Would a trickflow stage 3 cam work good with a turbo? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 08-27-2010, 10:27 AM Thread Starter
stng5pnt8's Avatar
I picked up a tfs stage 3 cam that I was going to be running on my car.
(I bought it thinking it was a stage 2 until I double checked the part # & realized it was a stage 3)
My setup was going to be:
n/a
Victor 5.0 intake
tfs cnc twisted wedge 205 heads
1.7rr's
long tubes w/3" exhaust
ud pulleys/msd digital 6 etc....
Well I ended up just realizing that I would just go turbo instead.
I currently have a b303 cam in the motor & I am trying to figure out if the tfs3 cam would be worth putting on or should I trade the cam for like a stage 2 or just leave the b303 cam?
I am looking @ getting a on3 turbo kit & run about 12lbs of boost.
I have a tfs street heat intake at the moment; should I swap out for the ported victor 5.0?
I've ran a e303 cam before on a turbo car & it did great; but I don't know too much how to figure what kind of cam would be good for a turbo car.
(car is a 5speed btw w/3.27 gears running 18" Mickey t. drag radials if that matters any)
thanks.
tony
1967 Mustang Coupe H/C/I
Sold
1986 T-top GT supercharged
Sold
1986 GT
Sold
1990 GT
Sold
1987 H/C/I GT
Sold
1995 Kawasaki Ninja (totaled
92 COUPE H/C/I SUPERCHARGED 302 w/450rwhp with a lil ol powerdyne w/6lbs of boost!!!
SOLD
92 Black GT Coming soon! to a track near you!!
95GT H/C/Ikinda slow...
but it has a F.A.S.T b2b
stng5pnt8 is offline
post #2 of 5 Old 08-27-2010, 12:15 PM
Trader Feedback: (33)
If the car has a stock block in it, just run the stock cam.
1987 Saleen clone: 358cid, FoxLake Vic Jr's, Victor 5.0, YSi, etc, etc, etc
809rwhp on pump gas + meth injection
"Just turn the boost up.....it's only air."
tireburner163 is offline
post #3 of 5 Old 08-27-2010, 12:53 PM
MATLOCK's Avatar
I have a stage 3 TFS cam in my 302 and it's stellar....you will not be disappointed! made 543hp on 9.5lbs of boost on 93 octane.
setup as follows...
TFS twisted wedge heads (ported & polished)
TFS R-series intake
75mm throttle body
trick flow 1.7 rockers & crane cams lifters & valve springs (valve reliefs cut in pistons needed)
upper & lower girdle bracing....stock block,crank,rods.
MSD6AL, MSD billett dizzy
SCT 4 way chip
car is ridiculous on the street but so fun to drive!
http://www.youtube.com/watch?v=v7J1uc3ClYc
TURBO'D NCR 302 G.R.E.A.D. TUNED
MATLOCK is offline
post #4 of 5 Old 08-27-2010, 02:20 PM
i would be willing your would see a better power curve with teh stock cam. the TFS stage 3 is a for highly modified N/A applications. the stock cam s have more exhaust duration to help teh turbos spool better. a turbo cam would be the best bet.
Willy Mo is offline
post #5 of 5 Old 08-27-2010, 02:28 PM
FreakingStang's Avatar
setup as follows...
TFS R-series intake
75mm throttle body
SCT 4 way chip
What were the TQ numbers and what's the car run?
My buddy;s combo consists of a stock roller block, 306, E303 cam Eddy Performer RPM intake, TFS TW's TEA ported 190cc. 67mm Precision. Car made 526/626 on 10lbs and ran 10.30's
03 SB cobra Vert 474 RWHP 495 RWTQ 11.70's on 18"s
86 GT VERT July 05' Badass Mustang of the month. Just another stroked and blown topless bitch
1966 Coupe Project Jackstand
FreakingStang is offline
Trick Flow Stage 2 cam no good for turbo car?? Rich G Turbochargers 23 04-04-2009 07:48 AM
TrickFlow Stage 1 a good cam for S-trim? zbantam 5.0/5.8 Engine Tech 1 08-01-2008 02:01 AM
trickflow stage 2 good blower cam? fastwhite86gt Superchargers 7 10-04-2005 06:25 PM
will gt-40 turbo swirl heads work good with my combo gtconv 94/95 Tech 4 01-06-2005 11:46 PM
will a turbo work good without a cooler 393stroker Turbochargers 12 12-09-2003 07:27 PM
