Rear end gears and turbos - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 34 Old 07-06-2010, 09:27 PM Thread Starter
Banned Alleged Scammer
I understand that having steep gears (4:10, 3:73) are not good in a turbo car because of spinning. But what gears are good for turbo spool under load? Is there a such thing as having the correct gear for the turbo to spool better? If the car hooks doesnt this put an instant load on the turbo, so if a 3.08 or 3.27 gear is utilized doesnt this help loading the turbo as well as bring a more usefull rpm range? Any light in this subject is appreciated. Thanks
post #2 of 34 Old 07-06-2010, 10:29 PM
Answered your own question!!
I came, I saw, I gave her a towel......
bigd3077 is offline
post #3 of 34 Old 07-06-2010, 10:49 PM Thread Starter
Im starting to figure the stuff out lol thanks man-
post #4 of 34 Old 07-06-2010, 10:57 PM
UJUSTLOST's Avatar
You have a 2 fold issue with a high gear ratio in a turbo car. First, much like a nitrous car, the engine is now a torque monster. It no longer needs a mechanical advantage like a high gear ratio to get the car moving. By going to a lower gear ratio, you are now utilizing all that extra torque and loading the turbo.
Secondly if running in the 1/4 mile, you typically maximize gears based on cam and head combo. So if you are running N/A and you needed a 4:10 to cross the finish line at 6500, which is where your cam and heads made maximum power, it will be different with a turbo. Now with that same gear you may cross the stripe at 7800rpm, well out of the power range of the cam and heads and probably out of the range of the bottom end you built to spin to 6500. I have a friend that runs 4.88s in his turbo car but he spins it to 9500rpm through the traps because that's where his particular setup makes its peak power.
Remember, its all about matching your parts. If you build a motor to spin to 6500rpm, choose gears and a cam and heads that will peak at that rpm. Also note that a turbo can stretch the peak power point out a little. So for instance if your cam peaked at 6500 N/A, you may make power to 7000rpms with a turbo. Its all a matter of math and science. Now let an engineer come in here and explain it better than I did......LOL
UJUSTLOST is offline
post #5 of 34 Old 07-07-2010, 01:31 AM
i have a 3.27 in mine
st pete chad is offline
post #6 of 34 Old 07-07-2010, 04:29 PM Thread Starter
Im thinking a 3.55, I also have it already. I bought a 3.73, 3.55, 4.10 before doing the turbo set-up and still have them all. and still have the 3.08 that cam in the car. It seems when I nail the car in 1st gear i have to shift, its going thru the gears really quickly.
post #7 of 34 Old 07-07-2010, 05:10 PM
conbread's Avatar
Trader Feedback: (60)
i would try the 3.27..i have a 3.27 and c4 with 28'' tires and i can drive this car anywhere i want, and loads the turbo great..
conbread is offline
post #8 of 34 Old 07-07-2010, 06:20 PM
hey quick question hows the driving on the highway how the c-4 and the 3.27 that what i have on my 95GT with a 351w and 76mm turbonetics turbo
post #9 of 34 Old 07-07-2010, 08:32 PM Thread Starter
Would the 3.55 be okay with a 5spd then? I also use 28" tires, If the 3.27 is a must then i will go grab one from the pull a part for $45.00,
post #10 of 34 Old 07-07-2010, 09:42 PM
2002mustanggt's Avatar
asap funds available will swap to 3.27 from my 3.73.
2002mustanggt is offline
post #11 of 34 Old 07-08-2010, 02:46 PM
conbread's Avatar
this car could run 80mph all day long and run about 28-3000rpms...it can be driven anywhere..
conbread is offline
post #12 of 34 Old 07-08-2010, 08:37 PM
foxfan88's Avatar
Depends on the car and power level. I'd say treat the gearing like any other car. Its just you have more lower rev power with the turbo so you can still pull like a freight train at lower revs and use the higher gear and still run good.
What i have found is with too low of a gear with a turbo. When you mash the gas, your turbo is going to take an amount of time to spool. and with the lower gear, in that amount of time your engine is going to rise in RPM, So your turbo is going to have to push more air to make that desired boost pressure at that higher rpm.
In a sense you can "outrun" the turbo.
With the higher gear its going to bog the motor more and the RPM wont rise as much in that same amount of spool time, so you can reach the desire boost quicker. ALso the abundance of midrange torque gives you a broader powerband so the high gear can work good.
