SC61 replacement / upgrade ?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 04-21-2011, 09:16 PM Thread Starter
xr8240's Avatar
I want to replace my Precision SC61 with bigger turbo's...
I would like to keep internal gates as I have little room..
They are maxing out at 18Lb / 780 rwhp d/d dyno..
What other options are there ??
Would like larger than .63 turbines and tighter trim wheels to give me some good spooling.
GT35/40's etc ??? Or similar ??
With 7.8 compression I need early response as it makes very laggy throttle response...
xr8240 is offline
post #2 of 3 Old 04-22-2011, 07:00 PM
jaredgoodwin's Avatar
I have twin SC61s, I thought they were rated to 680hp each
2007 Mustang GT
Whipple'd
1987 Mustang GT T-Tops
408W Twin turbo
jaredgoodwin is offline
post #3 of 3 Old 04-25-2011, 09:55 AM Thread Starter
xr8240's Avatar
Yea I feel they are on the small side ??
For 330ci ???
With 7.8 compression doesn't help..
xr8240 is offline
Wanting to upgrade to Windows 7? sc302 Lounge 12 04-16-2011 09:44 PM
Should I upgrade my Procharger bypass valve? WhiteLX Superchargers 0 02-16-2011 12:18 PM
Fuel Upgrade Questions Cobra tank swap to 00GT orangemachine GT & SOHC 0 12-25-2010 07:14 PM
SN95 brake upgrade questions WhiteGT-2 General Mustang Tech 6 12-27-2001 11:12 PM
