Getting hot inside car - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 07-17-2010, 03:27 PM Thread Starter
Hey guys I have a question what type of insulation you guys are using to stay cool inside the car...I'm getting hot after 45 to a hour of driving gets hooot...thanxxxxxx...
turbo_ase is offline
post #2 of 8 Old 07-25-2010, 09:14 AM
LOL, I just sweat and so do most of the guys I run with..
Turbo 306,How fast will it go that depends on who is around.. Local parts pimp.. Things for sale most stuff is OBO https://docs.google.com/document/d/1hvqaA8aKICIw6BBj3IU2KCwiv86TtWXmxmvrsd8lw1A/edit?hl=en_US&pli=1#
wvstangdriver is offline
post #3 of 8 Old 07-25-2010, 02:39 PM
I use the aluminum backed thermal insulation from jegs. And wrapped the exhaust from turbo back past the passenger seat. How does your exhaust run out of your car? Alot of my heat was coming in at the shifter due to bad seal. I used the insulation and some heat resistant sealer there but I have to redo the sealer everytime I pull the trans.
outlawdragradial is offline
post #4 of 8 Old 07-25-2010, 06:58 PM
Rich G's Avatar
Trader Feedback: (35)
Make sure you dont have any holes in the firewall, after I removed the AC box in my fox I would get super hot, I made patch panels and sealed them in and it kept the car much cooler.
Rich G is offline
post #5 of 8 Old 07-25-2010, 11:18 PM
jonyboy107's Avatar
Trader Feedback: (15)
I am having the same problem.. but im scared of wrapping passed the downpipe. Wont it rot?
DAILY DRIVEN: 92 GT
306,9,5:1,AFR 185s,RPMII,xe264hr,ProMagnum rockers,turbonetics 66S,bg kit,METH,Flowmaster catback,Accufab race 75mm,pro tube,60lb injectors,255lph walbro BAP,ac delete,no smog,full MSD ignition,mark fan,3G alt,TKO600,spec stage 3,alum flywheel,3.55s
jonyboy107 is offline
post #6 of 8 Old 07-25-2010, 11:57 PM
Mine has been on for 2 years, but i don't drive it alot if weather looks bad and it sits in the garage. I put on heavy coat of the silicone spray and usually retreat it when i change oil about 3 times a year.
post #7 of 8 Old 07-26-2010, 12:05 AM
does that silicone spray actually help??
1loudsuv is offline
post #8 of 8 Old 07-26-2010, 08:13 AM
Yeah, but you have to drown it with it though and continue to retreat. That has worked for me so far.
Best way to see inside a t-5??? stlslow50 General Mustang Tech 2 03-09-2006 01:41 PM
Need help look inside epaez 94/95 Tech 3 11-05-2003 08:43 AM
I want to see inside my T-5, how? Charged up 5.0/5.8 Engine Tech 1 07-15-2002 10:07 PM
rattle inside tank. Anyone ever had baffle inside tank come off? fast4d 5.0/5.8 Engine Tech 5 06-24-2002 12:21 PM
Can cats' break inside? loud clunking, rattling from inside exuast? foxbody_sandiego 5.0/5.8 Engine Tech 5 04-29-2002 07:17 PM
