K-Memeber issue - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 07-09-2010, 09:46 PM Thread Starter
Xstang82's Avatar
K-Memeber issue
I got On3 kit and need to know who is using what K-memeber and what has no issues or if it does what are the issues?? It's a 4V kit 2003 Mach 1... Thanks.....
Xstang82 is offline
post #2 of 4 Old 07-09-2010, 10:17 PM
vorga's Avatar
02 GT QA1 K and A arms UPR coil over kit and bump steer . No problems on the install. I took my time but did everything in my garage at my house. Did install myself for 99% of the build
2002 MustangGT,FRPP 70mm TB,TF plenum,1/2" Intake/plenum spacer,Qa1K member A arms,UPR Coilover,UPR 4Bolt CC,Tokico HP's,FL subframe connectors,UPR torque boxs,SVT Focus Fuel Pump,BAP,42lb injectors,Magnapacks,SCT X3,Pro-5.0 Shifter,3:55 Gears,On3 MP Turbo T70,EboostStreet,446whp/511wtq
vorga is offline
post #3 of 4 Old 07-10-2010, 09:44 AM Thread Starter
Xstang82's Avatar
OK with your QA1 did your front wheels move forward?? I know most of the aftermarket K memebers move the wheels forward. Very few don't but may have issues with pipes hitting..
Xstang82 is offline
post #4 of 4 Old 07-10-2010, 04:26 PM
vorga's Avatar
I was told it diddnt move the wheel forward but it does look like they are about 1/2in foward . I diddnt measure before i started so its hard to tell
vorga is offline
WHICH K MEMEBER?? racer37355 GT & SOHC 3 05-08-2008 09:03 PM
qa1 k memeber 97305hpcobra SVT & DOHC 0 09-19-2005 09:09 PM
WTB Tub K Memeber in Ga. SNY95 Suspension 0 03-11-2005 08:30 PM
93 k memeber spideys85gt Suspension 1 12-04-2004 09:23 PM
fox k memeber spideys85gt Suspension 0 09-27-2004 04:20 PM
