4.10's with my turbo - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 41 Old 08-18-2010, 12:40 AM Thread Starter
bwaite's Avatar
ok so i take it 4.10's are gonna suck, with the turbo. i havent gotten it tuned yet. so dont really know. but i guess i'll be soon swaping them out. to 3.23's or something like that
bwaite is offline
post #2 of 41 Old 08-18-2010, 12:58 AM
ManicMike's Avatar
A 3.27 rear gear is IMO the best turbo gear. Another option would be 3.55 rear.
'88 LX -New mill coming soon.
ManicMike is offline
post #3 of 41 Old 08-18-2010, 02:46 AM Thread Starter
bwaite's Avatar
yea thats what i'll switch to after the tune. right now money funds are getting low!!!!! but for few weeks you think 4.10's be ok. i guess spool time is gonna be really late.
bwaite is offline
post #4 of 41 Old 08-18-2010, 03:44 AM
Gearhead559's Avatar
no, tune it with the gears in it.. its changing the loading effect on the car. or seen if they will check the tune on it, after you swap the gears. most tuners will touch up a tune. and yes, you will hate the 4.10's. 3.27's or 3.55 if running a taller tire.
Gearhead559 is offline
post #5 of 41 Old 08-18-2010, 08:44 AM
Don't forget the 3.31, with it coming in so many 8.8 equipped vehicles you might be able to get a "used" set for cheap.
post #6 of 41 Old 08-18-2010, 03:08 PM
WarMachine762's Avatar
I have 4.10's its not that bad. Turbo lag doesn't feel so pronounced when you have a V8. My turbo spools late in 1 and 2 but once i hit 3 it comes on hard.
WarMachine762 is offline
post #7 of 41 Old 08-18-2010, 03:35 PM
To each their own, I personally can't stand 4.10s in any combo I have ever driven in regards to Mustangs.
post #8 of 41 Old 08-18-2010, 04:23 PM
strokercharged95GT's Avatar
I hate my 3:73s witha turbo and a 26" tire. As stated above, my motor seems to outrun the turbo in 1st and 2nd, but will feel normal in 3rd and up. I will definetely be going to a 3:27 when I can get um swapped out.
2013 Mercedes GLK-350
strokercharged95GT is offline
post #9 of 41 Old 08-18-2010, 04:45 PM
Trader Feedback: (22)
I wouldnt even try to tune it with those gears still in
03 Mustang GT
Turbo 2v
LS1KILR is offline
post #10 of 41 Old 08-18-2010, 05:09 PM
Member
Floordford's Avatar
Trader Feedback: (15)
I was thinking of this the other day. Even though with a 4.10 the engine is going to be doing the brunt of the work out of the hole I wonder if its faster at the track. It may depend specifically on the combo. A 331 twin wont act like a stock 4.6 single.
Sold-2000 GT-bolt ons and suspension. 273hp/ 309ft.lbs.
Good bye old friend
Floordford is offline
post #11 of 41 Old 08-18-2010, 05:16 PM
just get a nasty stalled auto setup!!
ferfont1 is offline
post #12 of 41 Old 08-18-2010, 07:51 PM
3.27 's been tested over and over...
I ran the best with a 3.27 and a 28 inch tire if you've got motor behind it.
otherwise 3.27 and a 26 inch tire.. way way faster then a 3.73 on the same tune.
turbo89 is offline
post #13 of 41 Old 08-18-2010, 08:05 PM Thread Starter
bwaite's Avatar
im gonna get it tuned with 4.10's then swapp to 3.27 in few weeks. i just wanna get it running. i'll take it back for a touch-up tune then later.
bwaite is offline
post #14 of 41 Old 08-18-2010, 10:07 PM
Why waste time and money .. you know it wont be right ...
its like getting a tune when its in the 80's or 90's and 80 % humidity ... whats the point ?
Be patient .. swap the gears... have it tuned as the weather is getting nicer... then have at it.
turbo89 is offline
post #15 of 41 Old 08-18-2010, 10:32 PM Thread Starter
bwaite's Avatar
dannggg. so the gears are gonna hurt me that bad.... geezzz this blows!!!!!! what a freakin money pit. so if i change the gears out after a tune. its going to change my tune that much??? just the gears. im assuming the load will be different.
bwaite is offline
post #16 of 41 Old 08-18-2010, 10:38 PM
2002mustanggt's Avatar
All I can say is I hate my 3.73 and turbo. You not gonna enjoy boost with 4.10 as it will boost and shift time in less then second lol or run 28" tall tire all the time.
