Backfiring under a load - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 07-12-2010, 08:13 PM Thread Starter
Drove my car around some today and did a WOT pull all went well until intercooler pipe came off at the maf, fixed that (thinking that's all that happend) drove it again then started getting a back fire under heavy throttle i can see it's loading up with fuel because it pegs wideband on rich side then does the backfire... So pulled back into driveway, intercooler pipe still good, but then I noticed the vacuum manifold on driverside firewall were the a/c vacuum line was the cap I had on there blew off probably on 1st drive out. Just wondering if that is my source of backfire issue?
93coupee is offline
post #2 of 8 Old 07-12-2010, 11:12 PM
maybe the maf is damaged
T70Cobra is offline
post #3 of 8 Old 07-12-2010, 11:22 PM Thread Starter
Shouldn't be didn't do it earlier in the day
93coupee is offline
post #4 of 8 Old 07-13-2010, 12:17 AM
plugs spark blow out
wild95 is offline
post #5 of 8 Old 07-13-2010, 12:21 AM Thread Starter
That's the thing didn't do this until the intercooler pipe came off under boost right before the maf then the vacuum leak from the cap getting blown off the vacuum tree on driversde firewall.. Just didn't know if a vacuum leak would cause this to happen
93coupee is offline
post #6 of 8 Old 07-13-2010, 08:05 AM
plug the tree and see if it still backfires.
T70Cobra is offline
post #7 of 8 Old 07-15-2010, 10:51 PM
Banned Alleged Scammer
backfire
x2
post #8 of 8 Old 07-15-2010, 11:19 PM
Ya a vacuum leak will cause a backfire among other issues.
sliver85 is offline
Load I/O Load Tuner software download Goody_Seven Engine Management Systems 2 07-04-2010 08:04 PM
fuel pressure drops under load or at high revs with no load Behemoth 5.0/5.8 Engine Tech 2 11-22-2008 11:00 PM
backfiring 19805.8L 5.0/5.8 Engine Tech 5 07-18-2005 01:19 PM
backfiring, cold when driving undr load BLK92GT 5.0/5.8 Engine Tech 0 04-11-2004 03:23 PM
My car is backfiring, can anyone tell me why? bgwlystyl 5.0/5.8 Engine Tech 4 04-19-2003 10:44 PM
