front tires are toed in??? help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 16 Old 08-18-2010, 03:45 PM Thread Starter
bwaite's Avatar
my front tires are toed in pretty bad on the top. i have the cc plates adjusted as good as they go. for it to be straight as possible. here a pic. but it looks a lot worse in person. FYI i have qa1 k, upr a arms, upr cc plates. any advice would would help. thanks. cause this looks like ####!!!!!
in this pic it doesnt look bad at all. but trust me it is.. i have the cc plates. adjusted all the over
bwaite is offline
post #2 of 16 Old 08-18-2010, 05:40 PM Thread Starter
bwaite's Avatar
anyone????? couple guys on here has this same setup!! what did you do to correct this??
bwaite is offline
post #3 of 16 Old 08-18-2010, 05:43 PM
silver03stang's Avatar
For toe in you adjust the tie-rods. For camber you adjust the cc plates.
I cant see the pics cause I am on a government computer. If you have alot of negative camber and your cc plates are as far out as they will go then you can try and get a camber bolt kit also. They usually give another degree or 2 of adjustment.
1994 Ranger - working on 302 swap, bagged, shaved.
2005 F250SD King Ranch CC - 4.5 in rough country lift, 18s on 33s, tuned, exhaust, intake.
silver03stang is offline
post #4 of 16 Old 08-18-2010, 05:50 PM Thread Starter
bwaite's Avatar
never heard of a camber bolt kit. were could you guys this??? any info how how it works, or were its installed and how?? thanks bud
bwaite is offline
post #5 of 16 Old 08-18-2010, 06:00 PM
vorga's Avatar
I have a camber bolt on my setup also. It looks like your car sits lower than my car and that will make your tires lean in at the top more . My car sits at 26 1/2 from ground to the fender lip and I still bottom out the piping on speed bumps if not hit on a angle. Also I set my height at 26 7/8 when i did my build a few months ago and its settled to 26 1/2 when i just checked today .
2002 MustangGT,FRPP 70mm TB,TF plenum,1/2" Intake/plenum spacer,Qa1K member A arms,UPR Coilover,UPR 4Bolt CC,Tokico HP's,FL subframe connectors,UPR torque boxs,SVT Focus Fuel Pump,BAP,42lb injectors,Magnapacks,SCT X3,Pro-5.0 Shifter,3:55 Gears,On3 MP Turbo T70,EboostStreet,446whp/511wtq
vorga is offline
post #6 of 16 Old 08-18-2010, 06:30 PM
http://sitesearch.cjponyparts.com/se...s=camber+bolts
CJ's Pony Parts is only about an hour from you.
post #7 of 16 Old 08-18-2010, 06:40 PM Thread Starter
bwaite's Avatar
i just measured im at 26 3/8 on both sides. im gonna jack it too 27inches even. and buy those bolts. that should fix a problem. thanks guys!!!!!!!!!!
bwaite is offline
post #8 of 16 Old 08-18-2010, 07:18 PM
vorga's Avatar
You can try to loosen up the big 2 bolts on the bottom of the struts and pull the top of the tire out . Then tightn the bolts while holding the top of the tire out as much as you can . This is with the car jacked up. Thats what i did but i allready had the camber bolt. I dont know if your going to get enough but it might get you close .
vorga is offline
post #9 of 16 Old 08-18-2010, 07:39 PM
pkstang's Avatar
Trader Feedback: (161)
how is this turbo related...
pkstang is offline
post #10 of 16 Old 08-18-2010, 07:50 PM Thread Starter
bwaite's Avatar
BECAUSE MOST GUYS THATS LEAVING THE COMMENTS HAVE THE EXACT KIT I HAVE. AND THE REASON WHY "RELATED" IS ITS NEEDED FOR THE TURBO KITS!!!!!
thanks for your concern.
bwaite is offline
post #11 of 16 Old 08-18-2010, 07:53 PM
pkstang's Avatar
you're welcome!
what kit is it?
pkstang is offline
post #12 of 16 Old 08-18-2010, 07:56 PM Thread Starter
bwaite's Avatar
crappppppppy qa1 for k member, on3 for turbo
bwaite is offline
post #13 of 16 Old 08-19-2010, 03:49 AM
2002mustanggt's Avatar
Always after big change in suspension get realign !! Go to Sears they have fancy laser with computer that will make your suspension almost to where it should be. Btw you can adjust with tie rod.
2002mustanggt is offline
post #14 of 16 Old 08-19-2010, 01:08 PM
vorga's Avatar
When he says toe in i think he means the tires lean in at the top (neg. camber). But you are correct toe in means the space between the tries in the front of the tire are less than the back of the tire and can adjust with the tie rods. Say you messure the inside the front tires and have 84in and then the back has 85in you would be toed in . If you had 85in in the front and 84in in the back you would be toed out . So i think he means his camber is out and that can be adjusted with the CC plates and Camber bolts. Im still new to all this so if im wrong please correct me .
vorga is offline
post #15 of 16 Old 08-19-2010, 04:04 PM Thread Starter
bwaite's Avatar
well i did as VORGA said. i raised her up little more. it was setting to low for my liking. it was at 26 3/8 i jacked her up to 27 1/4. and what a difference it made. tires are almost straight (up/down) ( camber) i also got camber bolts as well. so when i get them in. i know 100 percent that the issue will be resolved. thanks vorga. for helping me out, for like the 100th time. haha.
bwaite is offline
post #16 of 16 Old 08-19-2010, 05:57 PM
vorga's Avatar
No problem im glad to help . Everyone helped me with my build so its the least i can do .
vorga is offline
315 front tires on 10.5" wide front wheels dogface Road Racing/Auto X 23 11-07-2005 04:56 AM
How much tires pressure for 18" front tires? Z's Cobra Wheels and Tires 4 02-21-2005 08:35 AM
FOR SALE. WELD DRAGLITES 4 LUG 3.5 FRONT 8 ON BACK WITH FRONT TIRES & ET STREETS NC chad casstevens Rims Wheels and Tires 2 10-15-2004 02:55 PM
What kind of rear tires are needed to pull the front tires off the ground? KwikFox Drag Racing 39 08-18-2004 12:56 AM
What size front tires to get for my 10 holes to match the back tires? TommysCarbd86 General Mustang Tech 1 06-26-2003 10:28 PM
