upr coil overs not fitting around the struts!! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 07-15-2010, 07:23 PM Thread Starter
bwaite's Avatar
im having a issue with upr coilovers Not fitting around my struts there is i round metal piece thats not letting it fit around. how can i fix this ? also how does the coil over seat on the bottom? these look like cheap ebay ####! i bought them off urp website? preparing for the on3 turbo set up. thanks you all for your help!!!!!!!!!!!
bwaite is offline
post #2 of 13 Old 07-15-2010, 07:45 PM
bennydaball930's Avatar
Did you bother to read the instructions that came with the kit???
Dust cover support must be removed. Use a 1/4” drill bit and drill out the 3 spot welds on top. Drill the weld only do not drill strut!
2. Next using a grinder to remove the dust cover from the top of the strut by grinding down the spot welds holding the cover to the strut. Once the spot welds are ground down you can pry off the rest of the dust cover with a screw driver. These can also be drilled out however grinding is recommend as to not drill through the body of the strut.
1993 Turbo LX
bennydaball930 is offline
post #3 of 13 Old 07-15-2010, 07:47 PM Thread Starter
bwaite's Avatar
its kinda hard to read them if i never received any? i wouldnt be asking then!
bwaite is offline
post #4 of 13 Old 07-15-2010, 09:03 PM
Bubbaman99's Avatar
The sleeve just slides over the strut and line the cutout with the strut mounting tabs.
Bubbaman99 is offline
post #5 of 13 Old 07-15-2010, 10:50 PM
conbread's Avatar
Trader Feedback: (60)
i know on the lakewood 90/10's you have to knock the cap off the top of the strut..
conbread is offline
post #6 of 13 Old 07-18-2010, 06:31 PM
privatejoker's Avatar
That's what I was thinking, you need to remove the dust cap.
privatejoker is offline
post #7 of 13 Old 07-19-2010, 10:50 PM
kevj46774's Avatar
I'm running the upr coilovers too and they are garbage. The spring rubs the threaded sleeve that goes over the strut and makes a nice noise while doing it.
kevj46774 is offline
post #8 of 13 Old 07-21-2010, 08:31 PM
You know you can just go to their web site and download the instructions! You need to remove the dust cover by drilling out the spot welds. This is very common! Just don't drill into the strut!
Mine don't rub at all, how ever my CC plates make a god awful noise!!!
88mmNotch is offline
post #9 of 13 Old 07-21-2010, 09:11 PM Thread Starter
bwaite's Avatar
yea i got them on what kind of cc plates you got
bwaite is offline
post #10 of 13 Old 07-21-2010, 09:14 PM
Rich G's Avatar
Trader Feedback: (35)
Turbocharger forum??
Rich G is offline
post #11 of 13 Old 07-21-2010, 09:32 PM Thread Starter
bwaite's Avatar
yep cause this ""turbocharger forum"" is a lot more active didnt have any luck in reg forum got the turbo kit but this was stopping me from going any further.. thank you for your worry's
bwaite is offline
post #12 of 13 Old 07-21-2010, 09:40 PM
Rich G's Avatar
You're welcome
Rich G is offline
post #13 of 13 Old 07-21-2010, 09:58 PM
UPR aluminum.
WTB Fox 90/10 or 70/30 struts and Coil overs 427strkrLX Suspension 5 04-26-2008 08:02 AM
Struts with coil overs fireman02 Drag Racing 3 03-06-2008 09:27 PM
QA1 Struts & 175 coil overs Chalie R. Suspension 5 06-13-2006 09:12 AM
D&D or QA1 Coil-Over kit? Also, Tokico Drag or QA1 Struts to go with my Coil-Overs? joe-stang Drag Racing 2 09-19-2003 02:03 PM
Best 90/10 struts for D&D coil overs? 91interceptor General Mustang Tech 2 05-20-2003 05:29 PM
