Figure Out This TKO Or Junkyard 4R70W - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 39 Old 07-29-2010, 03:33 PM Thread Starter
Meangrn92GT's Avatar
Trader Feedback: (62)
Ok guys, I've about had it with this TKO 600. It's a complete pile and will not go in third gear. Had two other people drive the thing at the track and the same #### happens. Someone suggested the shifter on them sucks so I bought a MGW, same thing still happens.
What is wrong with this thing, it's like it hits a "wall" when you go to third gear. Swear it's the worst shifting aftermarket transmission I've ever felt. Made a thread before and the carbon fiber rings were suggested to "fix" it but I don't think that's the issue. Reason I don't think it's the issue is because IF you get the shifter in the right place it'll let it go in, but when you go from second to third gear it's like something is moving wrong and you go past third gear and literally have to pull the shifter back towards first gear to get it to go in. Not sure if this is common with these things because all the issues I see are high rpm shifts and things like that, never this "wall" type experience I get.
What are the chances a junkyard 4R70W with a manual valve body will live behind a 500rwhp turbo car for awhile? Being raced prob an average of two track days a month?
What would you all do? BTW, I've always said I'd never convert to an auto(and I wouldn't if I had a good shifting manual) but this is stupid. No point in taking the car to the track if it's never going to make a good pass because of the transmission.
-Dave
1992 Mustang GT
Meangrn92GT is offline
post #2 of 39 Old 07-29-2010, 03:45 PM
talk to Darrin aT bc trans, he seems like the man for 4r70w's. He will be building mine here shortly.
slothy is offline
post #3 of 39 Old 07-29-2010, 06:00 PM
90fiveoh's Avatar
I would still say you would need the 4r70 gone through and put some decent clutches in it and the mechanical diode setup. You will need a convertor too. I'd say sell the TKO and for around 1500ish you could have a nicely setup trans. Check out clickclickracing.com forums. They have some 4r70/aode gurus over there. One guy silverfox even makes valve bodies for them
90 Turbo GT
90fiveoh is offline
post #4 of 39 Old 07-29-2010, 08:25 PM
NoSloCoupes's Avatar
Trader Feedback: (53)
I'm gonna give the stock '00 4R i have a go, i've got everything for the swap...just haven't got around to doing it yet. The converter, manual valve body, and supporting cast/etc were so damn expensive...i can't afford to build the trans yet,lol!!
I said i'd never do the auto swap either, just feel i am and would be leaving too much on the table e.t. wise if i don't.
NoSloCoupes is offline
post #5 of 39 Old 07-29-2010, 09:18 PM
Common problem with tremec trans is 3rd gear.. Luckly mine never did that
93coupee is offline
post #6 of 39 Old 07-30-2010, 10:21 AM
how many miles are on the tranny?
ahurl90 is offline
post #7 of 39 Old 07-30-2010, 10:40 AM
9 times out of 10 the clutch is not adjusted properly.
At least every time my TKO 600 would not shift right the clutch was
not releasing properly.
Clutch adjustment and spacing seems to be critical to make TKO's shift right.
I think TKO's get a bad rep from not being installed correctly
Did you index your bellhousing ? or just bolt it on .........
Are you sure your clutch has proper disengagement ?
Shift stops set correctly ?
r.barn is offline
post #8 of 39 Old 07-30-2010, 11:03 PM
Member
Floordford's Avatar
Trader Feedback: (15)
Wish you were closer. I have a 4R70W with 120k mi. a J-mod and a Precision Industries 3,500 lock-up. Also the aluminum driveshaft to match.
Sold-2000 GT-bolt ons and suspension. 273hp/ 309ft.lbs.
Good bye old friend
Floordford is offline
post #9 of 39 Old 07-31-2010, 10:17 AM Thread Starter
Tranny has around 1,000 miles on it.
Floordford, how much? If you're in TN then you're in driving distance.
I really love the manual, but I really want to try the auto too.
The bellhousing is the aluminum bell so it wasn't indexed. I got a PM from a fellow member who said his TKO had the same issues and replacing the shift lugs fixed it. What all does that entail? I wouldn't care to spend a few bucks to get it right but I really am afraid to spend "a lot" and it still not shift to my likings. Wish it would shift as good as my T5 did, I'd be mucho happy..lol
-Dave
1992 Mustang GT
post #10 of 39 Old 07-31-2010, 10:51 AM
Call these guys and see what they say.
http://www.promotionpowertrain.com/TRANSMISSIONS.html
They make modified TKO 600's they claim are capable of 750+hp and 7,000rpm shifts
r.barn is offline
post #11 of 39 Old 07-31-2010, 12:38 PM
Coilz347's Avatar
I just had www.libertysgears.com go through my tko600 because it shifted like crap too. Wouldnt shift at all above 5500rpm into third and was even tough rowing it into 4th.
