Went to track ran a 12.0 @ 123 now car runs bad - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 42 Old 06-04-2011, 10:26 AM Thread Starter
93BLKNotch's Avatar
Went to the track second pass my car blew the oil cap and now blows smoke out the exhaust runs like its stuttering no oil in coolent vice versa. Don't know what's going on what does an blow head gasket drive like
93BLKNotch is offline
post #2 of 42 Old 06-04-2011, 11:12 AM
Moderator
Jeff88coupe's Avatar
Pull the plugs...see what they look like. Do a compression test. You may have a blown intake or head gasket.
Xtreme 8.5" -Heads up 1/8th mile limited 8.5 class at Kilkare Dragway
Dedpedal Racing;Sponsered by
;Tuned by
Boss block Big bore 347/225 TFS HP's/SR/BW S476R/A2W/PG/FAST xfi on E85
5.33 at 134.9 on 26x8.5 in 1/8th @3380#
Jeff88coupe is offline
post #3 of 42 Old 06-04-2011, 02:52 PM Thread Starter
93BLKNotch's Avatar
Anything else?
post #4 of 42 Old 06-04-2011, 05:04 PM
firemanwill28's Avatar
How much psi were you running? What kind of crankcase vent system are you using?
1990 Coupe, 302/AOD, stock cam/short block, AFR 165's, 3.55's. Working on a N/A stroker build.
firemanwill28 is offline
post #5 of 42 Old 06-04-2011, 05:27 PM
Aside from the normal blown gasket, I had the same problem when I cracked a valve spring at the track a few years ago.
ByondHlp is offline
post #6 of 42 Old 06-04-2011, 09:18 PM Thread Starter
93BLKNotch's Avatar
13 pounds breather on one valve cover pcv still intact I changed pvc to vent to atomsphere but still nothings still smokesw in boost
post #7 of 42 Old 06-04-2011, 09:29 PM
You need to get rid of the PVC system; if any of the stock system in still intact, you'll be boosting the crankcase. I had a similar problem of smoke under boost and it was the oil filler neck vent tube to the TB. Once it was removed the problem went away. I'd seriously consider a vented catch can, especially running 13 pounds.
post #8 of 42 Old 06-04-2011, 09:53 PM Thread Starter
93BLKNotch's Avatar
Dpnt got the oil filler neck to tb just pvc to intake but now I got it vented to atmosphere
post #9 of 42 Old 06-04-2011, 09:55 PM
Hope she didn't break; 13 pounds is pushing it with stock block 302's. I'd change the oil and do a compression test, that should tell a good story.
post #10 of 42 Old 06-05-2011, 05:44 PM Thread Starter
93BLKNotch's Avatar
pulled plugs all were good besides #4 plug was melted i detonated im assuming anyways i changed plugs and oil today car still has power but not like it should it takes a while to spool up. vacuum was low @10 normally 15 with my f303 cam. havent pulled the valve covers yet though
post #11 of 42 Old 06-05-2011, 07:38 PM Thread Starter
93BLKNotch's Avatar
valve train looked fine springs are fine didnt get into the pushrods but i did narrow it down to #5 cylinder. it has spark but is not getting fuel. checked power @ injector there is power so is it the injector? wish i had a spare green top...
post #12 of 42 Old 06-05-2011, 08:07 PM
Swap the number 5 injector with a different injector on the engine and see if the problems follows the injector.
Remow2112 is offline
post #13 of 42 Old 06-05-2011, 09:31 PM Thread Starter
93BLKNotch's Avatar
pulled injector and hooked up positive and ground injector clicks and lets fuel out likes its suppose to im stumped could it be a headgasket i just dont have the symptoms. Car doesnt overheat, oil was fine, no loss of coolent. vacuum gauge still reads lower. could it be a head gasket. never done a compress test or leak down test.
post #14 of 42 Old 06-05-2011, 11:22 PM Thread Starter
93BLKNotch's Avatar
anybody wanna chime in please. I wanna solve this problem.
