9.5.1 compresstion with boost good for 600 rwhp - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 27 Old 03-29-2011, 05:37 PM Thread Starter
bwaite's Avatar
hey guys is a 9.5.1 compression with about 15-17 psi through the turbo safe??
the main goal is to get to the 600 rwhp level. so not really sure how much boost ill need.
i know that a lower compression would be more ideal. but i found a killer deal on a short block that im picking up this weekend.
please let me know thanks brett
2004 Mustang Sonic Blue - turbo- - MMR 4.75 900
bwaite is offline
post #2 of 27 Old 03-29-2011, 05:57 PM
Apocolipse's Avatar
Maybe with 110++ race gas and meth injection :P
Apocolipse is offline
post #3 of 27 Old 03-29-2011, 06:33 PM
goatnipples2002's Avatar
Trader Feedback: (22)
Just run E85 and be good. E85 will laugh at u and want more.
goatnipples2002 is offline
post #4 of 27 Old 03-29-2011, 08:41 PM
331D1SCGT's Avatar
pump fuel + meth inj or e-85 like stated above and no prob at all.
95GT: 302, TEA TFS heads, systemax, jay allen cam, t-70, 60lb inj, moates quarterhorse, dynamic c4, and so on...
best so far (only pass on the car) 10.72 @ 123 (needs 3.27's)
331D1SCGT is offline
post #5 of 27 Old 03-29-2011, 10:13 PM
e85
03 Mustang GT
Turbo 2v
LS1KILR is offline
post #6 of 27 Old 03-29-2011, 10:33 PM Thread Starter
bwaite's Avatar
i do have a e85 gas station 3 miles from my house. hummmmmmmmmmmmmmmm its just those darn long road trips im worried about.
bwaite is offline
post #7 of 27 Old 03-29-2011, 10:52 PM
Mustangnut6788's Avatar
Are you going to be running an intercooler? You may have to pull some timing out up top but you should be able to hit around 15psi and be ok on 93 oct. I would pay close attention to your IAT's and your AFR. I would also talk to who is going to be doing the tuning work as well. They should be able to point you in the right direction.
Going E85 is ok but be prepared to upgrade your fuel system from pump to injector.
https://
http://stores.ebay.com/Nates-Fox-Body-Mustang-Parts
Outlaw Limited Street 91 Coupe 427w F3 Procharged
Mustangnut6788 is offline
post #8 of 27 Old 03-29-2011, 11:04 PM
shustack's Avatar
my build is a 9.1, stock compression is 9.5 i believe in a fox, so i dont think you should have a problem at all. I think 10.0 is the very max for boost.
shustack is offline
post #9 of 27 Old 03-29-2011, 11:15 PM Thread Starter
bwaite's Avatar
thanks you for the input. also it is inter-cooled and i might try getting it tuned with 93 first to see where that takes me,
my current setup is stock 2v 8 lbs through the turbo. made 460hp/514tq turbo has bin on the car just shy of a year.
boost is currently at 10psi so im sure im over the 500 hp mark.
im sure my stock bottom end hates me right now. first i started with 125 nitrous ran about 10 bottles, then switched to procharger at 10psi. now turbo with 10psi.
im sure its going to pop soon. but the last 3 years its had a lot of abuse. makes me really wonder if the bottom end is stock.
bwaite is offline
post #10 of 27 Old 03-30-2011, 08:05 AM
Jersey True Street Guy
mcj50's Avatar
Trader Feedback: (84)
Turbo cars will make more power with a more aggressive compression, but the comments here are right on the need to run high octane gas or an alternative like E85 or Meth.
It was one of the things my engine builder changed on my current motor to make more power with my setup....but I do run VP C16.
mcj50 is offline
post #11 of 27 Old 03-30-2011, 11:06 AM
Road trips in a boosted Stang u guys are funny. Rent a damn prius and call it a day.
post #12 of 27 Old 03-30-2011, 12:41 PM
once your turbo with built motor and making over 600 at the tires, its about time to buy a beater. The gas savings over the mustang will easily pay for the car after a year of daily driving. Sure you "could" probably drive the mustang everyday and take it on long road trips, but it wouldnt be economical. Plus insurance doesnt like to pay for aftermarket parts
03 Mustang GT
Turbo 2v
LS1KILR is offline
post #13 of 27 Old 03-30-2011, 08:12 PM
huafist's Avatar
You'll make more overall power with less compression and more boost.
There is nothing wrong with 9.5:1 compression. If you have 93 octane at the pump, run it and let her eat. As with any boosted car, keep an eye on things while tuning.
huafist is offline
post #14 of 27 Old 03-30-2011, 08:48 PM
You will make more power through out the entire powerband with more compression.
post #15 of 27 Old 03-30-2011, 10:13 PM
you'll be fine...it's all in the tune
chinopsu is offline
post #16 of 27 Old 04-01-2011, 02:25 AM
WhiteLX's Avatar
I like to drive to the track and it's 90 miles each way. e85 stations are few and far between here. Believe me, if we had more of them, especially within a reasonable distance of the track and somewhere along the way, I'd be running e85 since there are two within a few miles of my house.
