on3turbo 2v driver side piping not tight enough with manifolds - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 08-06-2010, 07:02 PM Thread Starter
bwaite's Avatar
i got little problem. the driver side piping that comes off exhaust manifold. will not tighting down anymore so its still loose. any ideas. heres a pix. there are some spacers there. but i cant get them off. i dont even know if there suposed to come off. thanks for your help.
DRIVER'S SIDE MANIFOLD!!!!!
bwaite is offline
post #2 of 12 Old 08-06-2010, 07:34 PM
Member
Floordford's Avatar
Trader Feedback: (15)
Those were a problem when i installed my first o/r X-pipe a while back. That dowel prevented the manifold to mid pipe from forming a good seal. I ended up getting a Dremel with a tungsten carbide bit and just made the necessary adjustments.
Sold-2000 GT-bolt ons and suspension. 273hp/ 309ft.lbs.
Good bye old friend
Floordford is offline
post #3 of 12 Old 08-06-2010, 07:59 PM Thread Starter
bwaite's Avatar
how did you do that with out messing with the threads. did you pull the bolt off to fix it
bwaite is offline
post #4 of 12 Old 08-06-2010, 09:21 PM
Member
Floordford's Avatar
I trimmed down the metal on the flange so the dowel could sink inside of it instead of hitting it.
Good bye old friend
post #5 of 12 Old 08-07-2010, 12:19 PM
vorga's Avatar
Mine was just like yours. I trimed about 1/8 off the pipe mine hasent leaked but I still might buy the adapter from UPR or go to a muffler shop and have them make one. I think trimmimg might of caused the inside of the U on the pipe to sit on the kmember or mabe all the U pipes on the On3 touch. In your pic it looks like your as far in as you can go with out trimming or adding a adaper pipe. im talking about the bottom of the pipe right above the dowel in your pic .
2002 MustangGT,FRPP 70mm TB,TF plenum,1/2" Intake/plenum spacer,Qa1K member A arms,UPR Coilover,UPR 4Bolt CC,Tokico HP's,FL subframe connectors,UPR torque boxs,SVT Focus Fuel Pump,BAP,42lb injectors,Magnapacks,SCT X3,Pro-5.0 Shifter,3:55 Gears,On3 MP Turbo T70,EboostStreet,446whp/511wtq
vorga is offline
post #6 of 12 Old 08-07-2010, 01:32 PM
Blk4V00GT's Avatar
I would recommend the exhaust reducer piece fro UPR, I was gonna cut mine down as some do but think I'm gonna use the reducer so I get the piping as far away from the K and a arms as I can
1994 Mustang GT Coupe....
Blk4V00GT is offline
post #7 of 12 Old 08-07-2010, 07:43 PM
Link for the UPR Exhaust Reducer? I cannot locate it on their site.
acidshn is offline
post #8 of 12 Old 08-09-2010, 01:04 PM
2002mustanggt's Avatar
Look at this picture, called them for just reducer. In between xpipe there is reducer
http://www.uprproducts.com/mustang-o...x-pipe-99.html
2002mustanggt is offline
post #9 of 12 Old 09-20-2010, 05:05 PM
Trader Feedback: (60)
is the reducer just a cone pipe? i'm on the hunt now for a round doughnut gasket that will work. the thing is what ive seen so far is the doughnuts are too thick and might push the pipe too far back.
bullitt15 is offline
post #10 of 12 Old 09-20-2010, 08:06 PM Thread Starter
bwaite's Avatar
the cone adapter is deff. needed its going to leak. it only pushes it back about 3/8 inch
2004 Mustang Sonic Blue - turbo- - MMR 4.75 900
bwaite is offline
post #11 of 12 Old 09-22-2010, 01:33 PM
i replaced the studs with bolts already so i don't really have that issue. having a gasket would insure no leaks and i''m all about that. i'm not sure how well the cone will act as a gasket.
post #12 of 12 Old 09-22-2010, 01:52 PM Thread Starter
bwaite's Avatar
its really no different then a ball and socket joint. thats how most cat back exhaust systems are bolted on. if you make it tight it wont leak! lol
but if you replaced the bolts with studs(w/out spacers) then i wouldn't worry about it cause, the spacers that were on the old studs were the issue, because it wouldn't allow you to draw the 2 pipes together tight enough.
bwaite is offline
Fs: 5.4 turbo kit hot side and cold side piping.. turbovert04 Power Adders 6 03-02-2010 08:06 AM
Hellion Hot-Side Piping Kit 9cobrastang7 Power Adders 1 08-31-2009 09:45 PM
cold side piping RED95GTCOUPE Turbochargers 7 03-23-2008 10:17 PM
Cold Side Piping Scones Turbochargers 9 01-14-2007 06:53 PM
Cold Side Piping LowFast Turbochargers 4 02-08-2006 11:06 AM