post #15 of 42 Old 06-05-2011, 11:36 PM
Trader Feedback: (22)
my car had a similar problem. i melted a spark plug apparently from going lean. car never ran the same after that. problems continued to get worse. car kept eating plugs. compression test showed good. finally pulled the heads off and found out the cylinder which had the initial spark plug damage also melted away part of the spark plug boss on the head and did some light damage to the piston. It ran fine around town but was having problems at high rpm
03 Mustang GT
Turbo 2v
LS1KILR is offline
post #16 of 42 Old 06-06-2011, 12:08 AM Thread Starter
93BLKNotch's Avatar
so what you do was the head gasket gone? did you replace it? dont know what to do. thanks for the reply!
post #17 of 42 Old 06-06-2011, 07:11 AM
5.0mustang5speed's Avatar
did u do a compression check on that cylinder yet, may have a hole in the piston or burnt valve
1962 falcon stock 1992 302 short block, RHS heads, 1.5 inch headers ..bullet cam ..victor jr.. [email protected] on 26x8.5 inch slicks with 1962 suspension(under construction getting back halved)
1979 zephyr , 393w, bone stock 1979 suspension on 26-8.5 tires [email protected]
5.0mustang5speed is offline
post #18 of 42 Old 06-06-2011, 10:32 AM
no the head gasket was fine. i just got new heads and pistons. Your issue might not be the same as mine but just sharing my experience. The head had a small spot melted away. I had spark plug threads exposed in the combustion chamber. Nothing that a compression check or leakdown test would have shown. So im just saying if you continue to have issues it might be something internal
03 Mustang GT
Turbo 2v
LS1KILR is offline
post #19 of 42 Old 06-06-2011, 11:05 AM Thread Starter
93BLKNotch's Avatar
Ill keep everyone posted tearing it down wed my bday....
post #20 of 42 Old 06-06-2011, 02:01 PM
Do the compresson test, it will answer most of your questions. What are you running for Air Fuel Ratio?
93 Cobra # 2588
93 LX Notch
93mustang4me is offline
post #21 of 42 Old 06-06-2011, 02:28 PM
Moderator
A compression or Leak down test will answer most all your questions if you have a blown head gasket or other issue. I blew a head gasket on an old stock 302 shortblock/gt40p head/nitrous combo. Ran fine unless I was at WOT...then it would push vapor/oil out the pvc/dip stick tube. Found that the head gasket blew out right at the top so it let combustion pressure into the lifter valve which pressurized the crankcase.
;Tuned by
post #22 of 42 Old 06-08-2011, 02:58 AM Thread Starter
93BLKNotch's Avatar
well headgaskets were fine but #5 pistion went bye bye.....
so question:
1. Can i go 331 stroker? If so how do i keep compression down
2. what are good pistons and do i need to balance the engine again?
post #23 of 42 Old 06-08-2011, 09:01 AM
ShaaZammm
so question:
Bro, I'm thinking a little JB Weld and you'll be back in business.... Lol.
Yes you could run a 331. DSS racing kit is what I run. But, you need to think about what caused this, detonation. Give us a run down on your setup, what heads are you running, fuel system, ect? Before I would send the money on a new 331, I would look at upgrading your fuel system. I have seen it before people spend money in all the right ways except one, their fuel system. If you are on a budget, get another stock short block from the salvage yard or craigslist and roll with it. I made 485 on a s-trimmed stock short block for a long time, but time took its toll and she let go on the dyno.
93 Cobra # 2588
93 LX Notch
post #24 of 42 Old 06-08-2011, 09:10 AM
Was the car tuned? What are using to control you timing?