They put the newer carbon fiber rings in and did a bunch of there internal mods to it. I'll have it back in about a week and let you know if its any better.
Coilz347 is offline
post #12 of 39 Old 07-31-2010, 12:47 PM
Member
Floordford's Avatar
Im in Antioch which is south Nashville
https://forums.corral.net/forums/show....php?t=1234794
$300 2000 GT 4R70W transmission with J-mod (shift modifier with modified stock parts. Its the best one to use) with fill tube and dip stick
$600 9.5" Precision Industries Stallion Converter. Stall speed 3,500rpm. Multi-disk lock up
$75 Automatic petal assembly from a 2000 GT.
$200 FRPP Aluminum Driveshaft
Good bye old friend
post #13 of 39 Old 07-31-2010, 04:28 PM
Needs the V6 trans bell pattern to bolt up to a 302. Yours is a 3 bolt starter, needs 2 bolt.
post #14 of 39 Old 07-31-2010, 05:02 PM
Member
Floordford's Avatar
Its a 3 bolt
Good bye old friend
post #15 of 39 Old 07-31-2010, 09:35 PM Thread Starter
Yep, exactly.
What exactly is involved in changing the shift "lugs"?
-Dave
1992 Mustang GT
post #16 of 39 Old 07-31-2010, 10:32 PM
Edit, was think fork pads.
Heres a pdf for changing to a mid shift, don't know if it helps...http://www.ttcautomotive.com/english...080107_133.pdf
post #17 of 39 Old 08-02-2010, 07:02 PM Thread Starter
Thanks.
Who do I need to contact about asking what I need to fix this thing to get some prices and opinions? Would I be better off talking to an aftermarket distributor or should I call Tremec themselves?
If it's nothing more than the shift lugs that needs to be fixed, I think I'm going to try and replace them and see what happens. I want an auto setup bad but I want to make some good passes with the manual first and I can't sell this thing if it's not shifting "properly" anyways.
Thanks guys!!!
-Dave
1992 Mustang GT
post #18 of 39 Old 08-02-2010, 07:13 PM
Liberty Gears
MMR Transmission
Promotion Performance
are all respected TKO aftermarket upgraders
see above links. Forget calling Tremec
r.barn is offline
post #19 of 39 Old 08-02-2010, 07:50 PM
Don't forget about Bob Hanlon.
post #20 of 39 Old 08-02-2010, 09:33 PM
Thanks.
Thanks guys!!!
Liberty did mine ... proshifted in 3rd ... clutchless 6K rpm shifts like butter..
noisy but shifted effortlessly...
Ive driven a few cars that had Hanlon boxes... very impressive as well.
turbo89 is offline
post #21 of 39 Old 08-02-2010, 09:39 PM Thread Starter
Thanks.
So I take it Tremecs tech over the phone doesn't help much, haha. I'll let everyone know how it goes tomorrow evening.
-Dave
1992 Mustang GT
post #22 of 39 Old 08-02-2010, 09:50 PM
huafist's Avatar
I vote 4R70W. I think you'll be happier with a good auto in that car, Dave.
huafist is offline
post #23 of 39 Old 08-02-2010, 09:59 PM
What he said !
Auto all the way.. was just pointing out the TKO can be made to shift great.. but Alot easier to drive a 9 second car with a auto... its a walk in the park much nicer to drive..
have a few customers running the V6 4r70w with just shift kits/convertors
and trans coolers running SOLID 10's for a few seasons... tough tranny's
turbo89 is offline
post #24 of 39 Old 08-03-2010, 01:11 PM Thread Starter
This is what I want to hear!!!
How hard is it to find the V6 4R70W?
-Dave
1992 Mustang GT
post #25 of 39 Old 08-03-2010, 01:40 PM
I found one at a yard online, they shipped it to another one of their places that was 15 miles away...picked it up for around $150 if i remember. Out of a '00 mustang so the shift selector is correct. Stay 98+ and make sure it has the speedo splines.
