9.25 compression to high? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 06-13-2011, 02:08 PM Thread Starter
93BLKNotch's Avatar
Just wondering if this compression is to high in my 302? Car is boosted. What's the highest boost level can I go?
93BLKNotch is offline
post #2 of 13 Old 06-13-2011, 02:29 PM
Trader Feedback: (157)
that is fine.
are u running intercooler though?
jtmustang91 is offline
post #3 of 13 Old 06-13-2011, 02:38 PM
conbread's Avatar
Trader Feedback: (60)
it will depend on the tune up.. should be plenty fine.. i plan on making mine 9.5 to 1 and run pump gas with a meth kit..
89 Hatch 6.65 @ 106...
conbread is offline
post #4 of 13 Old 06-13-2011, 03:51 PM Thread Starter
93BLKNotch's Avatar
Yes I have an intercooler. How much boost can I run with it
post #5 of 13 Old 06-13-2011, 08:43 PM
conbread's Avatar
boost number doesnt really matter, every setup is diff.. what kind of power do u wana make??
conbread is offline
post #6 of 13 Old 06-13-2011, 09:06 PM
cesna150's Avatar
Trader Feedback: (29)
Too many variables. More comp, more boost, good gas.
1993 notch 302 and c4
quicktime turbo system
9.986 @ 136.84
cesna150 is offline
post #7 of 13 Old 06-13-2011, 09:48 PM
blucoupe308's Avatar
Trader Feedback: (48)
I've ran 9:4 1 on 18lbs on my last motor and it was fine, 93 pump gas 306.
351w I have now has about the same compression
blucoupe308 is offline
post #8 of 13 Old 06-14-2011, 04:42 PM
Formerly eades5.0
4Jenna's Avatar
c/r is fine for most boosted street app's
WWW.JENNABEARSFOUNDATION.ORG
4Jenna is offline
post #9 of 13 Old 06-15-2011, 11:19 PM
rdub79's Avatar
Trader Feedback: (80)
X2, mine is 9.3:1 pump gas and meth 15 psi and 22* timing
88' Coupe
rdub79 is offline
post #10 of 13 Old 06-30-2011, 11:16 PM
Jersey True Street Guy
mcj50's Avatar
Trader Feedback: (84)
More compression makes more power. Like the guys said, watch it with pump gas...
My motor gave us a big smiley face when we gave it more compression...
If running race gas you can go higher then 9.25 safely. The things some of the 275 owners do with motors scares me....
mcj50 is offline
post #11 of 13 Old 07-05-2011, 09:20 AM
goatnipples2002's Avatar
Trader Feedback: (22)
Go e85 u won't be mad.
goatnipples2002 is offline
post #12 of 13 Old 07-05-2011, 04:54 PM
jasonlx's Avatar
i run 9.5:1 with iron heads, 12#'s and pump gas. no problems so far.
93 lx, stock block, windsor jr. heads, custom cam, track heat , 75mm tb, hellion turbo kit (62-1), abaco 85mm, PMS IV, 3:27's, t5
proud member of the "jackstand turbo mustang club"
jasonlx is offline
post #13 of 13 Old 07-06-2011, 05:31 AM
old motor was 9.8-1 with #15 lbs of boost on 93 made 567rwhp
new motor is 8.5-1 with #30 lbs of boost on E85. no idea find out friday for hp
if you have a good tuner youll be fine. make sure you have good fuel pump/pumps
chevyguy15 is offline
What kind of power, high compression combo? saleen9973 5.0/5.8 Engine Tech 12 04-12-2011 05:55 PM
High Compression Big Bore 347's? Roadwarrior 5.0/5.8 Engine Tech 8 02-19-2011 08:30 AM
High compression nitrous build? Modded_droptop GT & SOHC 30 01-27-2011 07:10 AM
high comp 347 piston question running NOS mustangparts4u Nitrous 4 01-24-2011 12:31 PM
Compression? And How N20 Reacts to Increased Comp? Silver Streak GT & SOHC 6 12-16-2001 08:37 AM