93 Cobra # 2588
93 LX Notch
post #25 of 42 Old 06-08-2011, 10:43 AM Thread Starter
93BLKNotch's Avatar
k i have a on3 kit 70mm .68exh
42lb injectors
pmas 3inch blow through cal for 42s
stock fuel lines
195 in tank
trex vortect inline pump
WCP heads port matched to
Pro Products Upper and lower
70mm tb
not running egr
underdrive pulleys
aeromotive adj Fuel Reg set @ 40 line off
F303 cam
Timing was set at stock 10 degrees
car was tuned by John Garner Horserpower Ranch here in Maple Valley WA
I have a chip in it he also Forced the O2s into open loop
Question though I got it tuned before I put the F303 Cam in I got it tuned with a z303 cam. Would that have affected my tune??
post #26 of 42 Old 06-08-2011, 12:50 PM
I love the F-cam man. You can make some good power with that bump stick. Changing the cam will effect your tune. With chips, anytime you change your setup they should be reflashed/tuned. I would upgrade the fuel system and think about a PMS from AFM.
93 Cobra # 2588
93 LX Notch
post #27 of 42 Old 06-08-2011, 01:10 PM
cesna150's Avatar
Trader Feedback: (29)
if you are gonna change stuff after having it tuned your asking for trouble. you can sometimes make small changes but ONLY if you have a afr gauge and watch what its doing. it dosent take much to create a lean hot spot and end up with a see thru piston like yours.
1993 notch 302 and c4
quicktime turbo system
9.986 @ 136.84
cesna150 is offline
post #28 of 42 Old 06-08-2011, 02:26 PM Thread Starter
93BLKNotch's Avatar
So gettin some forged pistons with the stock crank and rods do I need to get it rebalanced?
post #29 of 42 Old 06-08-2011, 02:59 PM
SilverFox's Avatar
Yes, if you buy pistons to fit the stock rods it's a good idea to get the whole assembly balanced. It might also be recommended that you get the crank turned. Whatever you decide to do, please buy a yourself a wideband. Changing the cam after getting a tuned chip is a no-no. This isn't a cheap hobby and it can easily bite you in the butt if you don't make sound decisions.
New Combo.....1985 notch, 331, T-76GTSH, C4, track numbers soon.
SilverFox is offline
post #30 of 42 Old 06-08-2011, 03:48 PM Thread Starter
93BLKNotch's Avatar
I do have a wideband. My afr was 11:6 wot
post #31 of 42 Old 06-08-2011, 04:55 PM
Moderator
Check into Probe pistons. Think they are running a 20% off sale this month. Good pistons..ran them in my 347. Yes you will need to have the rotating assembly rebalanced with new pistons.
;Tuned by
post #32 of 42 Old 06-08-2011, 08:38 PM
Do you have a data logger? That would tell you what happen.
93 Cobra # 2588
93 LX Notch
post #33 of 42 Old 06-08-2011, 08:45 PM Thread Starter
93BLKNotch's Avatar
I just thiink fuel pressure was to low. I have an aeromotive fpr and when I prime the fuel system instantly I lose 40 psi. When first installed it held pressure.
post #34 of 42 Old 06-09-2011, 02:54 AM Thread Starter
93BLKNotch's Avatar
Any suggestions?
post #35 of 42 Old 06-09-2011, 09:21 AM
ive ran the probe srs pistons and they are tough. i believe you can get a whole set for less than $500
03 Mustang GT
Turbo 2v
LS1KILR is offline
For Sale 1993 lx coupe 5.0 turbo 66,000 miles hackster Mustangs For Sale/Wanted, 1987-1993 9 10-14-2011 11:50 PM
For Sale 1993 Ford Mustang Cobra Teal/Black - Amazing Car, Check it out. Mustang9 Mustangs For Sale/Wanted, 1987-1993 78 09-26-2011 11:14 AM
For Sale The Teal Terminator!!!...LOTS of details NothinButNotch Mustangs For Sale/Wanted, 1999-2004 70 01-12-2011 01:29 PM
For Sale 1993 Vortech Blown AOD LX Hatch in NJ FoxEffect93LX Mustangs For Sale/Wanted, 1987-1993 11 01-02-2011 10:49 PM
Need quiet Mufflers for 450hp car. Open headers at the track a good idea? *LONG* jz_mustang50 General Mustang Tech 22 01-03-2002 08:12 PM
