 10:34 AM
blownholley50's Avatar
Trader Feedback: (28)
Ive been pushing 1100+ all year w an shp. Great block and its the last thing I'm worried about!!
WestTexasMeanStreet-
93 LX Hatch F1A-94 ,363, Freezy, XFI-/[email protected]/[email protected] 5000'DA
Harlow Sammons,Southwest Perf. & Machine
YouTube Page- www.youtube.com/user/blownholley50
blownholley50 is offline
Tags
hellion power systems, hellion turbo system, power adder solutiions
For Sale 1993 Ford Mustang Cobra Teal/Black - Amazing Car, Check it out. Mustang9 Mustangs For Sale/Wanted, 1987-1993 78 09-26-2011 11:14 AM
For Sale MM 93' Cobra Master Cylinder, install kit and fittings, Wilwood Prop Valve Blue91LX Suspension 3 08-20-2011 12:48 AM
1993 Cobra build advise mustangnumber6 5.0/5.8 Engine Tech 6 04-04-2011 10:22 PM
FS 1993 Real OEM Cobra Body Kit $1000 CMCRacer302 Exterior Parts 10 03-24-2007 02:59 AM
