On3Performance 4v Turbo Dyno Numbers - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 34 Old 07-19-2010, 10:46 PM Thread Starter
Blk4V00GT's Avatar
Ok guys so I drove the car 7 hours from TN to Fort Mill SC the day after the car started. Pro-Dyno tuned the car this morning and the car made 445rwhp and 430rwtq @ 9lbs of boost in 94 degree heat.
I have a couple exhaust leaks I gotta track down and fix when I get back from Mustang Week next week but other then that I am happy and just have some minor things I need to work on to get her perfect.
1994 Mustang GT Coupe....
Blk4V00GT is offline
post #2 of 34 Old 07-19-2010, 10:51 PM
Trader Feedback: (250)
nice numbers man
eighty8gtfiveo is offline
post #3 of 34 Old 07-19-2010, 11:29 PM
ill say this.... FIX THEM....
In my experience bad exhaust leaks affect spool up time and I think even power...
I thank 2002mustanggt for helping me fix mines I went from probably 50% exhaust leaks to 99.9 exhaust leak free
1loudsuv is offline
post #4 of 34 Old 07-19-2010, 11:37 PM
conbread's Avatar
Trader Feedback: (60)
good numbers, the guys at ProDyno do dam good work....
conbread is offline
post #5 of 34 Old 07-20-2010, 12:06 AM Thread Starter
Blk4V00GT's Avatar
Thanks guys, I have v-band gaskets in all my hotside already so I may have to have a couple of the pipes modified to fit a little better and not open up the gaps.
And yes Pro-Dyno is some great people. Dan the tuner helped me out all week getting my car started while the shop was closed and he was on vacation. I highly recommend them to anyone. Very stand up shop.
post #6 of 34 Old 07-20-2010, 02:00 AM
2002mustanggt's Avatar
Congrats !! get that nasty leak fix then you will make more power plus enjoy even more.
2002mustanggt is offline
post #7 of 34 Old 07-20-2010, 02:01 AM
Your welcome
post #8 of 34 Old 07-20-2010, 02:08 AM
90fiveoh's Avatar
I want to ask. why would you even consider getting the car tuned when everything wasnt set? If you are losing exhaust because of an leak, and you do fix the leak its going to effect your tune....
90 Turbo GT
90fiveoh is offline
post #9 of 34 Old 07-20-2010, 09:32 AM
Pretty good numbers. Get the leaks fixed and they will go up.....
I came, I saw, I gave her a towel......
bigd3077 is offline
post #10 of 34 Old 07-20-2010, 10:22 AM Thread Starter
Blk4V00GT's Avatar
I needed to get the car tuned as soon as I could, the leaks weren't real bad during the tune, when he pulled the car off the dyno the y pipe hit and caused the bad leak, the tune shouldn't be affected much by the small leak I had during the tune
post #11 of 34 Old 07-20-2010, 12:54 PM
Tune will change with leaks, watch your a/f.
post #12 of 34 Old 07-20-2010, 02:43 PM
if it's after the turbo then it wont do any harm or anything at all with the afrs.
19935.slow is offline
post #13 of 34 Old 07-20-2010, 04:22 PM Thread Starter
Blk4V00GT's Avatar
Yeah I talked to the tuner while I was there and he said the only thing ill have to do is back the boost off some as it will increase without the leaks. The actual tune itself should be fine, so I'm not real worried about it.
post #14 of 34 Old 07-20-2010, 07:35 PM
Not exactly. if it's before the turbo, it will cause slow spool. After the turbo can still cause AFR change if it's before the O2's. Anything after the O2's, it won't matter. other than annoying.
10secgoal is offline
post #15 of 34 Old 07-20-2010, 10:16 PM Thread Starter
Blk4V00GT's Avatar
Yeah I plan on fixing the leaks as soon as possible, and I will watch my gauges to make sure everything is still alright.
post #16 of 34 Old 07-21-2010, 02:46 PM
are you going to be at the track thursday with the car? We are going out to the drag race event thursday and then to the hooters deal Friday. Ill try and find you if you were going to be at either of those events. Ill have my green 2v down there with us driving around
On 3 Performance is offline
post #17 of 34 Old 07-21-2010, 09:27 PM
I'm moving to Ohio so I can hang out with you guys!!!
