on3 first startup question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 07-29-2010, 12:37 PM Thread Starter
Just got my on3 kit running with a base tune and am using a pte 6765 turbo. Question I have is should the turbo be spinning even when the car idles down to like below 1000 rpm? It spins when I first start it and when it is idling higher but slows and stops when it idles down really low. Is the oil feed too small or what? Any help greatly appreciated thanks
01GTurbo is offline
post #2 of 4 Old 07-29-2010, 01:56 PM
Blk4V00GT's Avatar
Yes the turbo should be spinning while at idle, I would make sure the feed line is directly in the top of the turbo and that the feed line isn't kinked anywhere
1994 Mustang GT Coupe....
Blk4V00GT is offline
post #3 of 4 Old 07-29-2010, 03:23 PM
conbread's Avatar
Trader Feedback: (60)
make sure it doesnt have any exhaust leeks..
conbread is offline
post #4 of 4 Old 07-31-2010, 12:36 PM
vorga's Avatar
Mine did the same thing . the bearings are packed with a thick grease when new. once the car worms up and pushes the clean oil from your motor into the turbo .It then should spin freely at idel. As long as everything else is set up correctly.
Here are 2 vids of my first start up and one after about a hr of ideling.
My car idels at around 800rpm 2nd vid i never touched the gas
http://s867.photobucket.com/albums/a...t=P6270072.mp4
http://s867.photobucket.com/albums/a...t=P6270073.mp4
2002 MustangGT,FRPP 70mm TB,TF plenum,1/2" Intake/plenum spacer,Qa1K member A arms,UPR Coilover,UPR 4Bolt CC,Tokico HP's,FL subframe connectors,UPR torque boxs,SVT Focus Fuel Pump,BAP,42lb injectors,Magnapacks,SCT X3,Pro-5.0 Shifter,3:55 Gears,On3 MP Turbo T70,EboostStreet,446whp/511wtq
vorga is offline
New 347 startup Have a quick question. 94gt_vert_procharged 5.0/5.8 Engine Tech 6 04-28-2009 10:10 PM
First Startup (HELP) bigger_is_better 5.0/5.8 Engine Tech 28 02-25-2007 09:14 AM
lc-1 and xd-16 startup question DavidNC Engine Management Systems 0 02-14-2007 12:38 PM
New 5.0 startup beaglesfalcon 5.0/5.8 Engine Tech 5 05-21-2005 11:35 PM
Startup Idle question Ed McAndrew 5.0/5.8 Engine Tech 0 01-03-2002 08:33 AM
