#2 Plug fuel foul and fuel smell in oil - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 08-30-2010, 01:38 AM Thread Starter
93BLKNotch's Avatar
So like the post says
Turbo mustang 42lb injectors pmas blow through maf.
Anyways. I pulled my plugs to change them and I notice that #2 is complete black rest brownish. I then changed the oil and notice a smell of fuel. What could cause this?? Also when I start my car cold starts right up. but after i shut it off and start asap car will not start unless i pump the peddle. changed regulator, and fuel gauge holds a strong 40psi after i shut off for a while. So whats the problem??
Stuck open injector?
Rings?
Im stuck. Thanks
93BLKNotch is offline
post #2 of 4 Old 08-30-2010, 05:07 PM Thread Starter
93BLKNotch's Avatar
Can someone please help me????
post #3 of 4 Old 08-30-2010, 06:49 PM
Maybe a sticking injector?
post #4 of 4 Old 09-02-2010, 09:42 PM
privatejoker's Avatar
I would start by swapping the position of that injector, see if the brown plug follows it. If not, tear it down.
privatejoker is offline
AN8 fuel line problem -fuel smell when parked smokingtz General Mustang Tech 5 12-28-2009 10:00 AM
Fuel smell inside car & lots of pressure underneath fuel cap... 66COUP General Mustang Tech 24 03-06-2004 10:29 PM
Raw fuel smell from engine.. fuel pressure regulator?? vreverdito General Mustang Tech 8 11-10-2003 05:24 PM
Will VP C-16 race fuel foul O2 sensors? gasguzzler 5.0/5.8 Engine Tech 14 04-12-2003 01:46 AM
Why does only one plug carbon foul? mat50ho 5.0/5.8 Engine Tech 11 11-22-2002 10:30 AM
