Carb turbo fuel system - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 09-08-2011, 08:37 PM Thread Starter
I did see the post on the other page that is just like this one but it didn't seem very helpful.
What are you folks with blow through carbs and turbos running for a fuel pump? Efi pumps? Are all of you running bypass regulators? Just trying to get an idea.
Thanks in advance.
Tropikallie is offline
post #2 of 3 Old 09-09-2011, 03:06 AM
Gearhead559's Avatar
bypass for sure, boost ref and all that too...
you can run a a1000 to it with the correct reg just make sure your return is as large as the feed. or you will see fp creep up at idle/low rpm..
Gearhead559 is offline
post #3 of 3 Old 09-10-2011, 08:30 AM
I run an A1000, 13204 regulator, -10 feed, -8 return, with -6 to each bowl. I can get the fuel pressure as low as I want. You need a pump that can put out enough pressure for you base of 7ish plus whatever boost you are running.
chiaj144 is offline
carb conversion redfox89 5.0/5.8 Engine Tech 6 11-11-2013 09:20 AM
For Sale Aeromotive 18601 Sumped 79-98 Fuel Tank $450 shipped StangTV.com Fuel System & Related 2 10-01-2011 01:57 AM
Fuel System Upgrade Before Engine Swap? WickedSnake00 GT & SOHC 1 08-30-2011 12:39 AM
For Sale Carb fuel system parts (left over, some new some used) n2omaverick Fuel System & Related 2 04-03-2011 06:23 AM
fuel injection to carb question snakebite8 5.0/5.8 Engine Tech 3 01-04-2011 09:22 PM
