Optimal BOV location in intake track? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 07-19-2010, 06:33 PM Thread Starter
Donovan's Avatar
What is the optimal BOV location in the intake track? For some reason I got the idea in my head that having the BOV before the intercooler would be good since you would be venting the hot air prior to cooling preventing extra heat loading of the Intercooler. Anyone have any thoughts on this?
94 GT Vert - R347 - B&G w/PT76GTS - T56M - AEM w/LS2 Coils - 575/601tq @ 10Psi
Donovan is offline
post #2 of 14 Old 07-19-2010, 06:48 PM
strokercharged95GT's Avatar
yes between the turbo and intercooler is the best becuase of the reasons you mentioned in addition to keepin it further away from the mass air sensor.
2013 Mercedes GLK-350
strokercharged95GT is offline
post #3 of 14 Old 07-19-2010, 08:31 PM Thread Starter
Donovan's Avatar
Mass Air Meter? What is that?
Donovan is offline
post #4 of 14 Old 07-19-2010, 09:10 PM
thats where we have our bov located on our kits as well
On 3 Performance is offline
post #5 of 14 Old 07-20-2010, 03:59 PM
Glad you made this thread, I was just searching for an answer on this!
97 GT/03 Cobra
Chingus is offline
post #6 of 14 Old 07-20-2010, 04:48 PM
Banned Alleged Scammer
I put mine after the mass air meter on the throttlebody side. Is this bad?? Will this cause a problem with my mass air sensor? Thanks
post #7 of 14 Old 07-20-2010, 04:50 PM
Erich's Avatar
Yeah, I have one on each side of the intercooler inlets. Any turbulence will be dampened by going thru the ic
Erich
Erich is offline
post #8 of 14 Old 07-20-2010, 06:01 PM
My plans are to move one to each side like you have described above erich. Thats for pointing me in the right direction.
post #9 of 14 Old 07-20-2010, 10:16 PM
"One to each side" as in two BOVs?
97 GT/03 Cobra
Chingus is offline
post #10 of 14 Old 07-21-2010, 02:23 AM
I do believe that is what he is saying. I am assuming twin turbos and a 2 inlet 1 outlet intercooler. He's gonna put a BOV right before each inlet.
Lowvez is offline
post #11 of 14 Old 07-21-2010, 12:16 PM
Erich's Avatar
That is correct.
There is an inlet on each side of the IC at the bottom and one outlet on the Pside at the top. So a bov goes between each turbo outlet and the inlet of the ic on on each side.
Erich
Erich is offline
post #12 of 14 Old 07-22-2010, 01:52 AM Thread Starter
Donovan's Avatar
You are dumping that air to the atmosphere right? If so you are reducing the amount of metered air that is going to the engine when you open the throttle plate which would cause a rich condition. Not ideal IMHO. You are better off to put the BOV before the MAF meter.
Donovan is offline
post #13 of 14 Old 07-23-2010, 01:02 AM
here is my setup
Turbomustang
Mesarina is offline
post #14 of 14 Old 07-24-2010, 11:10 AM
I just recievd my two bov flanged pipes and waiting on my other bov so I can put them in the correct locations. Thanks to op for this thread, thanks guys.
IAT sensor location Super Victor Intake MSERNO75 5.0/5.8 Engine Tech 9 10-01-2009 05:57 PM
Powerband Location... Heads or Intake? 92cleancoupe 5.0/5.8 Engine Tech 0 07-07-2007 01:07 PM
Typhoon intake pcv hose location 89stang89 5.0/5.8 Engine Tech 0 06-07-2007 01:45 AM
Pro Products u/l intake pvc location 89stang89 5.0/5.8 Engine Tech 4 06-01-2007 10:17 AM
Intake Air Temp Sensor Location blowingt GT & SOHC 6 03-22-2002 10:17 PM
