inputs on stock bottem end 351w. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 08-24-2010, 11:02 PM Thread Starter
turbocar's Avatar
I have a 351w fuel injected out of a 1989 ford e150 van. this is the first of two that i will use. this one i plan on throwing in and using for now while the second gets built. aside from the obvious like changing my hotside, intake, distributor and pan, will the factory bottem end be fine under boost? and will stock pistons clear 2.02 valves. cam will only be around .512 lift. if i missed anything please let me know.
1993 GT 357W T76
turbocar is offline
post #2 of 9 Old 08-25-2010, 08:43 AM
SMOKEDYA's Avatar
Are they both 89 motors?I think the valve will clear,but i wouldnt take anyones word check the PTV clearence.Use the tootsie roll trick it's cheap and inexpensive.The 351 are good for around 700.
SMOKEDYA is offline
post #3 of 9 Old 08-25-2010, 11:13 AM Thread Starter
turbocar's Avatar
No, one is a 89 and the other is a 72. I'm just gonna swap my heads over to the 89 and put it on 10lbs for now
1993 GT 357W T76
turbocar is offline
post #4 of 9 Old 08-25-2010, 11:30 AM
Gearhead559's Avatar
older block's are stronger.. i would hope that is the one you are building!
casting numbers starting with c9 and d0
the later blocks are not much stronger then the 5.0 blocks
and e7 heads wont just fit. the 351w use's 1/2 heads bolts vs the smaller 5.0 bolts. best bet is to have the head bolt holes drilled out.. but atleast try to find some gt40 heads from a truck. e7 barely move enough air for a 5.0, let alone 5.0 extra cubes
Gearhead559 is offline
post #5 of 9 Old 08-25-2010, 12:45 PM
couperdude's Avatar
Trader Feedback: (30)
Everything I've ever heard was the 351 is a good deal better than the 5.0. I would rather run a 351 at 500hp all day than a 302 at that level.
couperdude is offline
post #6 of 9 Old 08-25-2010, 01:04 PM Thread Starter
turbocar's Avatar
I'm not using E7 heads, there vic jr's. they have 1/2 bolt holes already. For the intake I'm going to keep my pro products typhoon and just get. 351w lower. I just want to see if anyone has used a a351w bottem end before with any issues.
1993 GT 357W T76
turbocar is offline
post #7 of 9 Old 08-26-2010, 06:36 AM
couperdude's Avatar
There's a thread on here somewhere with several folks saying they are running stock motors with hypers and no issues. The general concensus is you should keep boost low, somewhere around 10lbs or so.
post #8 of 9 Old 09-16-2010, 07:43 PM
There have been many "newer roller" blocked 351's make 800+rwhp. The 351 block no matter what year is a lot stronger than a 302. If your going to lean on it you should look at getting some pistons and rods.
Here is a link to one of them.
http://www.theturboforums.com/smf/in...?topic=84871.0
chiaj144 is offline
post #9 of 9 Old 09-17-2010, 02:53 PM
Everyone keeps saying its good to 700hp, but they don't read that he is retaining the stock bottom end.
So, you prolly want to keep it at about 10lbs.
1992 Mustang Coupe 5.0 5 speed
lancec2c30 is offline
What will an 02 3.8 stock bottem end hold up to? SiStang Six Shooter 1 02-07-2007 03:33 PM
Tfs stage 2 cam with stock bottem end? daigostang 5.0/5.8 Engine Tech 11 01-24-2006 05:18 PM
AFR 185 on stock bottem end 94 mattred90gt 94/95 Tech 9 07-09-2005 08:16 AM
Rebuilding stock bottem end. What are my options 87 LX 5.0/5.8 Engine Tech 2 10-02-2003 06:04 PM
largest cam stock bottem end 302 can take??? Joe95stangGT 5.0/5.8 Engine Tech 20 05-09-2003 02:27 PM
