Moost boost on pump gas - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 09-03-2010, 11:02 PM Thread Starter
91 octane gas
9.1:1 compression
4.6 motor forged bottom end.
Whats the most boost I can run on 91 octane?
Also methanol a good option? Like reliable enough for a daily driver?
1loudsuv is offline
post #2 of 8 Old 09-03-2010, 11:04 PM
bwaite's Avatar
my buddy gots 701rwhp at 26lbs on his cobra on 91 with meth
2004 Mustang Sonic Blue - turbo- - MMR 4.75 900
bwaite is offline
post #3 of 8 Old 09-03-2010, 11:10 PM
Ski-Dad62's Avatar
I'm running 15 lbs of boost on 91 octane - 475 rwhp no meth.
2003 Centennial Edition
MMR 1000 Vortech YSI Powered
Ski-Dad62 is offline
post #4 of 8 Old 09-04-2010, 12:13 PM
2002mustanggt's Avatar
I'm at 11-12 psi on 91 octane, 20 on 100 octane. 12 psi still makes 550rwhp
2002mustanggt is offline
post #5 of 8 Old 09-04-2010, 12:19 PM
Supercharger FTL, go turbo and you will pick up 100-150 rwhp with same psi you running with supercharger.
post #6 of 8 Old 09-04-2010, 12:35 PM
Originally Posted by 1loudsuv View Post
91 octane gas
9.1:1 compression
There are a couple factors to consider. 9.1:1 is static compression. Dynamic compression is the number that counts and is affected by static compression, the cam, valve train timing etc. Also 91oct can vary a little. I work in the oil industry and have seen it first hand. Methanol works well but there are potential problems. Clogged nozzles, motor pumping pressure, etc. I got a friend who ran the snow kit on the street and had all sorts of problems that he didn't know about till he heard detonation. Imo run conservative boost level or get it tuned with 91 then run a couple gallons of 100 as a safety margin.
T70Cobra is offline
post #7 of 8 Old 09-04-2010, 01:32 PM
i run 20lbs on 93 with 15degrees timing.
'01 GT:
YSI, 20lbs
89 LX:
347 stock
2001sleeper is offline
post #8 of 8 Old 09-06-2010, 12:23 AM Thread Starter
What rings do you guys would work better? Its a daily driver and gonna run 15lbs for daily and 20+ on race gas
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
1loudsuv is offline
For Sale Kenne Bell Boost-a-Pump/Boost-a-Spark gmkillr Fuel System & Related 17 09-30-2010 10:24 AM
Kenne Bell Boost-A-PUMP / Boost-A-Spark Chris Doss Modular Engine Parts 2 12-24-2008 05:29 PM
Kenne bell boost a pump and boost a spark. Big Top GT SVT & DOHC 7 12-02-2005 02:42 PM
Kenne Bell Boost a pump / Boost a spark Chris Doss Electronics and Entertainment 4 08-13-2005 11:57 PM
Opinions needed - Boost-A-Spark/Boost-A-Pump Tat98Cobra SVT & DOHC 7 08-17-2003 08:15 PM
