any PMS tuners in florida? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 07-15-2011, 01:17 PM Thread Starter
i had the car tuned with a chip and that was a waste of 500 i ended up putting the anderson pms back on the car with the tune i putinto it and the car is making alot more power then the chip tune but i still need the car tuned right with the anderson pms anyone know of a shop in florida that tunes with the pms?
boosted351wcobra is offline
post #2 of 14 Old 07-16-2011, 12:48 AM
mghoward74's Avatar
your tuner was the problem, not the chip
mghoward74 is offline
post #3 of 14 Old 07-16-2011, 06:18 PM Thread Starter
yea i agree but i would still rather use the pms so every time i change something i dont need the tuner to do it.
post #4 of 14 Old 07-18-2011, 02:12 PM
What part of Florida are you in?
93 Cobra # 2588
93 LX Notch
93mustang4me is offline
post #5 of 14 Old 07-18-2011, 04:56 PM Thread Starter
im in st pete florida
post #6 of 14 Old 07-20-2011, 10:21 AM
Well I would say I could help in person but that is a long trip. What issues are you having?
93 Cobra # 2588
93 LX Notch
post #7 of 14 Old 07-20-2011, 03:50 PM Thread Starter
where are you at? well one big issue im having is that normal driving its way to rich 10.0 A/F and messes up the plugs really quick.im sure i could fix that but im just wanting someone that knows the pms to tune the car once i replace the clutch.
post #8 of 14 Old 07-20-2011, 04:22 PM
Ft Walton beach. It seems that I had a similar problem when I first installed the PMS. Some times the fix is the simplest fix lets start at the begining. Did you set you TPS for idle and WOT, base timing 10 with spout out, what is the AFR at idle?
Matt
93 Cobra # 2588
93 LX Notch
post #9 of 14 Old 07-20-2011, 04:51 PM
mghoward74's Avatar
That's funny, seeing as I pm'd you to the person who could answer all your questions and walk you through a tune ( for free )
Did he not help you?
post #10 of 14 Old 07-22-2011, 02:26 AM Thread Starter
Matt
yea i did all that A/F IS 14.4
post #11 of 14 Old 07-22-2011, 02:27 AM Thread Starter
im not sure if you are talking to me or not but if you are i never got a pm from you or anyone.
post #12 of 14 Old 07-22-2011, 11:00 AM
One more question, what is your FP set at? Here is one way to fix that issue. Disconnect your O2s (connector on the passenger next to your relays in the eng bay)and tune the LL ML HL tables, once you have it where you want it, connect them back up. This should help.
93 Cobra # 2588
93 LX Notch
post #13 of 14 Old 07-22-2011, 03:34 PM
You check Ford Speed? Justin at VMP? There are a couple other tuners on your side of the bay that Im sure can help you out.
Ryan
94 V6 to 98 Cobra swap.
the anti-rice is offline
post #14 of 14 Old 07-22-2011, 06:09 PM Thread Starter
i talked to ford speed but they said they dont like the pms so i figure ill find someone that has used it and know more about it
Any good PMS tuners in GA or FL? JPW PMS Tuning 2 05-06-2011 09:04 PM
Using PMS and InterACQ to control boost? WhiteLX Turbochargers 5 03-28-2011 11:22 AM
DEA bust in South Florida white88 Lounge 20 03-14-2011 09:49 PM
The Florida honey hole of drugs is drying up it seems... Streetstrip01 Lounge 8 02-24-2011 11:21 PM
So this is going to be Florida Rep's legacy? A hat? Make that a closet full... KC LX Lounge 10 11-24-2010 03:55 PM