Eh, never mind, I'll stay in South Florida!!
bigd3077 is offline
post #18 of 34 Old 07-22-2010, 01:35 AM Thread Starter
Blk4V00GT's Avatar
Chad, its been a rough couple days trying to get down here. Alt. went out right after the dyno and today on my way to the beach my cobra r hood flew up @ 80mph and destroyed my hood and windshield and bashed in my roof. Ill be at the events but idk if my car will be. Depends if I can find a hood to put on just to make the car driveable
post #19 of 34 Old 07-22-2010, 10:12 PM
Damn, that sucks...
bigd3077 is offline
post #20 of 34 Old 07-26-2010, 01:44 PM
Wow, I have worried about that same thing on my notch with the fiberglass hood. Didnt want to run pins but really dont want that same thing happening either. Sorry to hear that
We looked around all 3 days down there and didnt see the car, hopefully the body damage isnt too bad.
post #21 of 34 Old 07-26-2010, 02:24 PM Thread Starter
Blk4V00GT's Avatar
Yeah I had already decided to get hood pins when I got back home but apparently I was a little too late, my new hood will be getting them asap.
Damage is estimated to be about $3500 but we will see what happens
The car was really only there saturday, I saw your green car at the drag strip and I saw you leaving the mall friday but that was it lol, hopefully next time the trip will go a little bit better
post #22 of 34 Old 07-27-2010, 12:53 AM
Ouch thats no good, will your insurance cover any of the damage?
Hopefully everything will get sorted out and we will see it out next time
post #23 of 34 Old 07-27-2010, 12:56 AM
Speaking of the mall, I took it fairly easy leaving there and had no idea there was that cop in the median. Did you see him pull that red early model Mustang over in front of me? I saw him swinging out and thought I was done nailed but ended up pulling over the other guy
post #24 of 34 Old 07-27-2010, 03:07 PM Thread Starter
Blk4V00GT's Avatar
Haha yeah chad I saw the cop pull out, but you got lucky. Your car sounded good leaving too.
I have always taken off when I leave in the past but I didn't this year bc more cops and I almost got nailed last year leaving haha. Glad you didn't get nailed though
post #25 of 34 Old 07-27-2010, 04:34 PM
Trader Feedback: (22)
I've yet to see an on3 car that wasn't plagued with exhaust leaks
03 Mustang GT
Turbo 2v
LS1KILR is offline
post #26 of 34 Old 07-27-2010, 05:27 PM
turbocar's Avatar
u know after reading this, i saw your car in the back of the mall parked, without a hood on it.
1993 GT 357W T76
turbocar is offline
post #27 of 34 Old 07-27-2010, 07:46 PM Thread Starter
Blk4V00GT's Avatar
Haha yeah that was me....I pulled up and bought a hood from one of the venders and bolted it on in the parking lot.
post #28 of 34 Old 07-27-2010, 10:22 PM
turbocar's Avatar
gotya, was it the white hoods that guy had for sale? along with that over priced 117k mile 03 cobra longblock.
1993 GT 357W T76
turbocar is offline
post #29 of 34 Old 07-28-2010, 12:24 AM Thread Starter
Blk4V00GT's Avatar
Yeah that was him haha, the hood was a good deal though and worked out perfect givin my current situation.
post #30 of 34 Old 07-28-2010, 07:40 AM
turbocar's Avatar
good thing that woreked out for you. great numbers for sure and dan at pro dyno is awesome.
1993 GT 357W T76
turbocar is offline
post #31 of 34 Old 07-28-2010, 10:08 PM Thread Starter
Blk4V00GT's Avatar
Yeah im happy with the numbers, i thought i would hit that number at 8lbs but im still happy. those numbers are only up to 6k and i plan on shifting around 6300. Dan was a huge help and i would recommend him to anyone
post #32 of 34 Old 07-28-2010, 10:29 PM
I drove past there I think it was later saturday night maybe around 9-930 and they still had cars on the dyno. Those guys had cars going non-stop everytime I saw them, the track and hooters both days we were there
post #33 of 34 Old 08-01-2010, 04:58 PM
NVENEM8U's Avatar
I want one of these kits so bad
Bottle, Bolt-ons, Driver.....anything else ruins the surprise
NVENEM8U is offline
post #34 of 34 Old 08-01-2010, 10:27 PM Thread Starter
Blk4V00GT's Avatar
Well worth the money, I would recommend the kit to anyone looking to get started but can't afford a more expensive kit
On3performance, DYNO VIDEO SLO GT Turbochargers 30 03-16-2010 10:09 PM
bg turbo kit dyno numbers 95mustang_gt Turbochargers 26 11-09-2009 09:45 AM
dyno time 2002 Mustang GT with single on3performance turbo kit powershifter Video 7 10-26-2009 09:48 PM
99 Cobra with an On3Performance Turbo Kit Dyno Results Mobile Chassis Dyno Turbochargers 26 10-09-2009 08:57 AM
For those thinking of getting an on3performance turbo kit Dyno Results!!!! Mobile Chassis Dyno Turbochargers 30 07-24-2009 06:16 PM
