What are good good reading on a Wideband W/turbo - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 08-25-2010, 08:46 PM Thread Starter
vorga's Avatar
I have a On3 Turbo on my 02 GT and was wondering what my wideband readings should be? I was told by my tuner 12-12.5 at WOT (just about impossible to look at while at WOT)but what should the readings be while just driving or sitting at the light ? Im seeing around 14.5 . The car smells like its running rich at times.
I also have flomaster 44s and am wondering if they are hurting my setup being chambered mufflers.
2002 MustangGT,FRPP 70mm TB,TF plenum,1/2" Intake/plenum spacer,Qa1K member A arms,UPR Coilover,UPR 4Bolt CC,Tokico HP's,FL subframe connectors,UPR torque boxs,SVT Focus Fuel Pump,BAP,42lb injectors,Magnapacks,SCT X3,Pro-5.0 Shifter,3:55 Gears,On3 MP Turbo T70,EboostStreet,446whp/511wtq
vorga is offline
post #2 of 4 Old 08-25-2010, 09:10 PM
bwaite's Avatar
well im soon going to write a good write up about this. im having chris from "Power adder Solutions" tune my car. (very great guy) just dont rush him....hahaha
every tuner does have there own ideal WOT a/f ..... i have run nitrous, blower, and now a turbo. i like my a/f readings to be in the 11.0 / 11.5 range. thats best for street use. and a lot safer on the motor. but thats me. hope this helps you out.
also message chris, or give him a call. im sure that he can work with you.
bwaite is offline
post #3 of 4 Old 08-25-2010, 10:07 PM
conbread's Avatar
Trader Feedback: (60)
i would also say 11-11.5 and not killing ####.. But timming also plays a factor...
conbread is offline
post #4 of 4 Old 08-25-2010, 10:43 PM
turbocar's Avatar
I've got 19* timing with 5lbs of boost, and my wideband and datalog are showing 11.5-11.8. thats where my car did great. But i know every car is different.
1993 GT 357W T76
turbocar is offline
Good reading NOVIDLX Lounge 4 02-21-2010 07:29 PM
Good reading....... Daywalker Politics 0 04-18-2007 05:01 PM
This is some good reading Daywalker Politics 1 09-02-2005 05:17 PM
Good DOHC 4.6 reading??? Diabolic SVT & DOHC 12 01-02-2005 03:38 PM
Detonation Detection slantman 94/95 Tech 1 01-20-2003 10:14 PM
