help with fuel system for 800hp - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 08-28-2010, 01:51 PM Thread Starter
I have been doing a lot of research for the fuel system on my turbo fox on a budget. Looking for a go or no go on this setup. Run current walbro intank 255 to an inline 255 pump. I was going to disconnect the line to the fuel filter and use that to feed the 255 inline. Then run a 10 micron fuel filter with -8 line off the inline pump to a set of aftermarket 1/2" rails. Then run a -6 back to the tank. Building a 331 fms r block based setup with tfs heads/f cam. Running a 76mm garrett. Looking for 700hp on kill mode. 550 around town..
noslow_306 is offline
post #2 of 9 Old 08-30-2010, 12:55 AM
goatnipples2002's Avatar
Trader Feedback: (22)
U need more or bigger pumps.
goatnipples2002 is offline
post #3 of 9 Old 09-03-2010, 09:42 PM
Get a complete system from Behind Bars Race Cars and be done. Call Chris and tell him Dale sent you for a good price. Tanks are a thing of beauty!!
http://wzyht.xdysv.servertrust.com/P...CICS8793-41402
I came, I saw, I gave her a towel......
bigd3077 is offline
post #4 of 9 Old 09-04-2010, 03:14 AM
Yeah cause $2300 is totally worth it to spend on a fuel system. HELL NAW! The dude only wants 550-700. Double Intank or inline walbros will handle that.
post #5 of 9 Old 09-05-2010, 11:52 PM
i have a walbro HP 255 intake and a Trex inline. With a -8 feed line from fuel filter up to BBK rails.
Also i have a Boost a pump on the intank pump.
I can support 630hp and 717tq to the wheels on E85. And i havnt seen any pressure drop yet. But that was at 15 psi, im shooting for 20 soon.
88 GT convert.
- Dart block 347 stroker. 9.5:1 comp. Vortech V2-sq on 8#. AFR 205, custom cam, Track heat. long tubes, SCT3000, 60lbs injectors. Custom Air/Air FMIC. 373's with Nitto DR's on Cobra R's.
500hp 500tq. On a mustang dyno.
v8tiger is offline
post #6 of 9 Old 09-06-2010, 08:28 AM
True, but I would rather over kill and be safe when it comes to fuel. If he talks to Chris, he may give him a better deal....
bigd3077 is offline
post #7 of 9 Old 09-07-2010, 03:13 PM
slothy is offline
post #8 of 9 Old 09-07-2010, 05:02 PM
Stock sumped tank with A1000 pump -10 feed -8 return and never look back...
93coupee is offline
post #9 of 9 Old 09-18-2010, 09:31 PM
chris123's Avatar
Trader Feedback: (43)
Stock tank, -10 insert in place of factory pickup, y-block to 2- Walbro 255's y-block to -10 feed to y block to -8s feeding both rails and -8 return.
358 cid Dart block (8.2 deck) foxlake ported Victor Jr's
Victor 5.0 Anderson b4 cam BBK long tubes TKO 600
Anderson Motorsports YSI 8/2.95 10 rib setup
755RWHP @ 6750 RPM'S on pump gas & meth
chris123 is offline
help with fuel system for 800hp noslow_306 Turbochargers 0 08-28-2010 01:33 PM
800hp fuel system complete dmrtlr Fuel System & Related 3 02-03-2009 07:34 AM
800HP fuel system OneFastPony89 Fuel System & Related 0 10-18-2007 07:07 PM
Fuel system supporting 800HP? Mustangous General Mustang Tech 12 03-04-2005 01:39 PM
94-95 Fuel System Good For 800HP GlennSullivan Fuel System & Related 0 04-14-2004 07:04 AM