IMHO its not really that big of a differnce. The turbo seems to spool the same, but like i said the higher gear "bogs" it more and keeps RPMs from rising. It "seems" like it spool faster.
With the low gear, RPMS rose and boost hit and just blew the tires off.
Dont fall into the cut and paste 3.27s mindset. It seems like alot of folks automaticially hear "turbo car" and instantly tell you to go 3.27s
If your making lower power like 400 hp with lower boost, IMO a 3.27s can be too high. If your making more boost and more power in the 500-600 range a 3.27 should be the ticket.
If its a track car, dial in the gear for the trap speed/rpm/power etc etc.
If its a street car, IMO you can run the higher gear and work pretty good since your using alot more of your midrange and etc to play around with rather than just the high rpm like a strip car.
Also another factor is the trasmission your running.
A t5 or tko etc is much lower and tighter geared than say a c4 or AOD, so with the auto you can run a lower rear gear to get the same overall gearing as the manual car. unless you get a lower ratio gear set for your auto.
Brett
91 GT 302 CID c4 w/brake
TFS TW heads, f-cam, typhoon
70mm masterpower single turbo setup.
foxfan88 is offline
post #13 of 34 Old 07-08-2010, 11:44 PM
04Ryan's Avatar
I run 2.08 rear gears with 33" tires on my car...........
1992 2V Notch
S-Trim 14lbs
[email protected]
04Ryan is offline
post #14 of 34 Old 07-09-2010, 11:06 AM
I switched to 2.73 rearend gears in mine and it didn't seem to hurt a thing http://www.youtube.com/watch?v=AQtmrxaRVTg
1965 Cobra replica with twin turbo Dart block 331
thomaswpt is offline
post #15 of 34 Old 07-09-2010, 03:20 PM Thread Starter
cobra
Nice acceleration , that thing comes to life !!!!
post #16 of 34 Old 07-09-2010, 06:36 PM
vorga's Avatar
Im running 3.55 with 17x315 tires with my turbo setup . I havent had a chance to go to the track yet But i plan on going next friday . The closest track is like 15 miles away but it is a 1/8 mile track . At least i can see what my 60 is with the new gears and turbo .
2002 MustangGT,FRPP 70mm TB,TF plenum,1/2" Intake/plenum spacer,Qa1K member A arms,UPR Coilover,UPR 4Bolt CC,Tokico HP's,FL subframe connectors,UPR torque boxs,SVT Focus Fuel Pump,BAP,42lb injectors,Magnapacks,SCT X3,Pro-5.0 Shifter,3:55 Gears,On3 MP Turbo T70,EboostStreet,446whp/511wtq
vorga is offline
post #17 of 34 Old 07-10-2010, 02:46 PM Thread Starter
keep us informed on this-
post #18 of 34 Old 07-10-2010, 05:20 PM
Formerly eades5.0
4Jenna's Avatar
When Mine was running 11.0 @ 134 I went from 3.73's to 3.27s and it felt like I gained 50rw.
I still run them
WWW.JENNABEARSFOUNDATION.ORG
4Jenna is offline
post #19 of 34 Old 07-10-2010, 06:36 PM
Jersey True Street Guy
mcj50's Avatar
Trader Feedback: (84)
I had a major issue with my car but there are a lot of variables involved.
With a 3.55 and a 27 inch tire I couldn't go faster then 9.50 utilizing 14 lbs of boost which is about 650 rwhp. It was not comfortable nicking the rev limiter through the traps.
With a 3.27 and a 28 inch, I was able to go 9.70 with only 8 lbs of boost because the car was working "right".
For that valve train with 28 psi, I would have likely benefited from a 3.08 because it would only spin 6400-6500.
I since changed to a larger solid roller to let it spin 7500. I kept my 3.55's just in case...I will let everybody know how it works differently.
mcj50 is offline
post #20 of 34 Old 07-11-2010, 10:26 PM Thread Starter
I dropped the 3.55s in today, wow what a difference!!! 1st-4th Im seeing 14-14lbs as soon as I nail it and still cruise in 4th all day lol, man it feels good with the 325-50-15 m/t. The turbos seem to come on easier, not really have to work or maybe they were overworking before??? not sure
post #21 of 34 Old 07-12-2010, 09:06 AM
I'm looking for 600 rwhp, and I'm going 3.27 or 3.31......
bigd3077 is offline
post #22 of 34 Old 07-12-2010, 07:56 PM
04Ryan's Avatar
What did you have in there before?
