Thinking of going turbo.....talk me into it? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 20 Old 08-19-2010, 03:16 PM Thread Starter
I am looking @ the On 3 and Boost bros kits. I have a 96 cobra convertible with the factory K member still on the car. I have purchased a new k member from UPR, will these turbo kits work with it? I have heard that the bracing required on a vert makes it nearly impossible to route the turbo piping. Anyone out there with a 4 valve vert running a turbo? I understand the on 3 kits use the factory exhaust manifolds??? Do these kits sell with a ball bearing turbo or can they be upgraded to one??? My car has the supporting mods (fuel system, built motor) so how much power/tq could i expect to see running say 15psi??? I am running 9:1ish compression with lightly ported b heads, imrc deletes, stock intake, 60lb injectors and not sure what maf i would use if i went turbo. At what rpm would max boost be reached??? Is anyone running their car without a front mount air to air cooler and running meth injection only??? Any input would be appreciated and thanks .
yfz162 is offline
post #2 of 20 Old 08-20-2010, 10:07 PM
Well, yes, do it. Turbo is cool....
I came, I saw, I gave her a towel......
bigd3077 is offline
post #3 of 20 Old 08-20-2010, 10:13 PM
Noooo. It's horrible. Running a good street gear, pulling wheels up, and smoking the tires at 60 mph. Why do you need that much power ?
10secgoal is offline
post #4 of 20 Old 08-20-2010, 10:20 PM
shine1stang's Avatar
couldnt have said it any better...
97 turbo v6
448hp @15.6psi - 11.09 @124mph
xxxhp @21psi - [email protected] mph
Fastest Single Port V6 Mustang w a Ported Stock Upper Intake
shine1stang is offline
post #5 of 20 Old 08-21-2010, 12:42 AM Thread Starter
OK, you guys have my attention.....what about the on 3 kits or boost bros.???
yfz162 is offline
post #6 of 20 Old 08-21-2010, 12:49 PM
2002mustanggt's Avatar
If you want to spin tire even at 120 then get turbo. On3 kit FTW, not nutt swinging on3, just talking from experience !!
2002mustanggt is offline
post #7 of 20 Old 08-21-2010, 06:32 PM
goatnipples2002's Avatar
Trader Feedback: (22)
DIY for the win.
Turbo = Destroy almost anybody that u race.
No turbo = smile for my taillights.
goatnipples2002 is offline
post #8 of 20 Old 08-22-2010, 09:52 AM
I'm sold!!
bigd3077 is offline
post #9 of 20 Old 08-22-2010, 11:16 AM
WarMachine762's Avatar
I have a boost bros kit. Theres a couple minor fitment issues but nothing you shouldn't be able to handle. After you experience a turbo youll never build an na setup again.
WarMachine762 is offline
post #10 of 20 Old 08-22-2010, 12:54 PM Thread Starter
My current set-up is 3.73 gears, an S-trim pullied for 15psi and an NX Express Proton wet kit that i have not ran yet...... I have it jetted for a 70 shot and possibly go up to a 100 shot. I will be running the nitrous off an rpm switch set at 3800rpm. I went with the nitrous to boost the power down low. Damn centri blower only makes like 6-7psi down in this rpm range. What makes more sense to you guys, this set-up or just ditch it all and go turbo??? If i was running a 3.31-3.45ish gear where would i reach max boost with the turbo kit? I would want to boost to 15-18psi.
Thanks guys
yfz162 is offline
post #11 of 20 Old 08-22-2010, 01:32 PM
Thanks guys
Blower and nx is a good power adder you got there. Blower and 3.73 gear or 4.10 gear will work well for you. If you go turbo then 3.27 gear with tall tire will make it monster , why 18 psi go 20 and never look back. With my built 5.0l stroker with t70 .96 exhaust housing still full spool at 4k rpm with 3.73 gear but most 1-3 gear are useless. Some time soon to go back 3.27 and 28" tire , it should be fun as I can ride boost from 3k to 7k Now my boost comes in about 5 psi at 3k rpm and full to 4k but when boost hits cause of gear I have to shift even at 7k as 4-7k rpm goes way too fast with 20 psi and 3.73 gear.
post #12 of 20 Old 08-22-2010, 10:19 PM
You ever think about going to a .76 mm turbo?
bigd3077 is offline
post #13 of 20 Old 08-23-2010, 01:00 AM
Turbo vs centri w/ juice. Not sure I love my turbo, BUT the centri w/juice is pretty sweet as well. Both have alot of potential.
post #14 of 20 Old 08-23-2010, 01:30 AM
Yup , next tax return .
post #15 of 20 Old 08-23-2010, 01:45 AM Thread Starter
Well, i guess i'm stuck then..... I was going to just sell off the nx and blower for the turbo and then have it tuned. Looks like i will have it tuned for the blower and nx THEN make a decision lol......damnit! I will have the fuel system done by next weekend, so i have til then to make a decision. The only thing i don't like about the nx/blower combo is having to change tunes for the nx and the bottle will run out eventually......turbo will always be there ready for pedal mashing.....
yfz162 is offline
post #16 of 20 Old 08-23-2010, 02:18 AM
Yes sir, for street I use 91 oct turn with 11-12 psi and use 100 oct tune for 20 psi TUrbo FTW!!
post #17 of 20 Old 08-23-2010, 08:41 AM
Ya, I would figure you have reached your limit with that turbo.
bigd3077 is offline
post #18 of 20 Old 08-23-2010, 02:28 PM
21 psi is max for this turbo, turbo didn't want to go any higher .
post #19 of 20 Old 08-26-2010, 10:30 PM
What kind of power u think I'll be making with the 76mm?
cravens02 is offline
post #20 of 20 Old 08-27-2010, 05:10 PM
pkstang's Avatar
Trader Feedback: (161)
enough to put a big s grin on your face every time you take the car out
the only thing i hate is that my turbo car is very quiet which causes lot of tools to think its stock although few have learned including a new GTR that is not
pkstang is offline
Thinking of going turbo 8urzo6 Turbochargers 10 06-04-2009 08:50 AM
thinking about going turbo! bdub_02 Turbochargers 12 11-14-2005 02:07 PM
Thinking about a '99-'02 cobra...talk to me about them... Shifter SVT & DOHC 29 04-18-2004 12:49 PM
Turbo blow-off valve talk, ?'s for blower apps.. Aluminum SVT & DOHC 0 06-14-2003 06:09 PM
Thinking of going turbo Tra2xx Turbochargers 3 09-09-2002 11:03 PM
