which heads? on a 351w 76mm turbo - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 07-17-2010, 10:03 PM Thread Starter
ok i have a set of trick flow twisted wedge heads 170cc also a set of
trick flow high ports cast iron.they are both 2.02 1.60 its going to be more of a street car then a track car but will see the track.a list below is whats done to the car.just trying to figure out which heads.i know the high ports are heavy but i have been told by alot of people they are better then my twisted wedge heads.
351w roller block
turbonetics 76mm turbo with F1-68 turbine wheel ceramic ball bearing.81 A/R
JGS precision 40mm wastegate
front mount intercooler
CRT built the trans,comparable to a super comp c-4.
has a PA transbrake valve body,billet servo,PA deep pan,scs cheetah shifter,small bellhousing(157t),B&M tranny cooler,-6an steel braided lines for the cooler,
9" billet convertor 3800 stall with a billet stator in the convertor
A1000 fuel pump
Aeromotive fuel rails
Anderson Motorsport PMS
Twisted Wedge Heads
Trick flow Box R series upper and lower
75MM throttle body
PMAS blow through mass air meter
60lb injectors
Ford Racing SFI Harmonic Balancer
Ford racing aluminum drive shaft
QA-1 K member with A arms
90/10 with coilovers
Real cobra R hood
Cobra front bumper
Cobra rear bumper
rear lower control arms
2002 Cobra Complete interior
MSD6BTM with boost retard
NOS 150 dry kit
AEM Tru boost controller
15x3 and 15x10 welds wrapped in 275/60/15 Mickey Thompson Drag radials
st pete chad is offline
post #2 of 14 Old 07-17-2010, 10:11 PM
Trader Feedback: (41)
I would use the the TW heads. They are both good heads. BUT TW's are aluminum, 50lbs less plus you be able to run more timing and/or boost with them.
stangjumper is offline
post #3 of 14 Old 07-17-2010, 10:13 PM Thread Starter
i was told the high ports i could run more timing and boost.plus they wont run as hot.also i was told they wont lift like the aluminum heads could do.plus i was told the high ports will make more tq and power over the twisted wedge...
post #4 of 14 Old 07-18-2010, 12:41 PM
Highports are the bomb for sure.
TW's will work just as good though, work better with off the shelf turbo kits
are cheaper and will support enough power to break the block.
I'd just go with the 170 Twisted Wedges.
aluminum > cast iron on boosted motor
r.barn is offline
post #5 of 14 Old 07-18-2010, 01:36 PM Thread Starter
see i hear that the iron high ports are better for boost then the aluminum are better.either way ill pick one of them and sell the others
post #6 of 14 Old 07-18-2010, 03:17 PM
conbread's Avatar
Trader Feedback: (60)
i think they can both make the same power, i would just go with the TW just to loose a little weight..
conbread is offline
post #7 of 14 Old 07-18-2010, 04:27 PM
Louis Rowe's Avatar
What are the pistons desighned for inline or twisted wedge and that should tell you what you need to do.
Louis Rowe is offline
post #8 of 14 Old 07-18-2010, 04:31 PM Thread Starter
stock pistons
post #9 of 14 Old 07-20-2010, 03:13 AM
351w roller block
A1000 fuel pump
Twisted Wedge Heads
75MM throttle body
60lb injectors
Real cobra R hood
Cobra front bumper
Cobra rear bumper
NOS 150 dry kit
Can i ask what power you are making as your combo is similar to what im about to build.
eboost is offline
post #10 of 14 Old 07-20-2010, 02:08 PM Thread Starter
dont have it running yet car is in paint shop but it should make 700HP
post #11 of 14 Old 07-20-2010, 02:10 PM
stock pistons
FYI: stock pistons will need notched more than likely
r.barn is offline
post #12 of 14 Old 07-20-2010, 02:34 PM Thread Starter
they are already notched they are the pistons that came in the ford crate motors with sportsman block.look just the lighting truck pistons but they come notched
post #13 of 14 Old 07-20-2010, 11:33 PM
cool, how long til its running?
eboost is offline
post #14 of 14 Old 07-21-2010, 01:55 AM Thread Starter
should be done in the next month
For Sale PRECISION TURBO 78MM TURBOCHAGER JBetances Power Adders 7 01-25-2010 10:21 AM
Turbonetics 78mm Hurricane turbo 02saleen Power Adders 7 12-09-2009 06:36 PM
93 Notch 363ci 78mm Turbo Low 9sec Street Legal nosfed408coupe Mustangs For Sale/Wanted, 1987-1993 23 11-13-2009 09:12 PM
78mm Turbo for Sale [email protected] Power Adders 0 10-03-2006 12:25 AM
what heads for twin turbo 351w xrcool250 Turbochargers 4 10-08-2003 06:12 PM