2002mustanggt is offline
post #17 of 41 Old 08-18-2010, 10:41 PM Thread Starter
bwaite's Avatar
even in 3rd and 4th gear???????
bwaite is offline
post #18 of 41 Old 08-18-2010, 10:46 PM
if you get tuned with 4:10s and switch to 3:27 I would be hesitant to run it very hard. It could cost you, especially if you have a stock motor
03 Mustang GT
Turbo 2v
LS1KILR is offline
post #19 of 41 Old 08-18-2010, 10:51 PM
3rd gear is almost useless but I can run at 4th gear spinning hehe. Mostly I spin at 120 when 20 psi screaming lol. But you at 8 psi might have fun with 3rd.
post #20 of 41 Old 08-18-2010, 10:55 PM Thread Starter
bwaite's Avatar
would getting a retune after different gears be a big concern. even when the tune is gonna be on the rich side???
bwaite is offline
post #21 of 41 Old 08-19-2010, 01:33 PM
vorga's Avatar
I went from 3.27 to 3.55 and feel like I have more TQ with the 3.55 than the 3.27 . But feel the 3.27 is more comfortable for everyday driving . I also think the 4.10 w/turbo would be like driving a 4x4 in 4 wheel low all the time
2002 MustangGT,FRPP 70mm TB,TF plenum,1/2" Intake/plenum spacer,Qa1K member A arms,UPR Coilover,UPR 4Bolt CC,Tokico HP's,FL subframe connectors,UPR torque boxs,SVT Focus Fuel Pump,BAP,42lb injectors,Magnapacks,SCT X3,Pro-5.0 Shifter,3:55 Gears,On3 MP Turbo T70,EboostStreet,446whp/511wtq
vorga is offline
post #22 of 41 Old 08-19-2010, 03:50 PM
PowerAdder Solutions's Avatar
Trader Feedback: (230)
4.10's would be alot of fun on the street... For your power level and tire size I vote 3.55's but not count out 327's.
Chris
post #23 of 41 Old 08-19-2010, 04:08 PM
kellam's Avatar
i was about to do the same thing as you. turbo ,4:10s and then a clean up tune when i figure out what tire and gear i want to use. i hoped a 28 inch tall tire would help all the spool/gear issues.
89 gt turbo- R.I.P - f#@K TURBO GOING OLD SCHOOL CARB AND NITROUS...... BUILD IN THE WORKS.
kellam is offline
post #24 of 41 Old 08-19-2010, 04:19 PM Thread Starter
bwaite's Avatar
so a take it you are keeping the 4.10s well yea im going to keep mine for rest of this year. get new gears over winter then retune next year. maybe i will like the 4.10, maybe not. but at this point i just want to drive the damn thing. haha.
bwaite is offline
post #25 of 41 Old 08-19-2010, 04:50 PM
kellam's Avatar
me too.
plus im not racing everyday. i may drive my car 5 times a month. so im not so worried about shifting into 5th in the quarter(which is what i think everone is trying to warn you about) but next year im worried about that. ill re tune when i get my c4 put in and the axles, spool and yes different gears.
let me know how you make out. ill do the same.
kellam is offline
post #26 of 41 Old 08-19-2010, 04:52 PM
Just make sure and powershift it into 5th, buddy of mine never could refrain from doing that and killed a number of Tremecs from that nasty habit of his
post #27 of 41 Old 08-19-2010, 05:07 PM Thread Starter
bwaite's Avatar
yea my car will never see the track. just street use.
bwaite is offline
post #28 of 41 Old 08-22-2010, 11:24 AM
all of you that say he needs to get it re tuned after he swtiches gears can you tell him why? Just tell your tuner your plan and I'm sure he can account for that if he's worth his weight.
post #29 of 41 Old 08-23-2010, 05:27 AM
goat-ee's Avatar
Is my car doing it's best with the 4.10's? They tell me no, but with 28" slicks at the track and 315 drag radials for the street, I have no complaints. I'm a hard headed SOB, I want to run 10's on the stock longblock at full weight in my convertible with the wrong f'ing gear and a 5-speed. Not too many stock longblock B-head Cobra's in the 10's, let alone a convertible with a 5-speed. If I get close I don't think it would be fair to say that the 4.10's hurt it that bad. 11.7's @ almost 122mph without the 2-step or electric downpipe cut-out that's on it now. We'll find out this Wednesday night if I can get close to the goal. I also am going to data-log the boost through all the gears and see how much boost it really makes in each gear? Here is a vid at the track with the 28" slicks. (note the slight wheel correction after the 2nd gear shift!!)
http://www.youtube.com/watch?v=mvUIzXOPWcc
And by the way some of the guys saying that 1st and 2nd are useless with the 4.10's are the same guys still on street radials and not drag radials. Once a certain power level is attained it's almost irresponsible to run anything but drag radials on the street!! Is my car a little wild in the 1st couple gears on the street, yea, but not any more so than the guys with 3.27's and street tires.
