26 vs 27 inch slick - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 07-09-2012, 12:07 PM Thread Starter
g3mustang's Avatar
Trader Feedback: (18)
26 vs 27 inch slick
combo is a 331 afr 185 heads 3.27 gears through a 5 speed.
im running 26inch drag radials now and cant get the car to hook. going with a tack set setup and wanting to know would i notice going to a 27inch slick vs 26
i like the idea of the a inch more sidewall but will it hurt me down the track. i know a slick will balloon at the end of the track so does a 26inch slick turn into a 27 at the end anyway?? cuz i dont want to go to a 28invh tire at the end of the track this would be too much i feel
afr 185 heads, dss 331
Turbo build
g3mustang is offline
post #2 of 9 Old 07-09-2012, 12:36 PM
jturmanator's Avatar
I like the 27" Hoosiers and plan to run them when I kill my radials. I borrowed a buddys 26" M/T slick and the car seemed to be underpowered with them on. E/T were no different with radial
Just my experience.
jturmanator is offline
post #3 of 9 Old 07-09-2012, 01:12 PM Thread Starter
g3mustang's Avatar
i like the hoosier too but my main question is will the one inch in tire hight going to make a difference??
Turbo build
post #4 of 9 Old 07-09-2012, 01:44 PM
Na306Fox's Avatar
I ran 28" m/t et on my '96 GT with a 125 shot off the line an it hooked like a monster an popped the front wheels off the ground about 6-12 inches.
What the question is, what's the tire pressures you're running? I run mine at 17-19psi an it always would hook. I was making 306rwhp & 432rwtq
Sent from the All Mighty EVO 4g LTE
Na306Fox is offline
post #5 of 9 Old 07-09-2012, 01:56 PM Thread Starter
g3mustang's Avatar
im making close to 600whp
Turbo build
post #6 of 9 Old 07-09-2012, 02:01 PM
Na306Fox's Avatar
It's also about suspension setup.
I had upper & lower control arms, sub frame, drag springs, 90/10's up front and no quad shocks
Na306Fox is offline
post #7 of 9 Old 07-11-2012, 12:42 AM Thread Starter
g3mustang's Avatar
Stck style suspension
How do dot slicks hook on the street ????
Turbo build
post #8 of 9 Old 07-11-2012, 12:58 AM Thread Starter
g3mustang's Avatar
Or should I just bite tte bullet and 28inch
Turbo build
post #9 of 9 Old 07-11-2012, 01:04 AM
I ran both 28 10.5's slicks and 275 60 drag radials on my car. Ran nearly identical times with both (slightly better with the drag radials) Will never go back to a slick though. Car was all over the place with soft sidewalls. Drag radials were very stable up top. Made about 600hp
Originally Posted by JSZ03 View Post
pretty interesting...although I knew a guy whose son chewed through the backseat of his new Chevy Blazer on a vacation once....the guy asked the kid why, and the kid said he was just bored....
pete85fox is offline
Solid Rear Axles Questions? Nine inch ends or not chagan02 General Mustang Tech 10 09-19-2011 10:18 PM
3 inch collector fit a 2.5 inch H-pipe? justhereforinfo General Mustang Tech 9 07-26-2011 02:14 PM
For Sale Full Mac 3 Inch Setup StangSleeper Exhaust Parts 20 03-19-2011 10:26 AM
How much can a slick "grow" or "stand up" going downtrack??? NO MANRZ1 Wheels and Tires 4 12-14-2001 07:00 PM
