70mm or 76mm - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 04-20-2011, 04:34 PM Thread Starter
Montman's Avatar
70mm or 76mm
I've got a bone stock (Like I just removed the Air Silencer and it still has stock mufflers stock!) 91 GT. I've also got a B&G kit with a PT76GTHS .96A/R turbo. I don't have the funds to build everything I need for the bigger motor I have planned, but I want to turbo the car to learn and tune with the AEM. Should I buy a cheap used MP70 or the likes or put on the 76 and let it be a turd? I had a stock 86 coupe with a 70mm and it was a blast. Wouldn't mind doing something like that while I save up for the 331
Montman is offline
post #2 of 14 Old 04-20-2011, 05:55 PM
blackn2ocoupe's Avatar
a 70mm can make enough power to split your block, my logic if your on a budget would be pick up the Masterpower 70mm. I just put one on my coupe to learn this whole turbo thing and so far I'm very happy with it
blackn2ocoupe is offline
post #3 of 14 Old 04-20-2011, 06:08 PM
Do not even go with the master power, all you are doing is paying for the warranty. Save the money stick with the On3 70mm and put that money somewhere else.
paxton50mustang is offline
post #4 of 14 Old 04-20-2011, 11:12 PM Thread Starter
Montman's Avatar
I've actually considered this turbo, it's cheap. I'm a little worried as I don't know anything about them. Has anyone used one.
Montman is offline
post #5 of 14 Old 04-21-2011, 12:23 PM
sweat90lx's Avatar
im thinking about the On3 76 with .68AR
but I havnt seen many people run them yet
12.7s motor, 11.7s spray, turbo 400/460. [email protected]
sweat90lx is offline
post #6 of 14 Old 04-21-2011, 12:41 PM
1995gtCPE's Avatar
Trader Feedback: (34)
Not really sure why people say this all the time. I mean a block can split on a mild hci combo.
1995gtCPE is offline
post #7 of 14 Old 04-21-2011, 02:45 PM
Formerly eades5.0
4Jenna's Avatar
I would run the turbo you have, at most buy a smaller exh housing for it. Run like 6-8psi and enjoy it.
-Chris
WWW.JENNABEARSFOUNDATION.ORG
4Jenna is offline
post #8 of 14 Old 04-22-2011, 06:39 AM
swinerton's Avatar
Trader Feedback: (15)
Small boost, small turbo. Big boost, big turbo. No need to run a 76mm if your not going to push the boost past 15-18psi.
Cory Swinerton
2013 Boss 302 #540 712rwhp/592rwtq (SOLD)
1999 GT 2V 775rwhp Ysi, Boss 304". (SOLD)
Originally Posted by WhiteLX408 View Post
Running street tires at the track is like wiping your ass with a turd.
swinerton is offline
post #9 of 14 Old 04-22-2011, 09:29 AM
Jersey True Street Guy
mcj50's Avatar
Trader Feedback: (84)
By the time you buy the exhaust housing you will be a good portion of the way to an mpt70. Grab a deal on a used one and sell it again when you are ready. The car will work better with a smaller turbo. Something even smaller then the 70 could probably work if you comb the message boards for stuff for sale.
mcj50 is offline
post #10 of 14 Old 04-22-2011, 10:39 AM
Formerly eades5.0
4Jenna's Avatar
I have never ran 15-18psi, should I sell my 76? I plan to eventually though haha.
Boost is just a #, 12psi on my car may be 20psi on yours.
I would keep the 76 since you already have it, I like to do things simple though. I went 9's on a MPT70, so either turbo has the potential to make great power. Also for the record their is almost no spool diff from my MPT70 to my 76, both .96
4Jenna is offline
post #11 of 14 Old 04-22-2011, 01:51 PM
swinerton's Avatar
If your running a 230cc head, on 400ci 8000rpm monster yes, it probably would be.
Most of us however are in the 300-350ci displacement range with similar flow characteristics. 2-3psi range difference normally.
Cory Swinerton
post #12 of 14 Old 04-22-2011, 03:13 PM
Formerly eades5.0
4Jenna's Avatar
My point is boost is only backpressure, I see you missed that completely. I wasn't ACTUALLY compairing my combo to anyones.
On my car (many varibles, to many to compair) it took 10psi on a MPT70 to run a 9 sec pass. I just dont agree with the blanket statement is all.
"No need to run a 76mm if your not going to push the boost past 15-18psi"
That makes no sense to me as boost is just a #. Cars can be very fast and make great power on mild boost regaurdless of the turbo size. Heck a 76 on this car would be great on low boost with plenty of room to upgrade! Or end up like me, buy the MPT70...outgrow it and then get a 76gts again haha.
That's all I was getting at.
4Jenna is offline
post #13 of 14 Old 05-02-2011, 04:00 PM
ssj50driver's Avatar
Look at a compressor map and try to get a general consumption chart of your vehicle. Compare and be sure to account for efficiency of your setup. Good luck.
ssj50driver is offline
post #14 of 14 Old 05-02-2011, 04:26 PM
longstroke's Avatar
"No need to run a 3.4 whipple if your not going to push the boost past 15-18psi"
There i fixed it...
longstroke is offline
For Sale 86-93 C&L 76mm Mass Air w/ Meter - Power Pipe - K&N Filter capriman86 Windsor Engine Parts 1 03-27-2011 09:27 PM
Want To Buy 70mm or 76mm turbo ElSPa Power Adders 7 02-04-2011 04:54 PM
Want To Buy 70mm or 76mm turbo, aluminum radiator and slim fans ElSPa S197 and Coyote Parts 0 02-03-2011 04:02 PM
70mm or 76mm turbo on a 302 2007 GT ? ElSPa Turbochargers 1 01-30-2011 01:03 PM
For Sale FS: Real GT40 intake U/L, with 1" spacer and BBK 70mm TB South Jersey Stang Windsor Engine Parts 16 11-21-2010 02:35 PM
