94-95 B&G Downpipe Installation? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 07-16-2010, 11:41 PM Thread Starter
Donovan's Avatar
I am mocking up my turbo hotside setup that I just got from Brian and am trying to figure out what the best strategy is to get the B&G downpipe installed. I currently have the turbo and P/S header installed and I am thinking its not going to go in fully assembled like that. Any tips before I go banging up a perfectly ceramic coated downpipe? I was thinking possibly feeding it up from below but i am just not sure....
94 GT Vert - R347 - B&G w/PT76GTS - T56M - AEM w/LS2 Coils - 575/601tq @ 10Psi
Donovan is offline
post #2 of 5 Old 07-16-2010, 11:56 PM
1995gtCPE's Avatar
Trader Feedback: (34)
Get some 2in wide blue painters tape and tape that thing up for the initial install.
1995gtCPE is offline
post #3 of 5 Old 07-17-2010, 02:27 AM
Alex in Houston's Avatar
I cut it, installed a V-Band and suggest the same to others.
You can it in, as sent from BG but.. if you have A/C or in my case, A/C and I piped the wastegate back into the downpipe. It's a bit much of a struggle.
Mr. M. M. Alexander
Originally Posted by Stopsign32v View Post
Stop crying, its just the internet. Life gets alot harder than some screen name on a message board not liking what you do to your car.
Alex in Houston is offline
post #4 of 5 Old 07-21-2010, 12:11 AM
If you pull the passenger side valve cover off, you should be able to get it on. I have had mine off and on a couple of times now. The other way to do it......Set the passenger side header in place but not bolted in. Slide it as far forward as possible and tilt it down. Then you can slide the downpipe in its home and prop it up with some zipties to the hood. Now you can go about installing the header and the turbo.
It can be a total pain in the ass.
I did not want another exhaust connection under the hood, just another joint to come loose and I dont think they look that great under the hood to be honest.
Good luck!!
Sean
hackster is offline
post #5 of 5 Old 07-22-2010, 01:57 AM Thread Starter
Donovan's Avatar
Damb. I am really not looking forward to that.
Donovan is offline
downpipe question 87pony Turbochargers 17 12-23-2009 10:18 AM
downpipe ? pup50 Turbochargers 10 05-07-2007 05:20 PM
WTB downpipe 94sixsilver 2.3L Engine Parts 1 03-28-2007 11:41 AM
WTB: 3/3.5" Downpipe peporacing Exhaust Parts 2 09-07-2005 12:53 PM
WTB: 3 inch downpipe scorp69 2.3L Engine Parts 2 09-27-2004 10:31 PM
