how to hook up coolant for turbo - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 17 Old 09-02-2010, 03:52 PM Thread Starter
lechols155's Avatar
hi ive search some and didnt find any answers.
where is the best place to tap into for a coolant supply and return for the turbo
thanks larry
92 gt
Old setup: 100% stock w/ turbo 10.80 @ 126
lechols155 is offline
post #2 of 17 Old 09-03-2010, 02:17 PM Thread Starter
lechols155's Avatar
92 gt
post #3 of 17 Old 09-03-2010, 05:42 PM
the pony boy's Avatar
Trader Feedback: (21)
Don't u mean oil?
1993 notch lots of stuff and never done.doesnt run rite!!!!!
1990 33000 mile lx hatch.lowered,5 lugged,full exhaust,explorer intake with 65mm tb.next springs daily driver with a/c and sunroof!!!!
2001 red lightning. full obx exhaust punisher valve body!!!!!
the pony boy is offline
post #4 of 17 Old 09-03-2010, 05:54 PM
pkstang's Avatar
Trader Feedback: (162)
Originally Posted by the pony boy View Post
Don't u mean oil?
he might have a bb turbo which would require both oil and coolant lines to it
i'd also like to know...
pkstang is offline
post #5 of 17 Old 09-14-2010, 09:36 AM Thread Starter
lechols155's Avatar
yes pkstang i do have a bb turbo, they have both oil and water hook ups. i still not sure of the easiest stop for the feed and return. im thinking of just routing the feed for the heater core threw the turbo first. if anyone has hooked one up let me know how you did.
thanks larry
92 gt
post #6 of 17 Old 11-21-2010, 11:14 PM
stanger8995's Avatar
thanks larry
im interested in this topic also. Kinda slipped my mind untill i read this. I dont see why the heater core feed idea wouldnt work.
stanger8995 is offline
post #7 of 17 Old 11-22-2010, 08:37 PM
I tapped a fitting in my thermostat housing and returned it into the block drains.
tt30250 is offline
post #8 of 17 Old 11-22-2010, 10:36 PM
that sounds like a better idea. what size line did you run?
post #9 of 17 Old 11-23-2010, 07:56 PM
-6 if memory serves (pretty sure thats right)
tt30250 is offline
post #10 of 17 Old 11-24-2010, 12:02 PM
How much flow does it really need? Could you use the lines that go to the TB stock? A guy I knew who built a turbo 4cyl actually put Ts in the upper and lower radiator hose and ran them straight from there. It worked
Turbocharged 87 GT T Top
XBL Tag: Mikemachine812
MJs89GT is offline
post #11 of 17 Old 12-04-2010, 10:49 AM
ncontt's Avatar
X2 that's how it was on my INCON TT kit....
click me
look on diagram 7 for a pic of how the coolant lines were run on the Incon TT kit
~~Project OMG RUKIDN ME?~~
built aod, 03 Mach I rims, Pony Down Stage 3 Kit,Tokico 5 way illumina's, Systemax upper/lower,indiglo gauges, Pa 130 amp alt., various phantom gauges, 331 B50 Block, Forged internals,TFS stage 2 heads/cam and 4 doors of FUN in a 79 Ford Fairmont
ncontt is offline
post #12 of 17 Old 12-04-2010, 11:21 AM
millhouse's Avatar
In many cases, as long as there is enough space around the turbo CHRA...hooking up the coolant lines isn't necessary. The reason the Incon kit's had them was in part due to the way they were packaged...I.E. everything compacted close to the engine.
I would say that if you plan on hooking them up, you need to make sure that you have some sort of electric pump that will kick on when you shut the car down to prevent the coolant present in the CHRA from simply boiling ....which could also prevent coking of the shaft/bearings.
2016 Ruby Red Mustang GT PP
Prior Cars
millhouse is offline
post #13 of 17 Old 12-04-2010, 06:18 PM
Ive been getting mixed answers on that also. Some say run the coolant to the turbo since it was designed to have it, others say it is not needed.
post #14 of 17 Old 12-04-2010, 06:32 PM
and thanks for that link to incons install diag
post #15 of 17 Old 12-04-2010, 06:59 PM Thread Starter
lechols155's Avatar
from what i have read its all on how much you use the car. i never hooked mine up but my car is only a track car. but if i had a street car i would hook it up
92 gt
post #16 of 17 Old 12-06-2010, 07:01 PM
stangbanger88's Avatar
my buddy has a bb turbo on his car, this is what he did. took the metal heater lines that go to the heater core an removed the one that didnt have the sensor. (used a cut of wheel) an replaced that with a line to the turbo the from turbo to the port on the water pump. if you could find out what way the water runs in the lines you could use the heater core like a cooler for the turbo. if you dont have a heater core just run the lines from the water pump an call it a day. hope that helps. an the sound of a BB turbo is amazing just like a jet fighter on take off!
stangbanger88 is offline
post #17 of 17 Old 12-13-2010, 11:52 AM
Here are some instructions that we made for our universal water line kits. Hopefully this helps.
http://www.turboneticsinc.com/sites/...0kit%20ins.pdf
TurboneticsRW is offline
Turbo + coolant = any damage? 71chevellejohn Turbochargers 4 07-22-2010 01:15 PM
coolant line for bb turbo mikeextrafast Turbochargers 0 07-02-2010 06:41 PM
Cobra EGR coolant hook-up MamasGT 5.0/5.8 Engine Tech 1 05-27-2010 04:47 PM
coolant lines on turbo eighty8gtfiveo Turbochargers 14 03-12-2008 02:03 PM
How does a down pipe hook to this turbo (pic inside) sprayit Turbochargers 0 02-18-2003 10:20 PM
