28 INCH REAR TIRE - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 05-22-2012, 10:59 AM Thread Starter
g3mustang's Avatar
Trader Feedback: (18)
28 INCH REAR TIRE
Setup
331 afr 185 heads, fcam, spiderintake t67 turbo with .81 hotside 3.27 gears t5z trans full weight car
right now im running a 26 inch tire would my car go down the track faster with a 28in
i know in a n/a or s/c car you want a gear that gets you in redline at the traps.
is this the same for turbo cars?
afr 185 heads, dss 331
Turbo build
g3mustang is offline
post #2 of 9 Old 05-22-2012, 06:21 PM
Originally Posted by g3mustang View Post
Setup
you want the same as thing as far as passing the traps at redline goes but you also want as much boost/time as you possibly can get.
with that said bigger tire= more load = more sooner boost but you will suffer if you do not go thru the traps at the top of your gear... so my advice as was given in the auto gear thread is test and tune.
nyctony is offline
post #3 of 9 Old 05-22-2012, 11:17 PM Thread Starter
g3mustang's Avatar
K thanks
Turbo build
post #4 of 9 Old 06-01-2012, 11:45 PM
If gearing isn't right you could be slower. But as said, turbos love load and a bigger tire should help with traction! What gear and expectations of mph?
racerryan is offline
post #5 of 9 Old 06-01-2012, 11:50 PM
Just did a quick calc based on 3.27, stay with 26" tall tires.
post #6 of 9 Old 06-02-2012, 02:47 PM
Jersey True Street Guy
mcj50's Avatar
Trader Feedback: (84)
That turbo and exhaust housing sound like they may be the restriction on your car. You may pick up quite a bit if you do some research on the proper sized turbo. Not knowing the other variables on the car I would guess you should have something more like a 76 on that car.
mcj50 is offline
post #7 of 9 Old 06-02-2012, 04:22 PM
93alexcoupe's Avatar
Agreeed, that turbo must be running out of steam at the top. Even if its a stock block, a 72 or a 74 would be nice too.
Built by Lujan Motorsports
Boss 308ci BullseyePower Turbo, ProEfi.
93alexcoupe is offline
post #8 of 9 Old 06-03-2012, 01:10 AM
Setup
This is probably your biggest issue. Also i ASSume the turbine is ~65mm which is pretty small as well. I would do like the others have said and look into a properly sized turbo.
89 Coupe: 362CI, 227cc HP Heads, Super Vic EFI, 80mm Turbo, C4, and MS2 Extra
9.89 @ 142mph on 16psi
slo895.0 is offline
post #9 of 9 Old 06-04-2012, 10:49 AM Thread Starter
g3mustang's Avatar
turbo feels like it pulls through the traps. but your right a bigger turbo would be nice but the car makes enough power as is just looking for a better way yo hook on the track with a 5 speed car
Turbo build
For Sale 7.5 inch 5 lug 3.73 drum rear $100 heavyd5 Drivetrain Parts 1 11-15-2011 09:58 PM
For Sale ➫➫➫ 03/04 Cobra Part out Black & Torch Red ➫➫➫ 2003snake Modular Engine Parts 329 10-09-2011 10:39 AM
GoPro rear tire view 03rd SVT Video 2 07-18-2011 12:06 PM
Official Mod Motor 2vna rules Dave King GT & SOHC 37 12-21-2001 01:27 PM