Theres an online yard search somewhere, trying to remember....
post #26 of 39 Old 08-03-2010, 03:38 PM
biminiLX's Avatar
I've gone pretty fast with a synchro'd TKO600, you can search posts here but I had the same problem and Pro Motion fixed it with shift lugs.
You now have the option of those CF blocker rings, so personally I'd do those at the same time if shifting over 6500rpm.
I shifted at 6000rpm and went 9.84 @ 149 after Pro Motion fixed it.
Good luck.
-J
'91 LX hatch
Bimini Blue
427"/88mm at 16 psi
biminiLX is offline
post #27 of 39 Old 08-03-2010, 10:49 PM
Draggin90's Avatar
Trader Feedback: (29)
I have a built 4R70W in mine and love it. I will never go back to a stick. It can shift a lot faster than you can and you don't have a sore left leg after driving all day. I have not made it to the track yet but it is a blast on the street with the stall.
Draggin90 is offline
post #28 of 39 Old 08-03-2010, 11:38 PM
I would call up Promotion and inquire about the transmission. awhile back i remember talking to them about the 600's there was an issue with the rods being slightly bent from the factory in the trannys causing issues going into 3rd. Was a simple fix according to him.
Tobacco barn5.0 is offline
post #29 of 39 Old 08-04-2010, 10:06 AM Thread Starter
Thanks guys!!!
I really want to fix this TKO before I try and sell it, I'm not a fan of selling something that isn't "right". I do eventually want to go with the auto too so I'm always going to be looking for a 4R70W to throw in it. Going to send a few e-mails out and see which company replies then give that one a call.
Thanks and I'll keep everyone updated.
-Dave
1992 Mustang GT
post #30 of 39 Old 08-04-2010, 10:32 PM
UJUSTLOST's Avatar
Have a TKO600 in my stang. I have only driven it a couple of times now with the turbo and TKO. I know for a fact that this car would be considerably faster with an auto. For me, the TKO is going for sale sooner than later.
UJUSTLOST is offline
post #31 of 39 Old 08-06-2010, 08:30 AM Thread Starter
Looks like it's going to be $500 for labor/parts plus shipping both ways for them to "fix" it.
I'm just going to be REALLY disappointed if it doesn't shift good after this.
-Dave
1992 Mustang GT
post #32 of 39 Old 08-06-2010, 10:02 AM
You still need to go back and index your bellhousing. It does not matter
that its an aluminum bell.
ANY time you put ANY new bellhousing on an engine it MUST be indexed.
If the transmission is not square and true within very tight tolerances
to the engine, the clutch will not disengage properly and you will have shifting
issues.
This is incredibly critical thing to check. Dont be lazy about it.
It's not that hard to do. If you were in Houston I'd let you borrow my indexing jig and micrometer.
Order one ..... $100 with micrometer if I remember right.
http://www.precisionmeasure.com/fixt5.htm
r.barn is offline
post #33 of 39 Old 08-06-2010, 11:23 AM Thread Starter
Thanks.
I guess I'll add that to the ever growing list of parts. Might as well put a SFI scatterbell in as well.
-Dave
1992 Mustang GT
post #34 of 39 Old 08-06-2010, 01:13 PM
Ever seen the aftermath of a clutch or flywheel that let go ?
Like a bomb going off 6 inches from your ankles.
I run a SFI steel flywheel and McLeod scatter shld.
Get the McLeod over the Lakewood for sure. Mine bolted right up
and was within indexing tolerances right out of the box. Lakewoods are
notorious for needing offset dowl pins to get theirs right.
Some great vids out there on exploding clutches if you search too.
r.barn is offline
post #35 of 39 Old 08-08-2010, 09:59 AM
Huge fan of the Quick Time bell...mine was right on spec also. Plus its smaller,lighter.
4R70W/AOD junkyard gurus orion_134 General Mustang Tech 3 05-03-2010 02:43 PM
Going to the Junkyard mark12010 94/95 Tech 10 05-02-2008 03:49 PM
Going to junkyard for 4r70w...Don? orion_134 General Mustang Tech 25 07-05-2005 10:50 AM
How to tell difference between a 96-98 4r70w and a 99 and up 4r70w Mr.juice Six Shooter 3 02-27-2005 02:43 AM
Diff Between 3.8L 4R70W & 5.0L 4r70W DropDTop General Mustang Tech 2 12-04-2003 12:47 AM
