Are front and rear o2's different??? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 08-20-2010, 07:10 PM Thread Starter
bwaite's Avatar
i just installed a turbo kit and my front pass. side o2 got snaped off some how. just wondering if i could use one of the rear o2's. i have it in there now. seems to be working ok. but havent tuned the car yet. thanks brett
bwaite is offline
post #2 of 10 Old 08-20-2010, 08:56 PM
Gearhead559's Avatar
they are the same on 99-04 cars....
Gearhead559 is offline
post #3 of 10 Old 08-20-2010, 09:10 PM Thread Starter
bwaite's Avatar
thank you sir. i thought so.. because they looked exactly the same. the only difference is length of wire i believe..
bwaite is offline
post #4 of 10 Old 08-20-2010, 09:20 PM
i've got a 00' and my tuner (PSI) said they are different
ferfont1 is offline
post #5 of 10 Old 08-21-2010, 09:54 AM Thread Starter
bwaite's Avatar
anyone else have any info on this???
bwaite is offline
post #6 of 10 Old 08-21-2010, 10:54 AM
call the parts store, or go online and look them up..part number are all the same.. then print and show your tuner
post #7 of 10 Old 08-25-2010, 05:10 PM
Not sure where you get your info, but this is straight from ford. Why would they make the front ones green and the rear ones purple if they were the same? You have to shave off a tab for the rears to fit the front connectors too. All the rears do is check and see if the cat is working properly, the fronts give feedback to the ecu.
Part Description: 2V and 4V; Located in front of converter
Part Number: 9F472 (DY-834)
Manufactured By: Motorcraft
Part Description: F6DF-9G444-AA, LH & RH (Rear)
Part Number: 9G444 (DY-1086)
http://www.fordparts.com/Commerce/Ca...WLK+LH7viyyDAr
ferfont1 is offline
post #8 of 10 Old 08-25-2010, 07:09 PM
I was at Advanced the other day and they said they have the same part numbers as well. So I used them in my notch and never had any issues and looking at the o2's when it was being tuned it looked normal
I believe it was Bosche o2's that we were looking at
On 3 Performance is offline
post #9 of 10 Old 08-25-2010, 07:53 PM Thread Starter
bwaite's Avatar
update--- when i took my car to the ford dealer. the front and rear o2 ARE THE SAME!! the rears are to check to see if cats are working, yes. but if you plug those exact same sensors in the front, they will respond to your pcm. i have my car tuned with the rears in the front. and nothing has changed. the only difference in the part numbers is the length of wire of the o2, thats it. but thank you all that already new, so now we all know. thanks brett
bwaite is offline
post #10 of 10 Old 08-25-2010, 08:43 PM
did i say call ford? no i said call the parts store didnt i.
but as every one else has already said, they are the same...
Want To Buy Stock fox front/rear springs and complete front swaybar thebuckaman Suspension 0 06-21-2010 12:37 PM
Is code P0156 the Rear or Front Diver side o2? Dallas mustang says it's the front. Z.A.P. SVT & DOHC 1 08-24-2005 05:49 PM
F/S: ASC McLaren Capri front fenders/front bumper assembly/Rear bubble hatch-glass MIKE'SVO Exterior Parts 0 05-22-2005 09:41 AM
MUSTANG GT FRONT AND REAR $80 LX FRONT $35 PLENTY OF VERT GLASS WINDOW MOTORS gruvee87vertgt Exterior Parts 0 03-01-2005 11:11 AM
89 GT parts, hood, front facia, rear bumper, all front lights Doohic722 Exterior Parts 3 07-01-2004 03:02 PM