96 Cobra Vert
NEW SETUP: 60'-1.830, 11.7 @ 121.73. Hellion Single Turbo @ 10psi. UD pullies, timing adjuster, Meziere WP, Bassani Quiet Thunder w/cats, 4.10's, AL driveshaft, 315/35/17 BFG DR's.
New Driver-97 Pacific Green Cobra. Forged, 2.1 Kenne Bell, T-56, 3.73. 12.6 @ 112mph
goat-ee is offline
post #30 of 41 Old 08-23-2010, 07:44 AM
I think most of us saying not to run 4.10s are referring to pushrod motor'd cars and not 2V/4V cars. After all don't you at the very least have more rpms to play with along with more need for some low end grunt?
post #31 of 41 Old 08-23-2010, 08:17 AM
blown8950's Avatar
I had 4.10's in my turbo'd 91 GT convertible. It was a heavy car with a built AOD, and I'm not gonna lie to you and tell you it wasn't hella fun on the street! It was a freakin' blast to drive around, but it revved so quickly it wasn't really letting the turbo work. I switched to 3.55's and went quicker and faster in the 1/8th with the 3.55's because they were letting the motor load and the turbo work. Plus wheelspin wasn't as big an issue, but the 4.10's were loads of fun in the heavy car.
1989 LX: Vortech YS-Trim blown DSS 347, Stage 3 Twisted Wedges, Holley Systemax 2, AFM B-451 cam, AFM Power-Pipe, AFM PMS, 80mm Pro-M, Aeromotive 1000 hp fuel system, Precision Turbo 65 lb/hr injectors, UEGO 1000 Wide Band O2, MSD 6BTM and Distributor, 33-spline Moser axles and spool, Bogart Drag-On Stars, UPR Chromemoly K-member and A-Arms, Kooks 1-7/8", Dr. Gas, 130 amp alt, etc.
1991 GT Convertible: stone stock, PA AOD, Edge Converter, 62mm Turbo, 397 rwhp, 458 lb./ft rwtq @ 8 psi
blown8950 is offline
post #32 of 41 Old 09-19-2010, 08:47 PM
kellam's Avatar
i got the car back from jpc on friday. 4.10s and turbo is awesome.
kellam is offline
post #33 of 41 Old 09-20-2010, 08:15 PM
Bdubya's Avatar
Cool. Give us some info on how it drives if you can. I have a 414w thats getting a 88mm turbo for about 12#s. It too has 4.10s, but i'm gonna be running a 325/50/15 dr. Weekend driver.
Bdubya is offline
post #34 of 41 Old 09-20-2010, 08:41 PM
kellam's Avatar
i like it alot. it gets fast boost and pulls real hard. i could only tune 6 psi because my wastegate is too small. car made 400hp 430tq. its nice not have to down shift to get the car moving
kellam is offline
post #35 of 41 Old 09-21-2010, 05:51 PM
bred2run's Avatar
i have 4.10's right now also and planning to go turbo pretty soon.....Is the drive that bad as people say with the gear or would it be better to go witht he 3.27's???
also what size a/r's are you running on the 60-1?
94 mustang gt (Single turbo build in progress)
mods: Boost brothers 67mm turbo kit, mac flowthru exhaust, gt40 intake, 70mm throttle body, 3pc under drive kit, msd coil, 2700 stall converter, b&m shift kit, full suspension, 3.55's gears
bred2run is offline
For Sale 86-93 Intercooled Turbo kit Ceramic coated T-60 Turbonetics Turbo, Real Nice! 10SEC.LX Power Adders 13 04-06-2010 08:29 PM
The Turbo School will have Precision Turbo as a special guest speaker 4 Dallas class [email protected] Turbochargers 9 02-24-2010 09:54 AM
351w BG CUSTOM TURBO Turbo headers carb, turbo cam,pistons,gaskets,waste gate stang1986 Power Adders 8 03-25-2008 10:55 AM
'90 Notchback w/ turbo hotside (no turbo) for sale on East Coast: $2600 Fast90LXStang Mustangs For Sale/Wanted, 1987-1993 8 09-08-2007 06:37 PM
