3.27 vs 3.55 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 09-05-2011, 12:57 PM Thread Starter
3.27 vs 3.55
So I always see it's best to run lower numeric gears like 3.27 or 3.55 with a turbo. I'm planning on getting the Hellion single kit which comes with a 62mm. From the dyno graphs I have seen of the kit it makes full boost by ~3000rpm. One graph I saw was making over 400rwtq from 3250-5300ish and peaking at 530.
I'm curious as to what you guys would suggest gear wise, 3.27 or 3.55? The car is a 02 GT, 4r70w and 3600 stall.
00GT4.6 is offline
post #2 of 13 Old 09-05-2011, 02:04 PM
Trader Feedback: (22)
with the same kit, 3:27s, and 62mm I saw 532whp/630wtq at 10.8psi
03 Mustang GT
Turbo 2v
LS1KILR is offline
post #3 of 13 Old 09-05-2011, 02:10 PM Thread Starter
Not bad numbers
Maybe I should have been more clear. With the Hellion kit I will be running the stock block. I'm wondering what gears would be best for that setup (power level) and would get me down the track fastest.
00GT4.6 is offline
post #4 of 13 Old 09-07-2011, 09:56 AM Thread Starter
After some searching around I think 3.55s might be better. Still open to suggestions from people with first hand experience.
00GT4.6 is offline
post #5 of 13 Old 09-08-2011, 12:38 AM
y2k02's Avatar
I along with many run 3.27 and let the turbos do the work.
2002 2V TF heads Custom Edelbrock NA SVT Cams
Twin 6466 TH400 Dominator EFI TH400 UCC
y2k02 is offline
post #6 of 13 Old 09-08-2011, 09:49 AM Thread Starter
Why did you guys choose 3.27s over 3.55?
00GT4.6 is offline
post #7 of 13 Old 09-08-2011, 10:51 AM
turbos are load dependant. 3:27=more load. I will be trying out 3:08s sometime in the future
03 Mustang GT
Turbo 2v
LS1KILR is offline
post #8 of 13 Old 09-08-2011, 12:55 PM
y2k02's Avatar
My car was quicker with 3.27 and 27" tire than 26" tire. Then I ran a 28" tire and went even quicker.
y2k02 is offline
post #9 of 13 Old 09-08-2011, 07:16 PM Thread Starter
Hmmm...I have 4.10s now so maybe I could swap my rear for my buddies 3.27 rear. That way it wouldn't cost me anything and I could see how I liked the 3.27s.
00GT4.6 is offline
post #10 of 13 Old 09-08-2011, 11:13 PM
fivepointeightnate's Avatar
That's good thinkin' right there! Try before you buy
Forged 383CI - Turbonetics 78mm 3.5" DP - Stage III TFS - E-303 1.7RR - T56 - Mcleod RST Twin
fivepointeightnate is offline
post #11 of 13 Old 09-10-2011, 09:32 PM
JIMS SVT's Avatar
I had a 355 and switched to a 327. It dropped the rpm on the big end a little. Lost alittle 60ft with the 327. Car ran about the same really. I liked the 355 better. On the street it felt better all around.
1998 turbo cobra TH400 Street car Sold
1997 Triple black Novi2k 6 speed car.
1999 FRC Cammed C5
JIMS SVT is offline
post #12 of 13 Old 09-16-2011, 12:01 AM
Typically as you go down numerically it puts more load on the motor and it gets easier to get the car to leave well.
Its not in every situation but the small advantages of more load, easier leaving, and better highway RPMs usually make less gear a better choice.
you're the one waving your economics dick like you think it's a sword
streetfalcon is offline
post #13 of 13 Old 09-16-2011, 07:25 PM
pkstang's Avatar
Trader Feedback: (162)
i chnaged from 373s to 331s and all i can say is WOW!
pkstang is offline
For Sale FS: Good used gear sets, 3.27, 3.31, 3.55 South Jersey Stang Drivetrain Parts 25 12-26-2011 12:16 AM
For Sale Ford Motorsport 3.55 gears and 28 spline limited slip differential irwinner Drivetrain Parts 6 09-02-2011 03:51 PM
For Sale Richmond 3.55 gears for 8.8 built2rev Drivetrain Parts 1 08-18-2011 05:59 PM
For Sale 3.27 and 4.10 gears 8.8 Ruslow Drivetrain Parts 10 06-14-2011 10:45 PM
For Sale 3.55 gears for 8.8 $75 shipped 89GTPA Drivetrain Parts 4 02-20-2011 10:13 PM
