450 rw hp turbo 5.0? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 07-06-2012, 02:40 AM Thread Starter
Will I make 450 hp with this set up? Car is a 89 gt 5.0 mustang
Gt40p heads- milled, valve job, exaust port work and a little intake port work
Explorer intake lightly ported
75mm bbk throttle body
F-303 cam
60# injectors
255 lph fuel pump
Electric fans
Stock rebuilt bottom end
3:73 gears
On3 accessory kit includes injectors, mass air flow, fuel pump, oil filter relocation kit
On3 70mm turbo 12#s of boost
Playdoh302 is offline
post #2 of 14 Old 07-06-2012, 03:05 AM
with 12lbs of boost yes. but so is a blown head gasket.
88lx Conv. 200K mile stock longblock. Trickflow intake, 42lb inj, Pmas protube,TKO500, 3:27, pypes muffs, Pa Racing tubluar K-member, DIY single turbo setup. Summit aluminum rad, Crane Hi-fire ign, subfames, 17" sc saleen's, Saleen ground effects, SCT tune by Dynosport. 380HP 435ftbs.
71swing is offline
post #3 of 14 Old 07-06-2012, 03:53 AM Thread Starter
I'll keep the boost low to try to keep head gaskets then turn it up when needed if that'll hlp
post #4 of 14 Old 07-06-2012, 10:29 AM
RWILLIAMS's Avatar
Are the heads aluminum or iron? A good set of gaskets and some head studs will cure that problem. You could definelty make 450 with that combo and a turbo.
1990 Mustang GT
347ci, Vortech S-Trim 522rwhp / 497rwtq on 8psi
Featured in MM&FF December 2010
RWILLIAMS is offline
post #5 of 14 Old 07-06-2012, 02:25 PM Thread Starter
There iron heads
post #6 of 14 Old 07-06-2012, 06:08 PM
RWILLIAMS's Avatar
The weight of the iron heads will help with the seal but with 12lbs of boost Id definetly get a good set of head studs instead of headbolts.
Im running RHS aluminum heads on my SC 347 and with 8lbs of boost it was moving the heads around and blowing gaskets with head bolts, but my compression ratio is close to 10.5:1. ARP head studs solved that problem.
1990 Mustang GT
post #7 of 14 Old 07-06-2012, 06:59 PM
sweat90lx's Avatar
Should easily make that power. The iron heads have issues lifting head gaskets over 10#s.
Sent from my ADR6425LVW using Tapatalk 2
12.7s motor, 11.7s spray, turbo 400/460. [email protected]
sweat90lx is offline
post #8 of 14 Old 07-06-2012, 08:56 PM Thread Starter
I'll get some studs then to make sure I'll keep gaskets
post #9 of 14 Old 07-07-2012, 08:28 AM
The weight of the heads have nothing to do with gasket sealing abilities. The factory iron heads have thinner decks compared to most aftermarket stuff out there. Head studs will definately help to retain gaskets. A decent set of aluminum heads would be a step up. I personally ran 10.2.1 compression and 14 lbs of boost on my turbo car. I used victor jr cylinder heads and head studs and had no gasket issues. That set up will make over 450 depending upon how much boost you choose to run!
post #10 of 14 Old 07-10-2012, 11:54 AM
A set of aluminum heads is definitely the way to go, for several reasons. The increased port sizes with the aluminum heads will allow 450 hp (or more) at a LOWER boost level (easier on gasket seal). The aluminum heads also dissipate heat better, which will lessen the chance of destructive detonation. Thirdly the thicker decks and larger valve sizes will greatly increase potential power output. IMHO
9Sec93LX is offline
post #11 of 14 Old 07-10-2012, 10:10 PM
mw95gt's Avatar
Yes you will make that easily.....Do yourself a favor...buy some arp head studs and good gaskets.....Cometics MLS and a good tune. I have ran several passes at 15LBS....Gaskets still holding. As me how I know...I learned the hard way buying 4 sets of gaskets. 4th set being the good stuff......
95gt Dart block 363, TEA 205 Heads. 78MM Turdblower Custom cam, All fab work done by me....Moates tuned by me, AODE done up, yep I got overdrive. Drag radials, 327 rear. Next setup to come over winter...lol
mw95gt is offline
post #12 of 14 Old 07-11-2012, 03:26 AM Thread Starter
Lol i bet it sucked geting 4 different kind of gaskets, I see u have the on3 kit how do u like and how long have u had it or the miles u've put on it, how does it hold up, and did u ever put it on a dyno, if so what did it make and sorry for all the questions
post #13 of 14 Old 07-11-2012, 08:10 PM
mw95gt's Avatar
About 4500 miles on it so far....I drive it a lot.....I have never put it on the dyno...Only went to the track once [email protected] foot breaking and spinning like crazy. 60ft was only 1.77.
mw95gt is offline
post #14 of 14 Old 07-12-2012, 02:41 AM
Bump
Alika is offline
On 3 Performance turbo questions, 2v, 3v, 4v 5.0, 5.8 Kit On 3 Performance Turbochargers 1522 05-04-2015 11:44 PM
For Sale On3 Turbo Kit for 94-95 5.0 w/ Extras Cody Austin89GT Power Adders 5 07-17-2012 10:48 PM
For Sale 1992 Mustang 2.3 Turbo Convertible NFS03COBRA Mustangs For Sale/Wanted, 1987-1993 7 06-05-2012 01:19 PM
For Sale My Rx7 Turbo 5.0 Project Part Out ripracer Windsor Engine Parts 8 01-12-2012 10:47 AM
Turbo 2012 5.0 88mmNotch Turbochargers 13 11-29-2011 12:32 AM
