can vacuum brake booster check valve handle boost? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 07-08-2010, 02:56 PM Thread Starter
or am I missing something like an external plumbing change to prevent such an issue? I'm talking like 15#. Plus, what keeps it from popping out of the grommet on the booster?
JimS is offline
post #2 of 7 Old 07-08-2010, 11:47 PM
04Ryan's Avatar
Yea they take it just fine...and the reason they don't pop off is because there isn't any boost on the other side of the check valve trying to pop it off. All the boost stops at the actual valve...if anything the rubber hose going to the check valve would pop off. Thats why everyone recommends you zip tie all your rubber vacuum hoses so they don't blow off. Hope that helps!
1992 2V Notch
S-Trim 14lbs
[email protected]
04Ryan is offline
post #3 of 7 Old 07-09-2010, 01:20 AM Thread Starter
that really does help.... and now it makes sense why the check valve doesn't blow off. I should have thought a little harder on that one.
thanks
JimS is offline
post #4 of 7 Old 07-09-2010, 02:05 AM
joeswr400's Avatar
I have a dumb question, does the booster actually hold vacuum? Mine won't when tested with a mity-vac. But I seem to remember testing the one on my old truck and it held vacuum fine?
"Authority should derive from the consent of the governed, not from the threat of force!"-- Barbie TS3
fquick.com/frankenstang
joeswr400 is offline
post #5 of 7 Old 07-14-2010, 01:59 PM
04Ryan's Avatar
Yes they are supposed to hold vacuum...a small leak may not be a problem. But a big leak would render the booster pretty much useless...not to mention having a vacuum leak that could cause all kinds of driveability issues.
1992 2V Notch
S-Trim 14lbs
[email protected]
04Ryan is offline
post #6 of 7 Old 07-14-2010, 05:05 PM
joeswr400's Avatar
Yeah, I kinda figured that would be the answer. Now the question, should I install the hydroboost setup I have or just get the 93 cobra spec booster? Oh boy.
post #7 of 7 Old 07-14-2010, 11:12 PM
do you have to add the check valve or is it one already one installed ?
mikeextrafast is offline
Where to find grommet for brake booster check valve? Adam Dugger General Mustang Tech 6 10-24-2010 01:52 PM
XE282HR - enough vacuum for brake booster and vacuum advance? cobradvm 5.0/5.8 Engine Tech 9 02-04-2010 06:52 PM
Anyone use a brake booster check valve inline with pcv valve? Black Superchargers 14 02-10-2006 02:46 PM
FS: 93 Power Brake Vacuum Booster jag218 Suspension 3 11-20-2004 06:16 PM
Check Valve For Brake Booster on a 1993? sam 5.0/5.8 Engine Tech 0 06-07-2002 05:09 PM
