T-trim or twin turbos??? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 07-20-2010, 05:15 PM Thread Starter
92t-trim's Avatar
Smile T-trim or twin turbos???
which should i go with? i have a T-trim now, but i have a chance to get a twin turbo kit (home made) the turbos are 60 A/R cold side, .63 hot. t/3-t-4 flange. it will go on a 408 windsor with 205/225 type heads. basically need a little help deciding which on to go with. any advice will help.
thanks corral peeps
92t-trim is offline
post #2 of 12 Old 07-20-2010, 06:08 PM
The kit is made for a 351? I'd imagine most will say turbo since this is a turbo forum section. But if it were my car then it would greatly depend on the quality of the homemade it and any sacrifices the install required me to do.
post #3 of 12 Old 07-20-2010, 08:32 PM Thread Starter
92t-trim's Avatar
it's for a 302, and i figured i would have to modify it a little, but basically i never did the turbo route, and didn't know if it was worth the trouble if any.
92t-trim is offline
post #4 of 12 Old 07-20-2010, 08:40 PM
Yes, they are worth it.
t3/t4's are a bit small for a 408 unless the hotside is spec'd out just right.
you want
Hotside t3 with Stage 5 trim wheel and .82 a/r housing
Coldside t4 - 60-1
that will spool like a mo-fo on a 408 and support about 700+rwhp
You can swap out hotside housing and wheels easily
Might be more trouble than it is worth trying to make 302 kit work on a 351 though.
r.barn is offline
post #5 of 12 Old 07-20-2010, 08:44 PM
While the turbos might be worth it that does not mean the homemade kit is. Depending on how it is laid out you could be looking at a downpipe hassle at the very least. Plus depends on how the headers are made as well.
post #6 of 12 Old 07-20-2010, 08:47 PM Thread Starter
92t-trim's Avatar
i'l do that and check on the exact specs of the turbo's. also that's what i heard about being on the small side, gives me some things to think about.
92t-trim is offline
post #7 of 12 Old 07-20-2010, 09:14 PM
I'd also look at the intercooler and see if it is worthy of the turbos or not.
post #8 of 12 Old 07-20-2010, 10:38 PM
Turbo. No shredded belts!!
I came, I saw, I gave her a towel......
bigd3077 is offline
post #9 of 12 Old 07-21-2010, 07:00 AM
On all of my Vortech combos I never had issues with shredding belts. What I did have issues with was the Vortechs leaking oil although my last Vortech combo had zero issues.
post #10 of 12 Old 07-21-2010, 03:33 PM
331merc's Avatar
I never once shredded a belt. I would say turbo = no belt slipping. lol
With the turbo most likely to small and a questionable home made kit I say max out the T trim. Then step up to a YSi. You should be good to go!
Mike 1986 Capri street car w/ a/c, p/s & p/w
Custom built T6 80mm s400sx based kit Shaunthony's built (Twin Trouble and Anthony Fury)
9.31 @ 146 1.39 60' on drag radials @ 3735# Kurgan tuned AEM EMS
80mm 718rwhp new 88mm 921rwhp No new track times yet
331merc is offline
post #11 of 12 Old 07-21-2010, 06:24 PM Thread Starter
92t-trim's Avatar
i never had a issue either besides the belt slipping ever once in awhile. seems like everyone is saying keep the t-trim and spin it, unless you go with bigger twin turbo's than the ones that i mentioned above on the first post.
92t-trim is offline
post #12 of 12 Old 07-21-2010, 09:57 PM
WHITEMACH's Avatar
Trader Feedback: (23)
vortech,,,,they do make a quality piece,,,,love turbos but if you already have it! just my .02
2012 GT AUTO
bbr tune ,bbr x-pipe,jlt cold air
[email protected]
WHITEMACH is offline
T-trim or twin turbos??? 92t-trim Superchargers 16 07-26-2010 10:22 PM
twin turbos stang393 Turbochargers 2 09-17-2007 12:22 AM
twin turbos wickedstallion Power Adders 7 11-25-2005 10:21 PM
Twin Turbos smokin88 Turbochargers 4 06-01-2003 04:31 PM
