2 steppin question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 08-13-2012, 10:31 PM Thread Starter
mw95gt's Avatar
2 steppin question
Was wondering who is using a 2 step with there turbo for launching? I recently put one on thinking it would be easier to stage the car being I can just put the peddle to the floor when staged rather than having to watch the tach and the light. However I was wondering or thinking it would be harder on the motor meaning risking popping a head gasket because it's basically loading cylinders with fuel and igniting every other or so. Do I have anything to worry about?
95gt Dart block 363, TEA 205 Heads. 78MM Turdblower Custom cam, All fab work done by me....Moates tuned by me, AODE done up, yep I got overdrive. Drag radials, 327 rear. Next setup to come over winter...lol
mw95gt is offline
post #2 of 8 Old 08-13-2012, 11:07 PM
sweat90lx's Avatar
I have never used mine but I dont think it that rough on the motor as long as you are not on it a long time. it will create heat very quick but nothing I would worry about for only a few seconds
12.7s motor, 11.7s spray, turbo 400/460. [email protected]
sweat90lx is offline
post #3 of 8 Old 08-16-2012, 07:53 PM
lightblade's Avatar
The 2 step cuts timing so its perfectly safe. Get a wot box it has a 2 step, no lift shift(lets you keep the pedal to the floor and cuts timing when it senses the clutch go in making power shifting easy as butter and less wear on the trans) also has a spark rev limiter vice the oem fuel cut limiter which is safer, shift light features, window switch for meth or nitrous etc.
N2MB Racing
lightblade is offline
post #4 of 8 Old 08-16-2012, 11:19 PM
pkstang's Avatar
Trader Feedback: (162)
N2MB Racing
how was it to install/wire?
pkstang is offline
post #5 of 8 Old 08-18-2012, 08:19 AM
lightblade's Avatar
Easy comes with great instuctions and support Jon always got back to me with questions in a timely manner.
post #6 of 8 Old 08-18-2012, 05:17 PM
Baznasty Dave's Avatar
How much boost are/can you guys build off the 2 step?
305/333 WHP/WTQ with CMS Stage II Cams
440/552 WHP/WTQ on Nitrous
7.86, @ 89.1mph, 1.61 60 foot, on Motor
7.15, @ 98.8mph, 1.55 60 foot, on Spray
Baznasty Dave is offline
post #7 of 8 Old 08-18-2012, 10:44 PM
pkstang's Avatar
my gate has a 10# spring and i see about 8# at 4500 using my pms
i plan on raising my rpm this year so i'm sure i will see the full thing
pkstang is offline
post #8 of 8 Old 08-19-2012, 12:50 AM
lightblade's Avatar
I have my 2step set at 4k rpms. When I engage it at the first amber i have 3-4psi by the time green comes on and I drop it. If I hold it longer, after 2-3 seconds of holding I have full boost which a little too much for the nitto dr's. lol
1994 - 95 Cobra grille: pony or snake? 1oldfox 94/95 Tech 57 04-19-2013 11:53 PM
Question on ground Location prangy 5.0/5.8 Engine Tech 0 05-02-2012 09:51 PM
Man facing jailtime for owing child support commits suicide on courthouse steps MurPHy4570 Politics 96 02-19-2012 01:24 PM
sn95 update/backdate question mobil95 Road Racing/Auto X 1 11-24-2011 02:23 PM
Head milling question. bagel77 5.0/5.8 Engine Tech 4 03-16-2011 03:23 PM