1992 5.0 coupe - TTI single turbo
1986 Merkur XR4Ti - 2.3L turbo
WhiteLX is offline
post #17 of 27 Old 04-01-2011, 03:49 AM
I've taken my 600RW Cobra on plenty of road trips last year...boosted, 6 speed, navigation....way more fun to drive than a Prius...
chinopsu is offline
post #18 of 27 Old 04-01-2011, 01:16 PM
huafist's Avatar
Only if everything remains static ; lower compression allows you to turn up the boost higher, and you'll gain more power from the extra boost than you will from 1/2 point of compression.
huafist is offline
post #19 of 27 Old 04-01-2011, 01:58 PM
Cansogo's Avatar
Don't you guys know......High Comp & boost is the new thing! 11 12 13 to 1 with boost
It's cooling, timing & a built bottom end!......2V 4V & LS are great platforms! stock 302 blocks are the weak link I think in most of our combo's......I'm on the hunt for a 6.0L for my fox & I'm going to try 11.1 comp 15-20#'s & meth all for 5K or less...Of course once I split the block...But I did find a CHEAP LQ9...hummmm?
Late 30's not so fat anymore white guy drivin a Turbo 5.0.....15 years TOO late
09' G8 GT tune & 100 shot 12.2's
67 Nova LS1 MS3 150 shot...11.2's
2003 pink Barbie jeep....Cause the girls LUV it!
Cansogo is offline
post #20 of 27 Old 04-01-2011, 02:09 PM
Trader Feedback: (33)
The 4.6 DOHC going in my cobra made 779 rwhp with 9.5:1 compression on pump gas, no meth.
1987 Saleen clone: 358cid, FoxLake Vic Jr's, Victor 5.0, YSi, etc, etc, etc
809rwhp on pump gas + meth injection
"Just turn the boost up.....it's only air."
tireburner163 is offline
post #21 of 27 Old 04-03-2011, 12:31 PM
I ran 10:8:1 compression and ran pump gas with no issues... you are just limited on pump gas until you detonate. I can tell you right now that you can take and build two motors identical minus the compression (one higher and one lower) and the one with higher compression will make more power per psi then the lower compression motor. The higher compression motor will also spool the turbo quicker and have better transient responce.
turbonotchcoupe is offline
post #22 of 27 Old 04-03-2011, 01:35 PM
Yes u "old guys" need to step up ur car game. We now run high compression AND high boost. I run e85 I don't worry about detonation, heat or compression I worry about these lame ass 5.0 blocks, but a 5.8 block is just as strong as a LS block.
post #23 of 27 Old 04-03-2011, 08:09 PM
huafist's Avatar
The mod motors are a completely different animal, and from what I've seen do respond better to higher compression.
However, for most engines, what I said is true. Lower compression and higher boost will make more power than higher compression and lower boost.
That being said, the valve events are more critical than the static compression.
huafist is offline
post #24 of 27 Old 04-03-2011, 11:15 PM
what your saying is a little misleading! It all depends on the gas you wanna run! If you wanna make 800whp on pump gas then of course you cant run 11:1 compression. you would need to run 9:5:1 or lower preferably in the 8:8:1 compression area. If you only plan on making somewhere in the 600whp level 10:1 compression should be fine with a good tune. now if you are running race gas and know what you are doing you can run 13:5:1 compression on a turbo car. There are alot of outlaw cars that do this(sport comact) but its all the same principle. these guys are making 800- 1300whp out of four cylinders on high compression and race gas. using between 67mm up to 72mm turbos
post #25 of 27 Old 04-04-2011, 11:36 PM
9.5 is good for 500-600 not too low not too high.my old 02 z06 had 10.5 compression and I ran 10 psi on it at 605rwhp on pump no meth
93 Teal Cobra- precision 67mm turbo
00 Formula
02 Z06 supercharged(sold)
SuperZ is offline
post #26 of 27 Old 04-05-2011, 11:07 AM
huafist's Avatar
It's not misleading at all ; it holds true the same. The window in which is applies is just different.
But like I said, static compression is really a useless number. The valve events will determine the cylinder pressure (and resultant power output).
huafist is offline
post #27 of 27 Old 04-06-2011, 04:46 PM
Mod motor is only different cause it uses AL heads and is slightly more efficient by design. You are right lower compression and higher boost SHOULD make more power than high compression and lower boost, BUT if u run high compression AND high boost You will ALWAYS make more power.
Keep motors alive drive on e85!
In my mind 15-20psi and 13.5 compression is EASY.....E85/E98.
TURBOSMART "e-Boost2 " Electronic Boost Controller *Corral Specials* PowerAdder Solutions Electronics and Entertainment 256 05-18-2015 03:57 PM
Pre-injection vs Post injection (Boost levels) Michael Plummer Superchargers 1 03-20-2011 03:55 AM
For Sale Apexi AVCR boost controller 95stangsvt Electronics and Entertainment 0 03-09-2011 11:22 PM
Im i good for 500-550 rwhp with this fuel system ? the_bock General Mustang Tech 16 12-20-2010 02:13 PM
going retro.. -tang Lounge 51 12-16-2010 01:47 PM