1992 2V Notch
S-Trim 14lbs
[email protected]
04Ryan is offline
post #23 of 34 Old 07-12-2010, 08:13 PM Thread Starter
4.10s first gear was way too fast, rpm wise. I didnt see alot of boost in 1st but now Im happy.
post #24 of 34 Old 07-13-2010, 12:04 AM
Blk4V00GT's Avatar
I currently have 3.73s and plan to run about 450rwhp so well see how that works but I'm thinking ill switch to 3.55s to get the best overall.
1994 Mustang GT Coupe....
Blk4V00GT is offline
post #25 of 34 Old 07-13-2010, 12:12 AM
Procharged F1R with 4:10's horrible will be swtiching asap oh yeah at 24lbs i cant hook up with any gear
wild95 is offline
post #26 of 34 Old 07-13-2010, 02:07 AM
Congrats !! BEAST!!
post #27 of 34 Old 07-13-2010, 01:01 PM
privatejoker's Avatar
This is a very good explanation. The next question is, how high is too high? Should we all trade our aods and C4s in on powerglides? Is crossing the traps at redline really the best way or does a turbo require even more load.
privatejoker is offline
post #28 of 34 Old 07-15-2010, 03:40 PM
vorga's Avatar
Ive had a chance to play some with my turbo setup . Keep in mind that this is a just about stock motor running 8 pounds of boost and 3.55 gears and like zombiestang said as soon as I hit the gas im also making boost . 8 pounds of boost by the time im at 3500rpm. The only problem is there is sooo much TQ that the tires want to break free as the RPMs climb in 2nd and 3rd. On the hwy the gear seems fine 2000rpm im running about 75mph. All and all i am glad i went with the 3.55 i think its a good allaround gear.
vorga is offline
post #29 of 34 Old 07-15-2010, 03:52 PM
ratedz's Avatar
This
Same here.
1986 Mustang GT
525hp/626tq
ratedz is offline
post #30 of 34 Old 07-17-2010, 07:29 PM
i was getting ready to do a search and found this thread. answered almost everything i needed to know. one thing though what about convertors. getting ready to do a turbo and hav aod with a 3500 stall. what gearing should i look for? just recently did the tranny and convertor so not looking to lose it?????
gibbit70 is offline
post #31 of 34 Old 07-18-2010, 01:57 PM Thread Starter
3.55 or 3.73, also depends on your power level as stated above. I got a chance to hit the track friday night, it rained in staging lanes, waited 30mins to clear and clean the track. it started lightning, so they did hand drops wtf lol i really wanted a time, it felt good, 2nd &3rd was really nasty. it pulled like a frieght train, I left on a 4500 2 step with4-5lbs boost with worn 325 drag radials, thats a no no , spun horribly, but caught a normal 7.20 car with no problem and was granny shiftin lol. Putting the 28x10 on for this friday and trying again!
post #32 of 34 Old 07-18-2010, 03:15 PM
conbread's Avatar
sounds good, keep us updated on how it runs..
conbread is offline
post #33 of 34 Old 07-18-2010, 05:22 PM
1995gtCPE's Avatar
Trader Feedback: (34)
Most likely 60' better with a 3.55 at your power level. I know mine did.
1995gtCPE is offline
post #34 of 34 Old 07-18-2010, 06:00 PM Thread Starter
Ive got a run friday night with a 03 cobra, its a buddy. Hes putting 527 to the tires, granite his car has a solid axle conversion its a heavier car, he went 7.2-7.0s with dragradials last yr, he will be on et streets friday, I will be on full slicks, my shifting will hurt me if anything. I havent raced a 5spd in 4yrs lol. Trying to get a c4 back in it before friday lol, I will post the video on next sat
2.73 gears gone! 3.27s rock for turbos! Erich Turbochargers 13 12-03-2008 07:49 AM
Gears and turbos Hal900x S-197 Mustang (2005-2010) 1 08-30-2005 04:07 AM
Turbos, Turbos, Turbos / Video From U.S. Nats @ Bradenton Mr. Fordman Turbochargers 0 02-08-2005 10:20 AM
Turbos, Turbos, Turbos / Video From U.S. Nats @ Bradenton Mr. Fordman Drag Racing 0 02-08-2005 10:19 AM
When you put gears in your rear end, do you have to change your timing chain to gears Generallee 5.0/5.8 Engine Tech 8 05-03-2002 06:21 PM
