difference in MSd digital 6 and BTM - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 07-19-2010, 09:25 AM Thread Starter
vbstng's Avatar
i did search and found a few things about both, just had a few questions.
i did notice the BTM is a lot more expensive, but it says its for boost. does the digital 6 have the boost retard like the BTM? also is it ok to put one of the boxes on your car before the turbo kit is installed? and drive on motor for a bit?
91 MUSTANG GT
99 EXPLORER DAILY DRIVER
vbstng is offline
post #2 of 7 Old 07-19-2010, 10:20 AM
1995gtCPE's Avatar
Trader Feedback: (34)
No boost retard on a digital 6.
1995gtCPE is offline
post #3 of 7 Old 07-19-2010, 03:26 PM Thread Starter
vbstng's Avatar
so the BTM should be better for turbo cars, i see alot of turbo cars with the digital 6.
91 MUSTANG GT
vbstng is offline
post #4 of 7 Old 07-19-2010, 03:58 PM
frankstang's Avatar
Trader Feedback: (115)
Seems like not a lot of people run them, but after having a couple MSD's crap out on me, I went with a Mallory 685.
http://www.jegs.com/i/Mallory/650/685/10002/-1?CT=999
Boost retard (need to buy a map sensor), 2 rpm limits, nitrous retard, 2 step, start retard.
I bought one used and it seems to be a hell of a nice box. Oh, by the way, no pills or rotary dials. Everything can be set with the two arrow buttons on the screen.
frankstang is offline
post #5 of 7 Old 07-19-2010, 06:38 PM Thread Starter
vbstng's Avatar
buy a map sensor? for a mass air car? hows that work?
91 MUSTANG GT
vbstng is offline
post #6 of 7 Old 07-19-2010, 06:43 PM
frankstang's Avatar
The map sensor hooks into the wire harness and a vacuum line. It reads manifold pressure and adjusts timing depending on if you're into boost.
It's really simple. Just plug it in, run a vacuum line, adjust how much timing you want removed per pound of boost.
post #7 of 7 Old 07-23-2010, 01:24 AM
could you tell me about your setup? base timing? how much retard, and how is the afr tuned, thanks
Turbomustang
Mesarina is offline
For Sale NX Nitrous kit, Digital Window Switch, Remote Opener, Digital Nitrous Gauge, etc. Zinc01 Power Adders 7 07-19-2010 10:38 AM
Autometer P/N 3389 Digital Pro Shift Systems - Shift Light / Digital Tach - Gauge 69mach03 Electronics and Entertainment 30 06-16-2009 03:18 PM
MSD DIGITAL 6 cobras281 Electronics and Entertainment 6 06-19-2005 11:53 PM
digital WOT and Digital Window switch.. GI Joe Power Adders 0 12-12-2004 10:43 PM
Attn MSD Digital 6 users/digital igniton users struckby 5.0/5.8 Engine Tech 7 08-10-2002 11:28 AM
