Sallen/vortech intake Q's inside - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 07-24-2010, 10:29 PM Thread Starter
Banned Alleged Scammer
Does anyone or is anyone using a saleen/ vortech 5.0 intake with the extra injector bungs on the side? Im looking for pictures of this set-up being used with the extra injectors. Im looking at adding a set of injectors to my boxed upper, but need to see how the fuel system is ran. Im thinking of using a y block to distribute the fuel to the fuel rail for these injectors. Any help in this direction is grealt appreciated.
post #2 of 10 Old 07-26-2010, 12:15 AM
Lasts month issue of muscle mustangs had the lx with a extra set of injectors put in a edelbrock rpm 2 intake he had an interesting setup. that worked well.
outlawdragradial is offline
post #3 of 10 Old 07-26-2010, 04:40 AM
1995gtCPE's Avatar
Trader Feedback: (34)
With the variety of injectors available today, why add a second set? Afterall, people added a set because nothing was readily available.
1995gtCPE is offline
post #4 of 10 Old 07-26-2010, 12:07 PM
Trader Feedback: (41)
X2
There is no need for that today. I always did like the look of it thogh LOL.
stangjumper is offline
post #5 of 10 Old 07-26-2010, 08:26 PM
I had one for awhile, still running the lower, ported with a Cartech Hurricane box upper.
I almost added Nitrous jets into those bungs. Thought it woulod make a good place for a fogger set up.
500HPLX is offline
post #6 of 10 Old 07-27-2010, 09:57 PM Thread Starter
Do you by chance still have that upper?
post #7 of 10 Old 07-27-2010, 10:03 PM Thread Starter
The only reason is budget really, and I noticed my injector duty cycle went to max a few days ago, you can wire the other injectors into the main injector harness and not have to recalibrate the mass air aswell, This method is still used today actually, take a look at Proline Race Engine owner Eric Dillard , he drives a black hatch with a twin fuel rail set-up but with 16x160lb injectors lol thats alot of fuel.... Im gonna get the parts needed this weekend from the local pull-a-part and should have no more then $50 and a days worth of time in it. I will keep you guys posted.
post #8 of 10 Old 07-27-2010, 11:23 PM
conbread's Avatar
Trader Feedback: (60)
those cars are running Alcohol, that is the reason for 2 sets of injectors...Now Mike Moran has baddass injectors out and most of them have switched back to 1 set..
conbread is offline
post #9 of 10 Old 07-28-2010, 11:27 PM Thread Starter
I will post up the pictures after this weekend if I get it all mocked up.
post #10 of 10 Old 07-29-2010, 09:25 AM
And it never seemed to work well back when they were sold new. Maybe today people can get them to work better.
Sallen Wing 87-93 Stangs 89StrokerStang Exterior Parts 3 02-21-2009 03:56 AM
F/S: Ford Truck lower only- Same as Holley/Vortech/Sallen EvinH Windsor Engine Parts 2 02-02-2008 10:25 PM
f/s: Ford Truck lower only- Same as Holley/Vortech/Sallen EvinH Windsor Engine Parts 0 11-18-2007 10:13 AM
96 Sallen DOHC conversion Dennis Reinhart GT & SOHC 5 09-10-2006 05:47 PM
HELP with Sallen Guages jpetre GT & SOHC 3 03-11-2002 03:56 PM
