Why does my bola cat back sound like butt underload w/turbo - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 16 Old 08-21-2010, 11:15 PM Thread Starter
bwaite's Avatar
My bola stingers sound bad underload with turbo. It sounds like a six banger. But at idle it sounds great. Anyone know why this is???
bwaite is offline
post #2 of 16 Old 08-21-2010, 11:24 PM
2002mustanggt's Avatar
With exhaust pulse from turbo your catback will not sound like na motor, only thing you hear is whooooosssssas air is moving very fast.
2002mustanggt is offline
post #3 of 16 Old 08-22-2010, 05:39 PM Thread Starter
bwaite's Avatar
its just really raspy and pops a lot. what do you guys run for cat back. anyone run just a straight pipe.(replace mufflers-with just pipe.) im trying to figure out another solution. because it really does sound like crap.. thanks brett
bwaite is offline
post #4 of 16 Old 08-22-2010, 06:10 PM
silver03stang's Avatar
If it is raspy and pops alot it could be your xpipe.
1994 Ranger - working on 302 swap, bagged, shaved.
2005 F250SD King Ranch CC - 4.5 in rough country lift, 18s on 33s, tuned, exhaust, intake.
silver03stang is offline
post #5 of 16 Old 08-22-2010, 06:27 PM
Jersey True Street Guy
mcj50's Avatar
Trader Feedback: (84)
Is it a single or twin setup?
An x-pipe is non value add on a single turbo car and I think you could question the validity of an x-pipe on any turbo car.
I run a single race bullet and it sounds sort of "boat like" when not in the boost. Can't say it is the best sound but once you tip into the throttle the turbo speaks for itself.
mcj50 is offline
post #6 of 16 Old 08-22-2010, 07:37 PM Thread Starter
bwaite's Avatar
there is NO x-pipe on it. just a y-pipe.
bwaite is offline
post #7 of 16 Old 08-23-2010, 04:58 PM Thread Starter
bwaite's Avatar
does anyone else recommend another muffler?? of what if i replaced the borla mufflers with straight pipe??????
here are my borla mufflers. im pretty sure there the stingers?? but im not sure
bwaite is offline
post #8 of 16 Old 08-24-2010, 01:04 AM
Borla is a high quality exhaust and should have sounded nice ? If you want to change I love my Magnaflow Magnapack!!
post #9 of 16 Old 08-24-2010, 05:32 PM
Member
Floordford's Avatar
Trader Feedback: (15)
I have the other Borla catback. The one that has larger baffled mufflers. Stingers to me sound like trash even on an N/A car. Idle is okay but any RPM after that and it gets loud and obnoxious.
Sold-2000 GT-bolt ons and suspension. 273hp/ 309ft.lbs.
Good bye old friend
Floordford is offline
post #10 of 16 Old 08-24-2010, 05:48 PM
I havent ever ran that muffler so I dont know what it really sounds like. You could use a resonator before it splits to try and quite it down. Thats what I did on my 2v car and I run single exhaust though with it. With just a single magnaflow it was a little loud for a daily driver so I welded in a race bullet right after the 2nd pipe in the downpipe(after turbo). I really like the single exhaust to the back axle personally but I do have the same setup like you with magna-flow on my cobra
On 3 Performance is offline
post #11 of 16 Old 08-24-2010, 06:01 PM
mcj50's Avatar
Not sure if it is at all relevant but I had a Borla cat back on my 99 GT that I got for free. Hacked the Borla tips off, reinstalled stock tips.
I really did not like the sound of it. Sounded more like a 1967 dumptruck then it did a mustang.
Turbo cars are a whole different ballgame though...
mcj50 is offline
post #12 of 16 Old 08-24-2010, 06:02 PM
i run these cans on my new 4v twin setup! these are not stingers, they're the race mufflers (XR-1) from borla. I run straight downpipe from each turbo to a resonator then to the borlas, no merge pipe. Mine sounds nice and deep tone. This is no help to you since we have 2 completely different setups But you could try adding a resonator before the y pipe to help the sound!
ferfont1 is offline
post #13 of 16 Old 08-24-2010, 06:55 PM Thread Starter
bwaite's Avatar
ferfont1 thank you for the input, now atleast i know what they are. haha. i think i will keep these on, til winter, then switch to the magnapacks over the winter. thanks again for the input. would you think if i put a highflow cat right before the y-pipe, it would help????
bwaite is offline
post #14 of 16 Old 08-25-2010, 04:41 PM
i think either a cat or a resonator will help greatly
ferfont1 is offline
post #15 of 16 Old 08-25-2010, 10:19 PM
where can you buy a ss resonator at?
got9lbs is offline
post #16 of 16 Old 08-26-2010, 05:50 PM
I used a race bullet, they are cheap and worked really well. Picked it up at jegs
cutting out underload woodsrider104 5.0/5.8 Engine Tech 12 01-09-2009 10:36 AM
Ok, so am I alone in the fact 7yr-old girls shouldn't do butt do butt thrusts? Stop&Turnfreak Lounge 46 01-12-2008 08:23 AM
Intake backfiring, surging underload, etc... Cobra5.0Jeep 5.0/5.8 Engine Tech 4 06-27-2006 12:59 AM
Stut brace install: Does the car need to be underload? teamtruett General Mustang Tech 1 05-03-2006 09:30 AM
help my ignorant butt build a turbo 347! lots of ??'s help is appreciated First5.0 5.0/5.8 Engine Tech 9 03-29-2002 01:11 PM
